PIC 16F877 i DS18B20 brljavi prilikom prikaza negativne temp
zoomtronic
Post by zoomtronic »
Napravio sam termometar sa PIC-om 16F877 i sensorom DS18B20,
sve lepo radi na pozitivnoj temperaturi, međutim kad stavim sensor u zamrzivač,
počne da opada temperatura, kad dođe do 0 stepeni ne izbacuje znak - ispred temperature, a odbrojava
sasvim normalno. Kao da raste temperatura u +
evo koda
program OneWire
dim LCD_RS as sbit at RD2_bit
LCD_EN as sbit at RD3_bit
LCD_D4 as sbit at RD4_bit
LCD_D5 as sbit at RD5_bit
LCD_D6 as sbit at RD6_bit
LCD_D7 as sbit at RD7_bit
LCD_RS_Direction as sbit at TRISD2_bit
LCD_EN_Direction as sbit at TRISD3_bit
LCD_D4_Direction as sbit at TRISD4_bit
LCD_D5_Direction as sbit at TRISD5_bit
LCD_D6_Direction as sbit at TRISD6_bit
LCD_D7_Direction as sbit at TRISD7_bit
' End Lcd module connections
' Set TEMP_RESOLUTION to the corresponding resolution of used DS18x20 sensor:
' 18S20: 9 (default setting can be 9,10,11,or 12)
' 18B20: 12
const TEMP_RESOLUTION as byte = 12
dim text as char[9]
temp as word
sub procedure Display_Temperature( dim temp2write as word )
const RES_SHIFT = TEMP_RESOLUTION - 8
dim temp_whole as byte
temp_fraction as word
text = "000.0000"
' Check if temperature is negative
if (temp2write and 0x8000) then
text[0] = "-"
temp2write = not temp2write + 1
end if
' Extract temp_whole
temp_whole = word(temp2write >> RES_SHIFT)
' Convert temp_whole to characters
if ( temp_whole div 100 ) then
text[0] = temp_whole div 100 + 48
else
text[0] = " "
end if
text[1] = (temp_whole div 10)mod 10 + 48 ' Extract tens digit
text[2] = temp_whole mod 10 + 48 ' Extract ones digit
' Extract temp_fraction and convert it to unsigned int
temp_fraction = word(temp2write << (4-RES_SHIFT))
temp_fraction = temp_fraction and 0x000F
temp_fraction = temp_fraction * 625
' Convert temp_fraction to characters
text[4] = word(temp_fraction div 1000) + 48 ' Extract thousands digit
text[5] = word((temp_fraction div 100)mod 10 + 48) ' Extract hundreds digit
text[6] = word((temp_fraction div 10)mod 10 + 48) ' Extract tens digit
text[7] = word(temp_fraction mod 10) + 48 ' Extract ones digit
Lcd_Out(2, 2, text)
end sub
main:
ANSEL = 0 ' Configure AN pins as digital I/O
ANSELH = 0
text = "000.0000"
Lcd_Init() ' Initialize Lcd
Lcd_Cmd(_LCD_CLEAR) ' Clear Lcd
Lcd_Cmd(_LCD_CURSOR_OFF) ' Turn cursor off
Lcd_Out(1, 1, " Outside temp: ")
Lcd_Chr(2,13,223) ' u drugom redu na 13. mestu ' Print degree character, "C" for Centigrades
' Different Lcd displays have different char code for degree
Lcd_Chr(2,14,"C") ' u drugom redu na 14. mestu ' If you see greek alpha letter try typing 178 instead of 223
'--- Main loop
while (TRUE)
'--- Perform temperature reading DQ linija
Ow_Reset(PORTC, 2) ' Onewire reset signal
Ow_Write(PORTC, 2, 0xCC) ' Issue command SKIP_ROM
Ow_Write(PORTC, 2, 0x44) ' Issue command CONVERT_T
Delay_us(170)
Ow_Reset(PORTC, 2)
Ow_Write(PORTC, 2, 0xBE) ' Issue command READ_SCRATCHPAD
temp = Ow_Read(PORTC, 2)
temp = (Ow_Read(PORTC, 2) << 8 ) + temp
'--- Format and display result on Lcd
Display_Temperature(temp)
Delay_ms(300)
wend
end.
Re: PIC 16F877 i DS18B20 brljavi prilikom prikaza negativne temp
Mrsko milupati glavu sta si pisao, ali negativna temp je ako je najvisi bit postavljen na 1.
Oko toga malo pogledaj sta si zeznuo.
Elektronicar
Post by Elektronicar »
Koliko vidim u ovom delu se vrsi provera negativne temperature.
text[0] = "-"
end if
Testira se rezultat 0x8000 odnosno AND odredjure negativnu temperaturu, u ondosu na rezultat koji je u obliku 1xxx xxxx xxxx xxxx
Ovo je mikro basic ako negresim mislim da nisi pravilno inicijalizovao DS18B20.
Pokusaj prvo sa rezolucinom od 9 ako sve radi onda 12 bit-a pa trazi gresku.
zoomtronic
Uspeo sam uz pomoć prijatelja
evo koda
program OneWire
dim
LCD_RS as sbit at RD2_bit ' RS linija portD2
LCD_EN as sbit at RD3_bit ' E linija portD3
LCD_D4 as sbit at RD4_bit ' Data 4 portD4
LCD_D5 as sbit at RD5_bit ' Data 5 portD5
LCD_D6 as sbit at RD6_bit ' Data 6 portD6
LCD_D7 as sbit at RD7_bit ' Data 7 portD7
LCD_RS_Direction as sbit at TRISD2_bit ' RS linija portD2
LCD_EN_Direction as sbit at TRISD3_bit ' E linija portD3
LCD_D4_Direction as sbit at TRISD4_bit ' Data 4 portD4
LCD_D5_Direction as sbit at TRISD5_bit ' Data 5 portD5
LCD_D6_Direction as sbit at TRISD6_bit ' Data 6 portD6
LCD_D7_Direction as sbit at TRISD7_bit ' Data 7 portD7
' 18B20: 12
dim text as char[9]
temp as word
text = "000.0000"
if ((temp2write and $8000) = 0x8000) then
text[0] = "-"
temp2write = (not temp2write) + 1
end if
' else
' text[0] = " " ' " " izostavlja nulu na pocetku "0" prikazuje nulu
end if
if text[0] = "0" then ' Eliminise nulu ispred temperature
text[0] = " "
end if
' Print temperature on Lcd (second figure determines position of xxx.xxxx st C)
Lcd_Out(2, 2, text) ' (first figure determines ROW, second figure determines space from begining of LCD)
end sub
main:
text = "000.0000"
Lcd_Out(1, 1, " Inside temp: ") ' u prvom redu na 1. mestu
Lcd_Chr(2,13,223) ' u drugom redu na 13. mestu Print degree character, "C" for Centigrades
Lcd_Chr(2,14,"C") ' u drugom redu na 14. mestu If you see greek alpha letter try typing 178 instead of 223
'--- Main loop
while (TRUE)
Delay_us(170)
Ow_Reset(PORTC, 2)
temp = (Ow_Read(PORTC, 2) << 8) + temp
Delay_ms(300)
wend
end.
Elektronicar
Ako sam dobro primetio samo je ovaj deo koda promenjen neracunajuci ispis nule.
