/Projects/Warm Tube Clock v2 - Nixie Clock
This is a new and improved version of "Warm Tube Clock" - the open source Nixie clock project. Important hardware changes between this new version and the previous one are:
- Timekeeping is more accurate and is done by DS3231 (or DS3232) RTC IC
- There is no DS18S20 temperature sensor - the internal one of RTC IC is used instead
- Backup battery is not powering AVR anymore, but only the RTC IC
- There is no "slide switch" to control the alarm - now it is done in firmware
- Crystal on PCB is optional and can be chosen up to 16 MHz. It clocks AVR and GSCLK pin of TLC59401 IC
- Pin-compatible with previous version of Nixie "shields"
So, if you didn't read about the previous Warm Tube Clock, it is best to do it right now.
All project files (schematics, PCB & source code) are available for download by clicking on the red download button under the article (open source hardware).
UPDATE: Project is on Hack-a-Day and Hacked Gadgets :-) !
UPDATE 06-03-2011: New firmware added.
UPDATE 28-11-2014: PCBs are available for sale at link: http://www.elecrow.com/warm-tube-clock-v2-pcb-board-p-1154.html.
UPDATE 10-06-2015: Forum discussion is on this link.
noleds
New firmware options
1. time display
2. date display
3. temperature display
4. seconds display
5. configurable times of showing for all of above (for example, the clock can display time for 20 seconds, and move to next thing to display: date, temperature or both and go back to time. It can even be set to display only the temperature)
6. configurable Nixie tube brightness
7. configurable color of bottom RGB LEDs that blink at 1/2 Hz rate (or even turned off)
9. fading tubes while showing the date for better understanding of what is on display (MM.DD and YYYY)
15. cathode anti-poisoning on every 5 minutes
16. 12-hour and 24-hour mode for time and date, temperature conversion to Fahrenheit
mainboard4
main board v2 - top side
mainboard1
main board v2 - bottom side
Design changes
This version of clock uses DS3231 RTC IC and is fully compatible with DS3232. There were few different methods of how this IC could have been used in this project. I chose to use it's SQW pin to generate an interrupt in AVR each second (1 Hz precisely). So, on every SQW impulse the AVR reads RTC data (I2C) from DS3231/2 to display on tubes and for other things. Note: you must solder the SMD jumper on PCB in order to use currently supplied firmware. This jumper connects SQW pin to AVR.
mainboard3
DS3231 RTC IC is now where "slide switch" used to be
Second method is much simpler - supply AVR's OSC1 (PB6) pin with 32 kHz output of DS3231/2 instead of using 32.768kHz crystal. This way the AVR would get extremely accurate 32.768 kHz clock for incrementing the Timer1 of previous version of firmware. In that case, no I2C routines would be necessary.
Third method would be not to use SQW or the 32 kHz output, but to read RTC data (with I2C) in a program loop at all times. There is that SMD jumper on board so you can disconnect the SQW pin to use this method.
RTCshema
Part of the schematics with DS3231/2 RTC IC
Nixie shields
New version of clock is pin-compatible with previous one, so it is possible to use shields of previous version on this one and vice-versa. In this new version of clock, IN-8 shield is replaced with IN-14 shield because these tubes are cheaper and easier to find.
v22
IN-14 Nixie shield
in-142
TLC59401 is at the bottom side of IN-14 Nixie shield
in-141
Under the Nixie tubes there are 4 SMD RGB LEDs
These IN-14 tubes are same as IN-16, only much bigger.
HV voltage booster
Voltage booster has remained the same. But if you are using (for example) 12 MHz crystal to clock the AVR, then the frequency of PWM signal is 46.875 kHz (FREQ/256). Using crystal of higher frequency will also result in a smoother RGB LED effects. You can experiment with the coil value and power supply to achieve minimum heating of the booster circuit. When powering clock with 11 V you can use coil of around 680 uH or even less (@ 12 MHz).
mainboard2
Nixie dots (semicolons)
Nixie dots are actually ordinary neon indicators from a 110/220V switch as you can see in the picture bellow.
neondotharvest
Nixie dot harvesting
Thermal images of PCBs
Warmest point: 36°C, coldest: 21°C. Thanks to Filip for these images!
therm2
therm4
therm1
3D printed enclosures
Thanks to Filip for this! Files can be downloaded from his blog article on this link.
therm2
Image and video presentation
v21
Image with blue LEDs
Video without bottom LEDs + at night
Video
AM/PM setting example
Nixie cross-fading example
Nixie cathode anti-poisoning
Download counter: 3,145
Rating: (2.93, votes 4805)
Date: 02-06-2011
Lokalna verzija ove stranice: Warm tube clock v2 - Nixie sat
800_warmtubeclock_v2.rar
Bookmark and Share Comments (31)
comment [31]
Hi Pablo, there is nowhere to buy all components as a KIT, but you can order mostly all parts from www.lcsc.com or www.taydaelectronics.com. Other components can be bought on ebay, so you will need to make only 3 orders: 1. PCB, 2. Parts eBay, 3. Parts on one of these two websites.
comment [30]
Hello! I really like this clock, it's refreshing to see a four digit clock for a change (six digit nixie clocks look clunky to me). I already have the tubes and would like to build this one, but because of customs in my country doing several orders for all the components isn't feasible! Does anyone know if someone's selling a kit with all the parts needed? I could do two purchases, one for the pcb and one for the rest of the parts if necessary. Thank you very much!
IP: 190.192.174.210
comment [29]
Not really! Open AVR Studio, new project for ATmega328P with (no files). Add all these files that you can download to the AVR Studio project you just d, and hit build. That is roughly it.
comment [28]
Hi is there a guide How to compile the source code. Thanks
IP: 79.66.66.170
comment [27]
Thank you Trax.
IP: 94.212.54.9
comment [26]
Hi niall, I d forum topic where you can write: http://www.elektronika.ba/forum/viewtopic.php?f=30&t=10968&p=108225
comment [25]
Hello Trax, (again), I started assembling the components to build the clock but I have a few questions regarding some of them. I apologise in advance, my electronics knowledge is basic at best and I have done a few small projects, but I am learning by doing them. Would it be wiser to the forum, open a thread on the clock so as not to fill the comments section with my inquiries.
IP: 94.212.54.9
comment [24]
Thanks...Just as I thought...I can compile assembly using MPLAB but I am a terrible programmer. If you have time perhaps you could have a go at it or you could let me know how to modify it or which lines of code to change. I haven't built it yet. I really do appreciate your time as I know it requires much time to do these projects and publish them.
IP: 24.231.243.79
comment [23]
Well, the single tube clock is only in 24hour format, but the firmware can be changed for US :) It is only a matter of subtraction in the code! I could do that once you build the hardware, or you can give it a go (it is in assembler though).
comment [22]
Thanks Trax...will post some pictures shortly...Also I looked at your single tube Nixie clock. I would like to make one but does the firmware permit 12hr operation?...Us yanks aren't on 24hr time yet....TNX....
IP: 24.231.243.79
Comment page: 1234>
