Hello,
Anybody here can share a USB EEPROM Programmer to program 8pins DIP 24xxxx EEPROM?
I've been using Serial JDM but unfortunately my laptop doesn't have any serial port anymore..
Any help will be appreciated..
TIA
Schematic for USB EEPROM Programmer
- Pocetnik na forumu
Re: Schematic for USB EEPROM Programmer
Heloo. Solution for you is that you buy USB/RS232 (serial port) cable and on one end of cable you have USB conector on the other end of cable you have serial port conector.
That cable you have in every IT store. In Bosnia that cable cost about 8 eurs.
And with zhat cable you can use JDM on your notebook.
mehmed
Ovo spada u gotove projekte ...
Hmmm...it seems to work for EEPROM since it does not need high programming voltage like PIC...I'll try this..BTW USB to Serial converter cost about US$2 here...
Thanks for the suggestion...
rhonnz
@Razor, covjek je stranac i ne zna "domaci" jezik. Tvoja primjedba ima vise smisla kad domaca raja upadne gdje ne treba!
@kasamiko, take a look at http://www.sprut.de" onclick="window.open(this.href);return false; , here you can find many useful solutions for issues with microcontrollers.
Thanks for the link...but it seems too complicated for a simple EEPROM programmer...
rhonnz
