# Emitted Colour : White
# Size (mm) : 5mm
# Lens Colour : Water Clear
# Peak Wave Length (nm) : N/A
# Forward Voltage (V) : 3.2 ~ 3.8
# Reverse Current (uA) : <=30
# Luminous Intensity Typ Iv (mcd) : Average in 20000
# Life Rating : 100,000 Hours
# Viewing Angle : 20 ~ 25 Degree
# Absolute Maximum Ratings (Ta=25°C)
# Max Power Dissipation : 80mw
# Max Continuous Forward Current : 30mA
# Max Peak Forward Current : 75mA
# Reverse Voltage : 5~6V
# Lead Soldering Temperature : 240°C (<5Sec)
# Operating Temperature Range : -25°C ~ +85°C
# Preservative Temperature Range : -30°C ~ +100°C
radi se o klasicnim 5mm diodama, bijele boje svjetlosti, prozirna plastika
dali se za njih treba ogranicit struja ko za one jake diode(1,3, 5, 10+w)? ili se mogu spojit bez ikakvog strujnog regulatora na izvor (Npr baterija od mobitela, 3,7v)?
glavna stvar koja me muci je dali je moguce te diode spojit u seriju( znaci nekakvih 70 komada) i onda prek nekog sklopa(grec, kond) direkt spojit na 220v?
hvala unaprijed
![Wink ;)](./images/smilies/icon_wink.gif)
