samples
gdje ti je stiglo od atmela? priča se na forumu da za balkan ništa nego nekome šalješ svom u inozemstvu
I like software and hardware
- VasilyZaitsev
A šta ti zapravo treba? Mehanika ili elektronika za motor, jer i jedno i drugo se može zvati "servo"?!
Nisam to vidio nigdje (nisam ni tražio), kao samples, ali bi u Zgb moglo biti po onim maketarskim klubovima, pa se raspitaj...
Samo da dodam Amatherm firmama koje sigurno šalju. Danas (nakon više od dva mjeseca!) stigli NTC. Zaliveni u kabelsku stopicu koja se zašarafi na hladnjak tranzistora... Nice!
- VasilyZaitsev
I wanted to order fr*e sample from www.national.com but when I hit the order button a message pop up and it says that I can't order fr*e sample because I was using .gmail mail account. Then I've tried with other mail account but nothing. Is there a way to order fr*e sample from www.national.com. Please help me!!! THANKS.
You can make reply on your language I will understand I am from Macedonia, we are brothers
- VasilyZaitsev
- VasilyZaitsev
evo...sad cemo krenuti iz pocetka
naisao sam na netu na ovo
ali ne znam da li ima sve na 1. strani
Company | Webaddress | Components
TI | http://www.ti.com | Semiconductor
Maxim | http://www.maxim-ic.com | Semiconductor
Analog Devices | http://www.analog.com | Semiconductor
National | http://www.national.com | Semiconductor
Microchip | http://www.microchip.com | Semiconductor
Atmel | http://www.atmel.com | Microcontroller
Philips | http://www.standardics.philips.com | Semiconductor
Intersil | http://www.intersil.com | Semiconductor
Agilent | http://www.semiconductor.agilent.com | Semiconductor
AVX | http://www.avxcorp.com/RequestSample.asp | Passive Components & Oscillators
California Micro Devices | http://www.calmicro.com/contact_us/samples_request.html | Protection and Interface
Catalyst Semiconductor | http://www.catsemi.com/need_a_sample/index.html | Memory and Voltage Reference
Cypress semiconductor | http://www.cypress.com/support/mysupport.cfm | Networking
Fairchild | http://www.fairchildsemi.com/samples/index.jsp | Semiconductor
Infenion | http://www.infineon.com | Semiconductor
Microsemi http://www.microsemi.com/store/request. ... PLE&MN=280 | Semiconductor
Ramton | http://www.ramtron.com/ | Memory
Sipex | http://www.sipex.com/products/samples.aspx | power Managemet, Interface, Optical Storage
Steward | http://www.steward.com/Sample_Request.asp | ferrites, inductive products etc.
On Semiconductor | http://www.onsemi.com | Semiconductor
Supertex | http://www.supertex.com/contact_form/sample_request | Power Devices
Clare | http://www.clare.com | Communication and drivers
Zilog | http://www.zilog.com | Semiconductor
Coilcraft | http://www.coilcraft.com/ | Inductor
Hittie | http://www.hittite.com/index.cfm | Microwave
FTDIchips | http://www.FTDIchip.com | USB
AllegroMicro | http://www.allegromicro.com | Sensors
Linear Technology | http://www.linear.com | Semiconductor
CML Micro | http://www.cmlmicro.com | Wireless communication
Holtek | http://www.holtek.com/english/contact/contact.htm | Semiconductor Need to be contacted
System General | http://www.sg.com.tw/semiGP/sample_E.asp | Semiconductor
Bivar http://www.bivar.com/l | PCB Packaging and LED Assemblies
RiaConnect | http://www.riaconnect.com/samples.asp | Terminal Blocks and RJ connectors
SunLED | http://www.sunled.com | LED and Displays
AboveBoard Electronics | http://www.aboveboardelectronics.com | Tools
MillMax | http://www.mill-max.com | Interconnects and IC sockets
Chesrep | http://www.chesrep.com | Supplier
Meritekusa | http://www.meritekusa.com | Passive Components
Murata Europe | http://www.murata-europe.com/contact/samples.htm | Passive Components
Molex | http://www.molex.com | Connectors
Kycon | http://www.kycon.com | Connectors
Azmicrotek | http://www.azmicrotek.com | Logic Translator
Astrorep | http://www.astrorep.com | Supplier
FMG Elecronics | http://www.fmgelectronics.ie | Supplier
Electec | http://www.electec.com | Supplier
Bhel Electronics | http://www.bhelectronics.com/forms/tran ... quest.html | Transformer
Avnet | http://www.avnet.com | Supplier
Lamb Industries | http://www.lambind.com | Switches
Promor | http://www.promor.com | Supplier
TAM | http://www.tamweb.com | Supplier
Central Semiconductors | http://www.centralsemi.com | Semiconductor
LittleFuse | http://www.littelfuse.com | Power Devices and Fuses
Foxonline | http://www.foxonline.com | Crystals and Oscillators
Semtech | http://www.semtech.com | Power Devices
OKW | http://www.okw.co.uk | Enclosures and Knobs
SMD INC. | http://www.smdinc.com | Supplier
Heyco | http://www.heyco.com | Grips and holders
Teknational | http://www.teknational.com | Thermal Insulation and hardware
FCI Connect | http://www.fciconnect.com | Connectors
Bridge Port | http://www.bptfittings.com | Fittings
PMC Flash | http://www.pmcflash.com | Memory
Pericom | http://www.pericom.com | Semiconductor
Elesta | http://www.elestarelays.com | Relays
Pacentec | http://www.pactecenclosures.com | Enclosures
Sensitron | http://www.sensitron.com | Arrays, Semiconductors, LEDs
Bergquist | http://www.bergquistcompany.com | Thermal related products
Cooperet | http://www.cooperet.com | Magnetics and protection
NorthWest Components | http://www.northwestcomponents.com | Passive and Diodes
EM Microelectronics | http://www.emmarin.com | RFID
ERG | http://www.ergpower.com | Display related
Wilco | http://www.sensitron.com | Inductor
Eswitch | http://www.e-switch.com | Switches
ON Shore | http://www.on-shore.com | Terminal Blocks and connectors
AAVID Thermal Alloy | http://www.aavidthermalloy.com | Sample Kits
Epcos | http://www.epcos.com | Passive Components
Fordata | http://www.fordata.cn | LCD
TRA CON | http://www.tra-con.com | Thermal Management
WJ Communications | http://www.wjcommunications.com | Communication
NJR | http://www.njr.com | Semiconductor
Wurth Elektronix | http://www.we-online.com | PCB, EMI, EMC, Connectors
Spectra Symbol | http://www.spectrasymbol.com | Flex Sensors
Cirrus Logic | http://www.cirrus.com | Digital chips, D/A converters, Ethernet controllers, audio/video decoders…
FreeScale | http://www.freescale.com | Semiconductor
Tyco | http://www.amp.com | Connectors and Cables
ITW/Fastex | http://www.itw-fastex.com | Connectors and Clips
Micrometals | http://www.micrometals.com | Toroids
Marktech | http://www.marktechopto.com | Led and related
New Age Enclosures | http://www.newageenclosures.com | Enclosures
