kineski je i piše -this is NOT a true sine ware inverter.
e sad problem je što s njime mislim pogonit mali kompresor od 220V i 1000W,
ali mislim da neće baš funkcionirati ponajviše jer mislim da napon nije odgovorajućeg
oblika, a i skeptičan sam prema ovim oznakama od 1000W/2000W pogotovo kada vidim žice koje idu prema inverteru, i koje bi trebale izdržati 100+ A.
Specification:
-Output Power: 1000W
-Peak Power: 2000W
-Output Voltage: 220V
-Working voltage: 10 V-15 V
-Output Frequency: 50 Hz±2HZ
-The output waveform: fixed sine wave
-No load battery loss: < 0.15 A
-The Max power amplifier: more than 90%
-Work environment: 0 ℃ -40 ℃
-Low voltage alarm: 10.4 V-11 V
-Low voltage off: 9.7 V-10.3 V
-Over voltage off: 14.5 V-15.5 V
-Thermal protection: 55 ℃ 77 ℃
-Dimensions:170× 95× 55mm(approx)
Note:
-this is NOT a true sine ware inverter. This item can’t power the true sine ware equipment for example: printer, drill, etc
-Please make sure the voltage and plug slot (in the third picture) fits for your country standard before biding
evo link na ebay:
http://www.ebay.com/itm/1000W-Car-USB-D ... 5246wt_914
ima li šanse da će ovaj inverter pokrenuti kompresor od 1kw?
