KOD:
/* Project name:
RTC2_Read (Reading date/time data from DS1307 through I2C)
* Copyright:
(c) MikroElektronika, 2005-2010
* Revision History:
20090504:
- Author: Igor Stancic;
20101126:
- Adapted for PRO compilers (TL);
* Description:
This project is simple demonstration how to read date and time from DS1307
RTC (real-time clock). The code MCU use MSSP module at PORTC.
Date and time are printed at LCD.
* Test configuration:
MCU: PIC16F887
http://ww1.microchip.com/downloads/en/DeviceDoc/41291F.pdf
Dev.Board: EasyPIC6
http://www.mikroe.com/eng/products/view/297/easypic6-development-system/
Oscillator: HS, 8.000MHz
Ext. Modules: I2C RTC (DS1307) - ac:RTC2
http://www.mikroe.com/eng/products/view/197/rtc2-board/
LCD 2x16 chars - ac:LCD
http://www.mikroe.com/eng/products/view/277/various-components/
SW: mikroC PRO for PIC
http://www.mikroe.com/eng/products/view/7/mikroc-pro-for-pic/
* NOTES:
- For proper I2C communication, pins on PORTC must be in the pull-up mode,
RC3 - pin 6 DS1307 - SCL,
RC4 - pin 5 DS1307 - SDA,
and the LEDs on board switched OFF!
unsigned char sec, min1, hr, week_day, day, mn, year;
char *txt, tnum[4];
// Lcd pinout settings
sbit LCD_RS at RB7_bit;
sbit LCD_EN at RB6_bit;
sbit LCD_D7 at RB2_bit;
sbit LCD_D6 at RB3_bit;
sbit LCD_D5 at RB4_bit;
sbit LCD_D4 at RB5_bit;
// Pin direction
sbit LCD_RS_Direction at TRISB7_bit;
sbit LCD_EN_Direction at TRISB6_bit;
sbit LCD_D7_Direction at TRISB2_bit;
sbit LCD_D6_Direction at TRISB3_bit;
sbit LCD_D5_Direction at TRISB4_bit;
sbit LCD_D4_Direction at TRISB5_bit;
void Zero_Fill(char *value) { // fill text repesentation
if (value[1] == 0) { // with leading zero
value[1] = value[0];
value[0] = 48;
value[2] = 0;
//--------------------- Reads time and date information from RTC (DS1307)
void Read_Time(char *sec, char *min, char *hr, char *week_day, char *day, char *mn, char *year) {
I2C1_Start();
I2C1_Wr(0xD0);
I2C1_Wr(0);
I2C1_Repeated_Start();
I2C1_Wr(0xD1);
*sec =I2C1_Rd(1);
*min =I2C1_Rd(1);
*hr =I2C1_Rd(1);
*week_day =I2C1_Rd(1);
*day =I2C1_Rd(1);
*mn =I2C1_Rd(1);
*year =I2C1_Rd(0);
I2C1_Stop();
//-------------------- Formats date and time
void Transform_Time(char *sec, char *min, char *hr, char *week_day, char *day, char *mn, char *year) {
*sec = ((*sec & 0x70) >> 4)*10 + (*sec & 0x0F);
*min = ((*min & 0xF0) >> 4)*10 + (*min & 0x0F);
*hr = ((*hr & 0x30) >> 4)*10 + (*hr & 0x0F);
*week_day =(*week_day & 0x07);
*day = ((*day & 0xF0) >> 4)*10 + (*day & 0x0F);
*mn = ((*mn & 0x10) >> 4)*10 + (*mn & 0x0F);
*year = ((*year & 0xF0)>>4)*10+(*year & 0x0F);
//-------------------- Output values to LCD
void Display_Time(char sec, char min, char hr, char week_day, char day, char mn, char year) {
switch(week_day){
case 1: txt="Sun"; break;
case 2: txt="Mon"; break;
case 3: txt="Tue"; break;
case 4: txt="Wed"; break;
case 5: txt="Thu"; break;
case 6: txt="Fri"; break;
case 7: txt="Sat"; break;
LCD_Out(1,1,txt);
Lcd_Chr(1, 6, (day / 10) + 48); // Print tens digit of day variable
Lcd_Chr(1, 7, (day % 10) + 48); // Print oness digit of day variable
Lcd_Chr(1, 9, (mn / 10) + 48);
Lcd_Chr(1,10, (mn % 10) + 48);
Lcd_Chr(1,15, year + 48); // Print year vaiable + 8 (start from year 2008)
Lcd_Chr(2, 6, (hr / 10) + 48);
Lcd_Chr(2, 7, (hr % 10) + 48);
Lcd_Chr(2, 9, (min / 10) + 48);
Lcd_Chr(2,10, (min % 10) + 48);
Lcd_Chr(2,12, (sec / 10) + 48);
Lcd_Chr(2,13, (sec % 10) + 48);
//------------------ Performs project-wide init
void Init_Main() {
Lcd_Init(); // Initialize LCD
Lcd_Cmd(_LCD_CLEAR); // Clear LCD display
Lcd_Cmd(_LCD_CURSOR_OFF); // Turn cursor off
I2C1_Init(100000); // initialize I2C
LCD_Chr(1,8,'.');
LCD_Chr(1,11,'.');
txt = "Time:";
LCD_Out(2,1,txt);
LCD_Chr(2,8,':');
LCD_Chr(2,11,':');
txt = "201";
LCD_Out(1,12,txt);
LCD_Cmd(_LCD_CURSOR_OFF);
//----------------- Main procedure
void main() {
Init_Main(); // perform initialization
while (1) {
Read_Time(&sec,&min1,&hr,&week_day,&day,&mn,&year); // read time from RTC(DS1307)
Transform_Time(&sec,&min1,&hr,&week_day,&day,&mn,&year); // format date and time
Display_Time(sec, min1, hr, week_day, day, mn, year); // prepare and display on LCD
Delay_ms(1000); // wait 1s
