Smargo reader
dombaa
Smargo reader
Post by dombaa »
Dali netko možda ima shemu kako napraviti smargo reader?hvala
morski_pas
Re: Smargo reader
Post by morski_pas »
onda ljepo napiši o čemu se radi a ne da moramo tražit po netu :azdaja: :lol:
radi se o Smartcard čitaču koji se koristi kod digitanih satelitskih prijemnika:
The Smartreader Plus is the first smartcardreader that can be connected directly into the USB port of a Linux or windows computer or Settop Box without extra cables of power supply.
prema karakteristikama teško da ćeš to sam lako napraviti :
Powerfull ARM 91 Thumb Processor
High-performance 32-bit RISC Architecture
High-density 16-bit Instruction Set
64 Kbytes, organized in 512 Pages of 128 Bytes (Single Plane)
16 Kbytes Internal High-speed SRAM, Single-cycle Access at Maximum Speed
Low-power RC Oscillator, 3 to 20 MHz On-chip Oscillator and one PLL
Supports 3.20, 3.43, 3.69, 4.00, 4.36, 4.80, 5.34, 6.00, 6.86, 8.00, 9.61, 12.0 and 16.0 MHz for smartcards
Supports standard driver for Windows and Linux applications
Developer guide available
Works on all Dreambox Models with USB connection
Works with most softcams (e.g. Newcs, CCcam ect.)
Can be cascaded with more SmartReaders using a USB Hub. In Dreambox (/dev/usb/tts/X of COM-4,5,6,X)
No power supply required
