Hocu da napravim sobni ventilator koji ima kontrolu univerzalnim daljincem! I sve sam resio samo mi triak pravi problem tj ne mogu da ga nateram da radi! Imam neke ideje, ali ne valja.
'Triak je povezan preko otpora 1k, a nula preko 1m
Define OSC 4 ' Set Xtal Frequency
DEFINE CONFIG INTRC_OSC_NOCLKOUT, WDT_OFF, PWRTE_ON, MCLRE_OFF, ALL_DIGITAL TRUE
CMCON = 7
TRISIO = 0
TRISIO = %00000001
NULA VAR GPIO.0
INPUT NULA
IZLAZ VAR GPIO.2
main:
if NULA = 0 then
goto okidac0
endif
goto main
okidac1:
PAUSE k
IZLAZ = 1
pauseus 8
IZLAZ = 0
while NULA=1: wend
goto main
okidac0:
PAUSE k
IZLAZ = 1
pauseuS 25
IZLAZ = 0
while NULA=0: wend
GOTO okidac1
end
