Termostat - Display prikazuje samo '*'
Milan97
Post by Milan97 »
Pozz svima...
Evo moj source code za PIC Termostat
DEFINE LCD_DREG PORTB                   ' LCD on port B
DEFINE LCD_DBIT 4                       ' Data bits B4..B7
DEFINE LCD_RSREG PORTA                  ' RS on PORTA
DEFINE LCD_RSBIT 1                      ' RS on A1
DEFINE LCD_EREG PORTA                   ' E on PORTA
DEFINE LCD_EBIT 0                       ' E on A0
DEFINE LCD_BITS 4                       ' LCD 4 bit mode
DEFINE LCD_LINES 2                      ' 2 line LCD display
'Pinout for Elektor
Heat			Var PORTA.2
Cool 			Var	PORTA.3
DQ				Var	PORTA.4		' One-wire data pin
Mode_B			Var PORTB.0
UP_B			Var PORTB.1
DOWN_B			Var PORTB.2
' I/o Settings
PORTA = 0
PORTB = 0
TRISA= %11110000                        ' RA0..3=Outputs RA4=Input
TRISB= %00000111 			' RB0..RB2=Inputs, RB3..RB7=Outputs
' Variables
Temperature 	Var	Word		' Temperature storage
TempC			Var Word
Float			Var Word
TargetTemp		Var	Word		' Desired Temperature
Hyst			Var	Word		' Hystereris
V				Var	Word		' Var. for display
B1              Var Byte            ' Byte for TargetTemp calculation
B2              Var Byte            ' Byte for TargetTemp calculation
'Count_Remain 	Var Byte		' Count remaining
'Count_Per_C 	Var	Byte		' Count per degree C
Sign			Var	Byte		' +/- sign
Mode 			Var	Byte		' 0=Temp. display, 1=Set Temp, 2=Set Hysteresis
Twist			Var Bit
' Resolution
DS18B20_9bit  	CON %00011111   	' 93.75ms, 0.5°C
DS18B20_10bit 	CON %00111111   	' 187.5ms, 0.25°C  <-- My favorite
DS18B20_11bit 	CON %01011111   	' 375ms,   0.125°C
DS18B20_12bit 	CON %01111111   	' 750ms,   0.0625°C  (default)
DATA 46, 224, 20                        ' Temp MSB, TEMP LSB, Hysteresis DIV 10
Heat=0                               ' Warm Output Low
Cool=0                               ' Cold Output Low
Mode=0                                  ' Temperature display mode
Twist = 0
PAUSE 500
LCDOUT $FE, 1, $FE, $0C                 ' Clear display, cursor off
PAUSE 250
' DS 18B20 Config
OWOUT DQ, 1, [$CC, $4E, 0, 0, DS18B20_12bit]    'Skip ROM search and write N_bits
'                                                '  resolution to scratch pad
Read 0, B1                              ' Read TargetTemp MSB
Read 1, B2                              ' Read TargetTemp LSB
TargetTemp=B1*256+B2                    ' Calculate TargetTemp value (Default=20.0 C.)
Read 2, B1                              ' Read Hysteresis
Hyst=10*B1                              ' Calculate Hysteresis value (Default= 2.0 C.)
MainLoop:
 If Mode_B=0 then                      ' Mode switch pressed
  Pause 50                              ' Debounce
  LcdOut $FE, $8F, "*"                  ' Show that command is accepted
  If Mode_B=0 then MainLoop            ' Wait until button is released
  Mode=Mode+1                           ' Increment mode
  If Mode=2 then                        ' Save Target Temperature (Mode1 -> Mode2)
   Write 0, TargetTemp / 256		' TargetTemp MSB
   Write 1, TargetTemp MOD 256          ' TargetTemp LSB
  EndIf
  If Mode > 2 Then                      ' Save Hysteresis (Mode 2 -> Mode 0)
   Mode=0               		' Only 0, 1, 2 are valid
   Write 2, Hyst / 10                   ' Divide Hyst value to fit in Byte
  EndIf
 EndIf
 If Mode =1 then                        ' Set Target Temperature
  LcdOut $FE, $80, "POST. TEMPERATURE "   ' Show function
  V=TargetTemp                          ' TargetTemp in V
  Gosub SelectSign                      ' Select +/blank/-
  Gosub DisplayTemp                     ' Display Target Temperature
  If (UP_B=0) Or (DOWN_B=0) then    ' Up or Down button pushed
   If DOWN_B=0 then                    ' Down button
    If TargetTemp > 7500 then           ' Not lower than -25 C. (10000-MinTemp * 100)
     TargetTemp=TargetTemp-25           ' Decrease temperuture with 0.25 C.
    EndIf
   EndIf
   If UP_B=0 then                    ' Up button
    If TargetTemp < 17500 then          ' Not higher than 75 C. (10000+MaxTemp * 100)
     TargetTemp=TargetTemp+25           ' Increase temperature with 0.25 C.
    EndIf
   EndIf
   GoSub SetTargetTemp                  ' Display TargetTemp and delay 0.25 Sec.
  EndIf
 EndIf
 If Mode=2 then                         ' Set Hysteresis
  LcdOut $FE, $80, "HISTEREZA      "   ' Show function
  Sign=" "                              ' No sign
  V= 10000+Hyst                         ' Set value for V
  Gosub DisplayTemp                     ' Display Hysteresis
  If (UP_B=0) Or (DOWN_B=0) then    ' Up or down button pushed
   Sign=" "                             ' No sign for Hysteresis
    If Hyst > 10 then Hyst=Hyst-10      ' Not less than 0.1 C.
   EndIf
    If Hyst < 1000 then Hyst=Hyst+10    ' Not more than 10.0 C.
   EndIf
   Pause 250                            ' Delay 0.25 Sec.
  EndIf
 EndIf
 If Mode > 0 then Mainloop              ' Setting TargetTemperature or Hysteresis
 LcdOut $FE, $80, "TEMPERATURA     "    ' Show function
 Output DQ             			' Make Pin Output
 DQ=0					' OneWire line Low
 PauseUs 480                            ' Keep down for 480 µS
 Input DQ                               ' Make Pin Input
 PauseUs 70                             ' Wait 70 µS
 If DQ=1 then                           ' No presence pulse from DS1820
  LcdOut $FE, $1, "** Nema senzora! **"    ' Show message
  Pause 500                             ' Wait 0.5 Sec.
  Goto MainLoop                         ' Check again
 EndIf
' Temp reading
 OWOut DQ, 1, [$CC, $44 ]       		' Start temperature conversion
'WaitLoop: OWIn DQ, 4, [Count_Remain]	' Check for still busy converting
' If Count_Remain = 0 Then WaitLoop      ' Busy
' OWOut DQ, 1, [$CC, $BE]		' Read the temperature
' OWIn DQ, 0, [Temperature.LowByte, Temperature.HighByte, Skip 4, Count_Remain, Count_Per_C]
' Temperature = (((Temperature >> 1) * 100) - 25) + (((Count_Per_C - Count_Remain) * 100) / Count_Per_C)
' if Temperature > 32767 then
'  Temperature= ~Temperature
waitloop:
	WHILE NOT DQ
	WEND
    OWOUT   DQ, 1, [$CC, $BE ]                       ' Skip ROM search & read scratchpad 														memory
    OWIN    DQ, 2, [Temperature.Lowbyte, Temperature.Highbyte]' Read two bytes / end comms
Convert_Temp:
	IF Temperature.15 THEN
	 	Temperature = ~Temperature + 1
		Twist = 1
	ENDIF
    TempC =  ( Temperature & $7FF ) >> 4   				' Partie Entičre '4
    Float = ((Temperature.Lowbyte & $0F ) * 25 )>> 2    ' Partie décimale 100čmes
    Temperature = TempC*100 + Float						'Préparation 1/100 degrés
 IF Twist THEN
  V= 10000 - Temperature                ' 25 C=12500  0 C=10000  -10 C=9000
  Twist = 0
 else
  V= 10000 + Temperature
 EndIf
 If V < TargetTemp - Hyst then          ' Below Target temperature - Hysteresis
  Heat=1                             ' Activate   Warm Output
  Cool=0                             ' Deactivate Cold Output
 EndIf
 If V > TargetTemp + Hyst then          ' Above Target temperature + Hysteresis
  Heat=0                             ' Deactivate Warm output
  Cool=1                             ' Activate   Cold Output
 EndIf
 GoSub SelectSign                       ' +/blank/- Sign
 GoSub DisplayTemp                      ' Temperature to LCD
Goto MainLoop				' Do it forever
' SUBROUTINES:
SelectSign:
 If v = 10000 then                      ' Temperature = 0 C.
  Sign=" " 				' No sign
 Else
  If v < 10000 then              	' <> 0
   Sign="-"				' Temperature below 0 C.
  Else
   Sign="+"				' Temperature above 0 C.
  EndIf
 EndIf
Return
DisplayTemp:
 If V >= 10000 then                     ' Above 0 C.
  Temperature=V-10000
 Else
  Temperature=10000-V                   ' Below 0 C.
 EndIf
 LcdOut $FE, $C0, Sign, DEC (Temperature / 100), ".", DEC2 Temperature, " ",223,"C "
Return
SetTargetTemp:
 V=TargetTemp
 Gosub SelectSign
 Gosub DisplayTemp
 Pause 250
Return
END
A evo sta dobijem kao rezultat:
http://www.dodaj.rs/f/2q/1l/3hEkuaS6/1.jpg
Ikakve ideje? :D
morski_pas
Re: Termostat - Display prikazuje samo '*'
Post by morski_pas »
a da staviš i proteus fajl nebi bilo na odmet ......
InTheStillOfTheNight
Ako je vec tvoj code, onda si trebao vidjeti i ovu liniju programa:
ili još bolji dio programa:
MainLoop:
  Pause 50                              ' Debounce
morski_pas
spoji tastere ovako i sve radi :D
termostat.zip
(2.38 KiB) Downloaded 270 times
termo.zip
(16.72 KiB) Downloaded 268 times
Milan97...
Ajde lepo napisi cije je to kod, ili ti leti ban...
Dosta je bilo pizdarija oko cije je sta. Ne znas ni plocicu nacrtati kako treba, a vec imas omiljenu rezoluciju na DS1820 :azdaja:
Ma kod je iz elektora 7-8/2008.
Sve sam mu poslao, i moj dizajn pločice...samo treba malo volje da se to sve napravi.
@Milan97, ako ti to treba za inkubator kako si naveo onda je ono što sam ti poslao puno puta provjereno u praksi. Ako pak želiš stvoriti svoj dizajn i software onda OK, no moraš u programu staviti i histerezu barem 0.1 stupanj jer će ti inače stradati relej... :roll:
Milan97
Post by Milan97 »
Okej, baujte me... Zdravo, dovidjenja...
Nitko nema ništa protiv da se koriste sheme i fr*e programi koju su dostupni na netu, ali većina programera mrzi kad ih netko deklarira svojima, kao da ih je sam napisao...
Očito je da nisi niti pregledao program jer bi odmah uočio dio programa koji ti konstantno ispisuje "*" na LCD-u, a odmah bi uočio i razlog tome.
Kao da je ne znam kakav problem napisati koji je izvor programa...
Mislim, nemojte me krivo shvatiti, ali mrzim kad netko tuđi source čini svojim... Meni osobno smeta... Ako je već netko pustio izvorni code u javnost, očito je htio pomoći ostalima, i bilo bi uredu da barem napišemo ime ili nadimak izvora... Kada se tih stvari budemo držali neće uopće biti problema...
78L05
Post by 78L05 »
Obrati pozornost i na to da si tipkala krivo spojio.
