Velleman pic programator
Locked
Cvik_Dasa
Post by Cvik_Dasa »
Pozdrav...
Dakle radio sam programator s [urlhttp://www.velleman.eu/support/downloads/?code=K8048/url]
Cvik_Dasa
Re: Velleman pic programator
Post by Cvik_Dasa »
Ispričavam se na gornjem postu... slučajno sam stisnuo submit umjesto preview.
dakle radio sam programator s vellemanove stranice k8048, al sam izbacio s šeme tastere i ledice za testiranje.
http://i46.tinypic.com/dy39df.jpg
Problem se javlja prilikom upisivanja programa u PIC
S orginalnim programom samo javi error i to je to neznam kakav, zato sam probao par različitih programa.
1.WinPic800
Error: ERROR -> Verifying address 0x000000 Verified: 0x28DB Read: 0x0000
2.IC-Prog
Error: Verify failed at address 0000h
3.WinPic
Error:
Programming...
Programming and Verifying CODE, 0x000000..0x000138
Verify Error: 000000: read 000000, wanted 0028DB
Verify Error: 000001: read 000000, wanted 003FFF
Verify Error: 000002: read 000000, wanted 003FFF
Verify Error: 000003: read 000000, wanted 003FFF
Verify Error: 000004: read 000000, wanted 0028D2
Verify Error: 000005: read 000000, wanted 003FFF
Verify Error: 000006: read 000000, wanted 003FFF
Verify Error: 000007: read 000000, wanted 003FFF
Verify Error: 000008: read 000000, wanted 003FFF
Verify Error: 000009: read 000000, wanted 003FFF
Verify Error: 00000A: read 000000, wanted 003FFF
Verify Error: 00000B: read 000000, wanted 003FFF
Verify Error: 00000C: read 000000, wanted 003FFF
Verify Error: 00000D: read 000000, wanted 003FFF
Verify Error: 00000E: read 000000, wanted 003FFF
Verify Error: 00000F: read 000000, wanted 003FFF
Verify Error: 000010: read 000000, wanted 0000A3
Programming aborted after 17 errors.
Suspicious: Buffer contains no data for the CONFIGURATION BITS.
Programming CONFIG-WORD
Verify Error: 002007: read 000000, wanted 003FFF
ERROR: Programming FAILED !
Zanimljiva stvar je da ni jedan od programa ne javlja grešku dok čitam program iz PIC-a več samo kad pokušavam upisati novi.
Napon napajanja je 17VDC na MCLR pinu je 12,07. Dovodio sam napon od 13,25v na MCLR al opet je javljalo greške.
Radi se o PIC16F84A-04
Kakav je comp tj. com-port na njemu, virtualni ili ...?
Inače nema baš smisla praviti programatore na com ili lpt port.
Cvik_Dasa
Post by Cvik_Dasa »
orginal com port preko žensko ženskog produžnog kabla od 1 metar.
Slažem se al opet treba nekako i isprogramirat pic za usb, a ovo mi tako i tako treba "jednokratno" tako da mi se ne isplati kupovat usb pic programator
Ako je jednokratno ne isplati se praviti ni com-programator.....
Pošalji to nekom iz blizine da ti isprogramira
Cvik_Dasa
Post by Cvik_Dasa »
Tako će i bit jer je programator završio svoju karijeru u smeču.
Ima li ko voljan programirat, šaljem pic i hex file, ako je neko za nek mi se javi (zagreb) al može i od dalje negdje samo nebi htjeo preko granice
morski_pas
Post by morski_pas »
ako ti nije kasno do ponedjeljka javi mi se na PM
Cvik_Dasa
Post by Cvik_Dasa »
može lock
Locked
