Pozdrav, imam lcd termometar koji spajam u auto na 12V gdje napon malo prelazi 14V, ovakvog je tipa: http://p.lefux.com/61/20091123/A0427000" onclick="window.open(this.href);return false; ... Sensor.jpg
7812 mi nije dobar izbor, da li mogu spojiti 3 diode 1N4007 u seriju koje mi ruse svaka po 0.7V?
Stabilnih 12V iz auto akumulatora za mali potrošač lcd
- Programer15
- Pocetnik na forumu
Re: Stabilnih 12V iz auto akumulatora za mali potrošač lcd
zasto nije dobar izbor 7812
7812 treba barem 2.5V vise da bi peglao na 12V, a imam i jacu muziku u autu pa bih htio napraviti prednaponsku zastitu, a da nije 7812. Bio bih zadovoljan da imam od 11-12V, nesto u tom rasponu.
- Programer15
kako ti se cini ovo!!!
A simple 12 volts voltage regulator that can be used to supply your electronic devices from your car can be constructed using few common components . This 12 volts car adapter circuit use a 12.7 volts zenner diode but maybe you can’t find a 12,7 volts zenner , so in that case you can use a 12 v or 13 volts zenner diode . If you will use a 12 volts zenner you will need to stick in another diode like 1N4001 (in this case the output voltage will be a little under 12 ) and if you will use a 13 volts zenner the output voltage will be around 12.3 volts .
The 2N3055 transistor must be mounted on a heatsink .
http://www.electroniq.net/files/surse/12V-car-regulator.jpg
Ovo će mi svakako poslužiti!
