- From trax on 09-06-2004 at 17:46:53
Da li neko ima noviju verziju ovog programa?
Quote: "Put "SP" directory on "C:" otherwise the program will not work. After that you can start it with sp.bat. You can edit this file using notepad to choose your COM port. Currently it is set for COM1."
Download counter: 3,308
Rating: (2.87, votes 2565)
Date: 18-05-2004
Lokalna verzija ove stranice: ESKAY PACKET SP v9.51
Tags: . +add your tag
Puno se mucite braco sa tim semama ja se bavim 30 god,elektronikom pa tu itamo i sada zapnem.e
sa ovim semama jetesko nesto kvalitetno uraditi,vecina je tehnicki oskudna.Pa je tesko
napraviti tv predajnik koji radi kvalitetno,ako treba savet tusam...
