Low Battery
78L05
Low Battery
Post by 78L05 »
Pozdrav svima,
zna li netko kako da napravim detekciju slabe baterije pomoću PIC-a 16F876.
Dakle predpostavljam da mi treba naponsko djeliko sa dva otpornika, radi se o bateriji od 9V, samo me zanima rutina s kojom se provjerava napon na nekom pinu.
Hvala unaprijed
bonn
Re: Low Battery
Post by bonn »
Primjer od 0 do 5v. Lako je prepraviti za bilo koji napon.
' PICBASIC PRO program to measure voltage (0-5VDC)
' and display on LCD with 2 decimal places
' This program uses the */ operator to scale the
' ADC result from 0-1023 to 0-500. The */ performs
' a divide by 256 automatically, allowing math which
' would normally exceed the limit of a word variable.
' Connect analog input to channel-0 (RA0)
' Define LOADER_USED to allow use of the boot loader.
' This will not affect normal program operation.
DEFINE LCD_DREG PORTD ' I/O port na kome se nalazi LCD
DEFINE LCD_DBIT 4
DEFINE LCD_RSREG PORTD
DEFINE LCD_RSBIT 2 ' Register select pin
DEFINE LCD_EREG PORTD
DEFINE LCD_EBIT 3 ' Enable pin
DEFINE LCD_BITS 4 ' 4-bitni data bus
DEFINE LCD_LINES 2 ' LCD ima dva reda karaktera
Define OSC 20 ' Kristal je 20 MHz
' Define ADCIN parameters
DEFINE ADC_BITS 10 ' Set number of bits in result
DEFINE ADC_CLOCK 3 ' Set clock source (3=rc)
DEFINE ADC_SAMPLEUS 50 ' Set sampling time in uS
adval Var Word ' Create adval to store result
TRISA = %11111111 ' Set PORTA to all input
ADCON1 = %10000010 ' Set PORTA analog and right justify result
Low PORTE.2 ' LCD R/W line low (W)
Pause 500 ' Wait .5 second
mainloop:
Adcin 0, adval ' Read channel 0 to adval (0-1023)
adval = (adval */ 500)>>2 ' Equates to: (adval * 500)/1024
LCDOut $fe, 1 ' Clear LCD
LCDOut "DC Volts= ",Dec (adval/100),".", DEC2 adval ' Display the decimal value
Pause 100 ' Wait .1 second
GoTo mainloop ' Do it forever
End
