youtube spy bug[HELP]
likeaboss
Post by likeaboss »
Pozdrav Nov sam u elektronici i odlucio sam da se okusam da napravim ovu bubu
http://www.youtube.com/watch?v=lIyyMVsk2WA
E sada za pocetak treba mi pomoc da kupim elektromaterial ako mozete da mi prevedete sta mi treba
ovo na engleskom ne razumem :D
Home made PCB
2n3904 transistor
4.7p ceramic capacitor
1n ceramic capacitor
22n axial ceramic capacitor
1 - 5p to 30p air trimmer
360R resistor
4.7K resistor
10mm Mic
35cm antenna
Battery Plug
Some solder
19mm heatshrink
PUNO HVALA POZDRAV
nixx994
Re: youtube spy bug[HELP]
Post by nixx994 »
ne znam odakle si,i gde kpujes,ali evo prevod
Home made PCB - pertinaks ploca(bolje vitroplast,ali je skuplji)
2n3904 transistor - 2n3704 tranzistor
4.7p ceramic capacitor - keramicki kondenzator 4,7pF
1n ceramic capacitor - keramicki kondenzator 1nF
22n axial ceramic capacitor - keramicki kondenzator 22nF (ali ne onaj kao dugme,vec kao otpornik)
1 - 5p to 30p air trimmer - trimer kondenzator(od 1-30pF ili 5-30pF)
360R resistor - otpornik od 360 oma
4.7K resistor - otpornik od 4,7 K oma(4700 oma)
10mm Mic - mikrofon (10mm precnik)
35cm antenna - antena dugacka 35cm
Battery Plug - konektor za bateriju
Some solder - kalaj
19mm heatshrink - termobuzir dug 19mm
likeaboss
Post by likeaboss »
HVALA MAJSTORE :D
