LCD Tajmer 00:00-59:59
Sve vezano za mikrokontrolere
sindja1204
Post by sindja1204 »
Jos jedan tajmer za osvetljavanje pcb
Jednostavan tajmer sa vremenom podesavanja u razmaku od 00:00-59:59min. Vreme se podesava pomocu dva tastera UP i Downe. Odbrojavanje pocinje pritiskom na taster start. Tasterom Reset vrsi se Resetovanje tajmera. U toku rada led dioda indikuje stanje potrosaca. Zavrsetak odbrojavanja praceno je zvucnim signalom buzera. Potrosac (sijalica) se aktivira trijakom Tic 206M preko optokaplera MOC 3020
Hex
:10000000A2011E2904089300061286128612831686
:10001000061286128612F030860583121308A21883
:100020002F283A308D009830C82033309200442079
:1000300013308D008830C82044206430C72044200D
:100040006430C72022309200442028302E200C300B
:100050002E2006302E20A21413082F2822149200DE
:10006000221C3D288612033C031C422842200730F4
:100070008D00D030C820031408002214FE3C031960
:1000800019298616920E221C22100616F0308605BB
:1000900012080F3986040612920E221844283230B4
:1000A000C72003140800A31315080319A31705306C
:1000B000940027308F001030692003308F00E83023
:1000C00069208F01643069208F010A30692010088F
:1000D00070288E0011088D0010088C00F8200C0884
:1000E0008C0094030319A313150803197A2814022A
:1000F000031808000C08031DA313A31B0800303EBF
:1001000014298F00260884002409A82084138F084E
:1001100003191929F03091000E0880389000F03052
:1001200091030319910003198F03031919299828C2
:10013000AB2003010C1824088E1F24088E08031915
:100140000301900FA52880068C28A62800008F2880
:100150008417800519290D080C0403198C0A8030B6
:100160000C1A8D060C198D068C188D060D0D8C0D34
:100170008D0D19298F018E00FF308E07031C8F070C
:10018000031C192903308D00DF30C820BC288D01E5
:10019000E83E8C008D09FC30031CD1288C07031825
:1001A000CE288C0764008D0FCE280C18D7288C1C05
:1001B000DB280000DB2808008D018F018E00023053
:1001C000E12894000F080D02031DE8280E080C0218
:1001D000043003180130031902301405031DFF30E9
:1001E00019290038031DFF300405031DFF301929AC
:1001F00091019001103092000D0D900D910D0E089F
:1002000090020F08031C0F0F910203180E290E080D
:1002100090070F0803180F0F910703108C0D8D0D19
:10022000920BFC280C08192984001D088A001C0860
:10023000820083130313831264000800831686016F
:100240000730850085140515051485118613831262
:10025000AB01AA01A901A80185118316851183129A
:10026000861383168613C8308312BA20FE3003200B
:10027000013003208530032020300320203003206C
:100280002030032074300320613003206A300320C3
:100290006D3003206530032072300320FE300320D0
:1002A000C03003208330032020300320203003207F
:1002B00030300320303003203A3003203030032028
:1002C000303003203A300320303003203030032018
:1002D00003308F00E830BB20860164008518712947
:1002E000AB0A64003C302B02031C7829AB01AA0A3C
:1002F00064003C302A02031C7E29AA016400051810
:100300008229AB0364003C302B02031C8A293B305A
:10031000AB00AA0364003C302A02031C91293B3045
:10032000AA006400051DBF293230BA20FE30032028
:100330000130032073300320653003207430032024
:10034000693003206E3003206730032073300320B0
:1003500020300320023095002A08900091010230DD
:100360009C009D0153203A300320023095002B0859
:100370009000910102309C009D0153206C29323085
:10038000BA20860186178316861383128515831675
:1003900085118312A80164003D3028020318482A01
:1003A000A90164003D3029020318462A6400290887
:1003B0003C3C031DDD29A901A80A640028083C3C37
:1003C000031DE329A80128088C002A08DC209E00D0
:1003D00029088C002B08DC20A0001E0884002008BF
:1003E000F120A000A1006400200821040319082ABC
:1003F00086138316861383128511831685110630A2
:100400008312A6004030A4006E308E00323081206E
:10041000FE300320C0300320633003206F30032000
:10042000753003206E3003207430032065300320C4
:1004300072300320203003200230950028089000FD
:10044000910102309C009D0153203A30032002307C
:10045000950029089000910102309C009D015320D5
:1004600001308F00F430BB2028088C002A08DC20E3
:100470009E0029088C002B08DC20A0001E088400A8
:100480002008F120031D6C29A90FD129A80FCB2921
:060490006C296300492AFB
:02400E00F53F7C
:00000001FF
tajmer.rar
(167 KiB) Downloaded 610 times
Re: LCD Tajmer 00:00-59:59
Bravo, lijepo je vidjeti jos jedan koristan uredjaj lijepo odradjen. Svaka cast!!
Lepo odradjeno. Samo otkud sema na 2 strane?
MORGAN
Post by MORGAN »
I od mene svaka čast...super izgleda...
Malo je mašina usporila ali i dalje radi... :D
sindja1204
pedja089 wrote:otkud sema na 2 strane?
Sch na jednoj strani :)
LCD Tajmer.rar
(66.31 KiB) Downloaded 585 times
Morgan wrote:Malo je mašina usporila ali i dalje radi... :D
Masina je jos nova, pa dok se malo razgazi i zalaufa... :)
P.S Hex je za 16F628A Uradjen je i za 16F84A.
Svaka čast majstore :!: :wink:
dino_kc
Post by dino_kc »
jako dobro :)
"cuksi" -> "dino_kc"
race king
Post by race king »
Ovo je super.
Svaka cast :wink:
Odlično :!:
Upozorio bih na mali propust. Stabilizator napona bi trebao na ulazu imati blok-kondenzator, kao i PIC između svojih priključaka za napajanje - što je bliže moguće.
sindja1204
Sugestija u vezi kondenzatora je na mestu. Medjutim za ovaj sklop nisam predvideo nikakav stabilizovani izvor napajanja posto ce takvo napajanje dobiti preko DC konektora sa drugog ispravljaca.. Ovde naponski regulator LM7805 sluzi samo kao ogranicavac napona , posto na ispravljacu imam opcije 5-9-12-15v da ne bi doslo do unistenja pica i displeja u slucaju pogresnog prikljucenja. :wink:
http://img36.imageshack.us/img36/7466/picture001hs.jpg" onclick="window.open(this.href);return false;
sindja1204
@royalevo9 Imas ovde poboljsan i dopunjen kod za 16F84A i LCD2x16
2 tas 2red16F84A.rar
(1.48 KiB) Downloaded 450 times
I varijantu hex-a za 2x16 LCD sa ispisom vremena na jednoj liniji LCD-a
2 tas 1red 16F84A.rar
(1.49 KiB) Downloaded 419 times
Kod oba koda, pocetno vreme je 8min , po isteku vremena 20 x buzer sa ispisom End count
royalevo9
Post by royalevo9 »
zahvaljujem :)
sindja1204
Evo par slika novog doradjenog i konacno spakovanog tajmera. U novu verziju ugradjen je Usb konektor za ICSP programiranje mikrokontrolera i jedan spoljni ulaz u sklop. Reprogramiranjem pica preko ugradjenog usb konektora, sklop za par sekundi moze da dobije drugu namenu. Tj od Hex-a koji se ucita u pic, ovaj sklop od tajmera postaje frekvencometar, counter ,termometar, brojac od 0 -65535 , sat hh/mm/sec, i jos dosta toga... Moze da posluzi i kao probna ploca za pisanje programa vezanim za LCD displej .
http://www.elektronika.ba/forum/viewtop ... 9&start=30" onclick="window.open(this.href);return false;
Sva potrebna dokumentacija , PCB brd/sch kao i dosta primera kodova za vise varijanti tajmera, frekvencometra , brojaca.... samo na PM.
Tajmer LCD.rar
(82.4 KiB) Downloaded 508 times
DaTi
Post by DaTi »
Odlično si zamislio sklop, svaka čast! , projekat za 5 :D
78L05
Post by 78L05 »
Postalo je besmisleno komentirati Sindjine ideje i projekte, jer komentar je uvijek sličan i svi se slažemo. BRAVO MAJSTORE!
DaTi
Post by DaTi »
@Stabilizator nije besmisleno. Čovek postavio projekat da čuje naše kritike i da nekome posluži.
78L05
Post by 78L05 »
Dati, nisi me shvatio. Mislio sam reći kako su svi njegovi projekti i ideje razrađeni od početka do kraja kako treba. Većina projekata nema neku zamjerku, pa sam zato onako napisao prethodni post, to je više bilo preneseno značenje. :wink:
