Prodajem nove UHF lampe ,tranzistore i audiolampe
ivocvetkov
Post by ivocvetkov »
CENOVNIK -4.08..2010
Novi delovi:
-470mF/400v:105st ,,Nichucon, - 2.5 evr
-6S4S –ruski 6С4С -analog /2А3/ 6A3/ -20evra
-keramicki kondenzatori K15U-1: 1000pf//4kv;30 kvar-5.0
- Bezinduktivni otpornici 50 Oma;50 W; do 10 GHz -12.5.0 evr
-5S4S- 5.0 evr
-GM70-25.0 evra
GU81,81М-25.0evr
-MRF377; RF power ;Mosfet;tranzistor;860MHz;Pdiss 486W;32V;-180 evra
-BLF861A; 150W;32v;14db;50%;850mHz;UHF;pover; LDMOS sot540 -130 evr
- BLV862 /TVU 150 / :PTF 150 W;28 V; 860MgHz ; UHF linear; puch-pul;SOT 262- 150 evra
--BLF 278/b tr-r 300 W;50v;14-20db;80-225mhz;VHF puch-pul;pover mos -125 evr
Vakum kondenzatori:
5-250 pf; 5 kv -50 evra
5-350pf;10kv - 60 evra
15-750 pf;5 kv; -90 evra
20-1000pf;10 kv;-100 evra
Keram kondenzatori k15U1-100,220.470 pF/6-do 20kv
BLF 177/b tr-r;prf180w;50v;30dw;SSB>35%;CW70%%;28-200mhz;hf/vhfMOS SOT121 /analog MRF151,154/
-65evr
BFR94;PH;NPN 3.5 GHz wideband transistor;25v;3,5W;sot122E -5 evra
Kondenzatori –original i-va kl
47mF/400v;105 st. ,,Rubycon,, -0.85 evr
47 mF/450 v;105 st.,,NPC,, -0.9 evr
100 mF/450 v;105 st.,,Matusita,, -1.35 evr
220 mF/400 v;105 st. ,,LSG,, -1.5 evr.
220mF/450v;105st,,Matusita,,-1.8 evr
330mF/400V; 85 st.,,Hitachi,,-1.5 evra
. 470mF/400v:105st ,,Nichucon, - 2.5 evr
3300mF/25v;105 st,,Rubycon,,.-0.75 evra
4700 mF/63 v;858 st.,,Matusita,, -1.5 evr
10000 mF/50 v.,,NKS,, -3,25 evr.
Elektrol. Kondenz. Tantal :
ETO-2;200mF/50v -3 evra
MODUL ZA RADIOPREDAINIK:
130W; 1-70Mhz; S ugradeni
/BLW77-2KOMADA IZLAZ;BLW83-3KOMADA POBUDA / -1V …50 EVRA
Trimer-kondenzatori ,,Tekelect,,
0.7pf –6 pf -1.0evr
1pf -20 Pf; -2.5 evr
1pf -30 PF -2.5evr
Druga fifma ;ph
0.7pf -5.7Pf -1.5 evr
0.9pf -9 Pf – 1.5 evr
Trimer SMD/Jonson/
4-18pf –1evr
7-40pf –1evr
Koaksialno relei REW/14 : Power handling capability (used at >2KW @ 432MHz) 1500 W PEP Insertion loss <0,2 dB to 650 MHz Isolation (measured: ~45dB @ 2M, ~35dB @ 70cM) >30 dB to 650 MHZ Coil voltage 24 V Coil current 120 mA;komplekt s konektori 3 komada -40 evra
Bezinduktivni otpornici 50 Oma;50 W; do 10 GHz -12.5.evr
Prom.vakuum kondenzatori: KP1 /5-250 pF/ 5 kv - 50 evra
JO 2014 60v; 2.6A;do 400MHz;80 W –analog MRF326 -8.0 evra
C1228 ;-10w; 33V; 1A ;UHF-L; 400 MHz-analog MRF321 pobuda za JO 2014 – 5 evra
KT919A ;28V; 0.7A; do1350 MHz; 10 W -3 evra
KT 919B ;28 V; do 1350 MHz -3 evra
KT919 V ;28v ;do 1350 MHz -3 evra
KT610A –12V,0.3A;1.5W;.>1GHZ- 4evr.
КП903А-MOS-N-FET 20V/0,7A/6W-3.0
KT909A – 28V;27W;500MHZ;2A - 3.5
KT909B- 54W; -3.5
KT911A- 28V;3W;1800MHZ -3.5
KT911B-28V;1000MHZ; -3.5
KT 911V-28V;750MHZ; -3.5
KT911G- 28 V; 750 MHZ; 3.5
KT 913A-28V;0.5A;5W;1GHZ -4.0
KT913 B-28V;1GHZ;8W - 4.0
KT 913 V-28V;1GHZ;12W’ -5.0
KT 920 A-12V;0.3A;5W;50-200MHZ -3.5
KT 920 B-12V;400MHZ;10W; -3.5 evra
KT 920 V-12V;3A;25W;50-200MHZ –5.0 evra
KT920 G-12V;3A;25W;50-200MHZ -4.0
KT 922 A-28V;0.8A;8W;>300MHZ -3.0
KT922 B-28V;3A;20W;50-200MHZ -3.5.0
KT922V-28v;5a;40w;50-200MHz – 5.0evr
KT 922 G-28V;3.3A25W;50-200MHZ -5.0
KT925A-12V;5w;50-400MHZ -3.5
KT925B—12V;11W; IK=1A;50-400MHZ -4.0
KT 925 V-12V;3.3A;25W;50-400MHZ; -5.0 evra
KT 928 A-28V;2W;250MHZ; -2.0
KT 930 A-28V;6A;40W;50-400MHZ -10.0
KT 930 B-28V;6A;100W;50-400MHZ -10,0
KT 931 A-28V;130W;50-400MHZ -20.0 -20.0
KT 934 V-28V;0.5A;705W;50-600MHZ –4.0
KT957 A-28 V;1-30 Mhz; 100 W;20 A - 10 .0
KT 958 A- 12V; 80-400 MHZ; 60W - 10 EVR
KT 971A-28V;17A;190W;50-200MHZ –60.0 evr
KT 983A-za Tv predainik 40 -860MHZ ; 8.7W;>1.2GHZ -15.0
KT983B-za Tv predainik 40-860MHz;13W;1A;>1,2GHz -15.0
BLX68 –600MHZ;18V;4A;25W –6,0
BLY 38-18V;0.5A;5.5W;1GHZ -3.0
BLW 77-28V;130W;120MHZ,koristeni,demontirani iz modul,100%garancija-10.0evr.
BFQ42-12V;2W;175MHZ -1.5
BFR94;PH;NPN 3.5 GHz wideband transistor;25v;3,5W;sot122E -5.0evr
BFW 16A-12V;1.4W;1GHZ -1.5
C12-28-10W;400MHZ;28-33V;analogMRF321-5,0 evr.
JO2014-80W;28-36V;3.3A;400MHZ -10 evra
AF270- 1.0
AF240-700MHZ -1.0
KT935A-60W;28V;60MHZ -5.0
3P915B-2- -2.5
3P604B2 -2.5
PROHODNI C 2NF -0.3
UHF lampe
GI 7B – 25.0 evr
GI7B-25 evr
GI23B -20.0 evr
GS 31B - 65.0
GU43B - 50.0
GS 35B - 95.0-evra
GK71 - 20.0
GU50+podnoge - 12.5.0
GU81,81М- 25.0
6С9Д/6S9D/
ВИ1-30/25-kenotron
Г-837
ГИ-30
ГИ-210
ГМИ-6 /GMI-6/
ГМИ-11 /GMI-11/-modulator -30.0
УВ-4 /UV-4/
ГУ32 /GU32/
ТГ1 01/03 /TG1 01/03
СГ15И-2 /SG15I-2
К-28
13ЛМ6В
PP65
УВ-3 /UV-3/
ГУ17 /GU17/
Audiolampe
Podnoge keramicki nemacki-noval 9 pin. -0.8 evra
Oktal 7 pin -0.3 evr
Podnoge za 6S33S -7.5 evr
2П1П /2P1P/ -3.0evr
4Ц1С /4C1S/-3.0
6А7 -3.0
5Ц3С /5C3S/ -6.0
5Ц4С/5c4s/ -5.0
5Ц8С/5C8S/- 6.0
6A8
6BC32
6Д14П 6D14P/ -1.5
6Д22С/6D22S/-4.0
6E5C
6Ж1П /6G1P/ -2.0
6Ж2П / 6G2P -2.5
6Ж3П /6G3P/ -2.5
6Ж4 /6G4/ /6AC7/EF36/EF37A -2.5
6Ж9П /6G9P/ - 3.0
6Ж8 / 6G8/ 6SJ7/5693/ -3.0
6Ж10 /6G10/ -3.0
6Ж10П /6G10P/-3.0
6Ж11П-ЕВ/6G11P-EV/ 4.0
6Ж38П /6G38P/ -2.0
6К4П-ЕВ /6K4P-EB/ -3.0
6Н1П-ЕВ /6N1P-EB/ -1.5
6Н2П-EB/-analogECC83/ 6N2P-EB/- 4.0
6Н3П /6N3P/ 2C51/5670 -2.5
6Н6П /6N6P/ -4.0
6Н23П /6N23P/analog ECC88/ -4.0
6Н7С /6N7S/ -1.5
6Н8С /6N8S/ /6SN7/ 6F8G/12SN7/5663;92 -4.0
6Н9С /6N9S/6SL7/12SL7/5691/ -3.0
6Н14П /6N14P/ -
6П1П -ЕВ /6P1P/ -3.0
6П3С /6P3S/ 6L6/ -5.0
6П6С /6P6S/6AQ6/7A5/6005/ -4.0
6П13С /6P13S/ -3.0
6П31С /6P31S/ -2.5
6П36С /6P36S/ -4.0
6П14П- /analogEL84/ -4.0
6П18П /6P18P/ -3.0
6П42С /6P42S/ -6.0
6П45С/6P45S/-7.5
6Р4П /6R4P/ 3.0
6С2П /6S2P/ -3.0
6С4С/analog /6S4S/ 2A3/6A3/ -17.5
6С19П /6S19P/ -3.5
6С17К-В /6S17K-B/ UHF triod 6GHz;6.3v/ -3.0
6C33C-B /6S33S-B/ -10.0
6Х2П /6X2P/ -2.5
6Ц4П-ЕВ 6C4P-EB/ -3.0
GM70 -25.0
EAA91 -3.0
ЕBF80 -3.0
EC92 -
ЕCC81 /12A7/ -4.5
ECC82 -5.0
ECC83 -7.5
ECC84 -4.0
ECC85 -4.0
EF84 -4.0
EM84 -3.0
ECH21 -3.0
ECH81 -3.0
EF22 -4.0
EF80 3.0
EF86-5.0
ЕF85 -3.0
EF183 -3.0
ECH84 -3.0
ECL81 -3.5
ECL82-4.0
EL95 -4.0
EZ80 -4.0
ГМ70/GM70/-22,5
GK71 -20.0
PCC88 -4.0
PCF80 -2.0
PCF82 -2.0
PCL82 -3.0
PCL84 -3.0
UCH21 -
UF21
STR10/60
STR150/20
STV108/30 /StR108/30- 3.0
В1-01/30
ВИ1-30/25-kenotron
Г-837
ГИ-30
ГИ-210
ГМИ-6 /GMI-6/
УВ-4 /UV-4/
ГУ32 /GU32/
СГ15И-2 /SG15I-2
К-28
13ЛМ6В
PP65
УВ-3 /UV-3/
ГУ17 /GU17/
Mogu da nabavim I druge audiolampe !!!
K15U-1- do 10 komada
K15U1;1.5 pF;6.8kV;5kvar -2.5
K15U1;10pF; 6kV 7kvar - 2.5 evra- 100 komada
K15U1;22pF;3.5kv;4kvar -3.0
K15U1;22pF;6kV ;5kvar -3.0
K15U1;22pF;10kV;8kvar -3.0
K15U1;33pf;3.5kv;4kvar -3.0
K15U1;33pf;10kv;8kvar -3.0
K15U1;47pF;3,5kV 4kvar - 3.0
K15U1;56pF;3,5kV 4kvar - 3.0
K15U1;68pF;3,5kV 4kvar - 3.0
K15U1;68pF;6kV 7kvar - 3.5
K15U1;68pF;15kv;14kvar -4.0
K15U1 -100pF;3,5kv ; 4kvar - 3.0
K15U1 -100pF;6.0kv; 7kvar -3.5
K15U1; 220pF;3.5kV;8kvar -4.0
K15U1;220 pF;6.5kV;8kvar -4.0
K15U1; 220 pf;15kv;100kvar-10.0
K15U1; 470pF;15kV;40 kvar -5.0
K15U1;1000pF;4kv;30 kvar-5.0
KVI-3; 470pF;12kV -4.0
KVI-3; 550pF;9kv -5.0
KVI-3; 1000 pF;12kV -5.0
KVI-3 ;4700 pF;5 kv -6.
K15 U 2-moge da se nabavi
К15У2;150pf;2kv 2,5kvar
K15U2;68pF;2kv 2,5kvar
K15U2;150pf;2,2kv 2,5kvar
K15U2;82pF;2kV 2,0kvar
DDR-ker.kondenzatori-moge da se nabavi
K15U2;120pf;5kV 1,2kvar
K15U2;82pF;5kV 1 kvar
Digitalne lampe Z570M - 2 evra
Digitalne lampe Z5900M
Digitalne lampe ИН12Б /IN12B/
IB3
R120
A gdje živiš :?:
ampermetar
Re: Prodajem nove UHF lampe ,tranzistore i audiolampe
Post by ampermetar »
jel imaš 2 EM84?
