PCB dizajn - rijecnik
Objasnjenje svih pojmova koristenih kod PCB proizvodjaca:
http://www.goldengategraphics.com/pcgloss.htm" onclick="window.open(this.href);return false;
Npr.:
panelize —1. To lay up more than one (usually identical)printed circuits on a pans. Individual printed circuits on a panel need a margin between them of 0.3". Some board houses permit less separation. 2. Lay up multiple printed circuits (called modules) into a sub-panel so that the sub-panel can be assembled as a unit. The modules can then be separated after assembly into discrete printed circuits.
Ili:
silkscreen —(Also called "silkscreen legend") 1. The decals and reference designators in epoxy ink on a printed wiring board, so called because of the method of application—the ink is "squeegeed" through a silk screen, the same technique used in the printing of T-shirts.
A silk mesh size commonly used is 6 mils. With this mesh size, the absolute minimum line width of any silkscreen legend artwork is 6 mils, which leaves a very faint line. 7 mils works better for a practical minimum line width.
Newer silkscreening methods allow for sikscreen draws of 5 mils, which come out very clear. A good reference designator size to use is 35 mils high with a 5 mil draw
Re: PCB dizajn - rijecnik
It could be useful for professionals only. I doubt that somebody from this site will use it ever - except you. :D
