comment [221]
- From 22.dimitri on 01-11-2019 at 14:31:47
Poštovani, da li je moguće naručiti izradu ovog sata i slanje istoga poštom? molim javite
mi se na 22.dimitri@gmail.com
IP: 161.53.155.100
Firmware features
1. time display, obviously
2. date display
3. temperature display
4. seconds display
Structure
The Middle (wood)
The beginning
Electronics
Main PCB drilling
Capacitive touch sensor PCBs
Touch sensor PCB in place
All done!
The Back (hardboard)
Testing the LEDs
LED matrix test
Images of completed clock
Videos of clock working
Download counter: 4,149
Rating: (2.96, votes 5112)
Date: 12-09-2012
IP: 161.53.155.100
IP: 161.53.155.100
projects/word clock
i STILL iNTEREST TO BAY THIS WHER IS POSSIBOL I BAY
TKANK aDELMO
IP: 138.201.205.167
Hello Mel Smith, I am glad you like the project. What do you think about the price range that
someone would be willing to pay for the assembled English version?
Would you consider making these to sell but with English words. I couldn’t make this myself
and can’t find any as nice as yours or as big.
IP: 138.201.205.167
Ima li netko da bi prodao ovaj sat? Nema živaca da idem to radit 😂
Ako ima saljite mejl na dcigir(@)Gmail.com
IP: 46.188.132.180
Jednostavno klikni na crveno DOWNLOAD dugme, i tu su ti sve sheme, nacrt plocice a spisak
dijelova pokupi sa sheme i vidi gdje ide tacno koji dio.
Pozdrav traxe! Jel bi mi mogao poslati na mail tocan popis elemenata i sve sta mi treba za ovaj
projekt i objasniti za tocno koju shemu ide koji odredeni element. Ili neke linkove iz kojih si
to uzimao jer bi mi to dosta pomoglo i bio bi ti puno zahvalan! 3
IP: 93.142.7.173
Hrvoje, diode su: PLCC-2 / 1210 / 3528. Za programiranje mikrokontrolera treba ti hardver
(programator) i softver koji dodje uz taj programator.
Imaam pitanjee posto jos uvijek ucim ali koju velicinu SMD ledica si koristio i preko kojeg
programa si isprogramirao to za sat i kako si ga ubacio unutra?
IP: 93.136.249.40
