GSM SMS Alram
marmeenar
GSM SMS Alram
Post by marmeenar »
Dear Trax, Thanks for your nice effort , because i finally found what i am looking for,i jurst need to ask you 2 questions : 1- after connecting thins great crcuit , i just connect the device to the PC and press the programming button then the sms uploader will do the rest, i mean there is so ASM files to be burn in the PIC 2- if i don't have the 24LCxxx can i use instead??
And what is the use of the hex file that is included in the compressed files?
Re: GSM SMS Alram
You have HEX file to burn into the PIC first. After that you connect ALARM to PC and work with uploader. The uploader will import text of SMS messages that you with PDUspy program. You must use EEPROM (24C512/515 - see circuit diagram for eeprom info), it cannot be replaced with MAX232!!!
