Moderators: pedja089 , stojke369 , [eDo] , trax
ZlacX
Posts: 38 Joined: 03-01-2009, 16:17
Post
by ZlacX » 27-09-2011, 13:59
Ovako imam za predati seminarski radi koji je po mojoj procjeni 99% gotov ,ali imam gresku u programu koju nemogu nikako naći . Nadam se da mi netko na forumu moze pomoći sa tim jer vec polagano gubim razum
Evo sheme u proteusu , program je pisan u MPLAB-u
Ko ispravi gresku dam mu temp.senzor za trud
ds18s20
PROCESSOR P16F628
#include "P16F628A.INC"
ERRORLEVEL -224
__CONFIG _CP_OFF & _INTRC_OSC_NOCLKOUT &_WDT_OFF & _PWRTE_ON & _LVP_OFF& _BODEN_ON
;(ZAŠTITA KODA UGAŠENA) | | | |
;(BRZI OSCILATOR 4-20MHZ)| | | |
;(WATCH DOG TIMER OFF)---------| | |
;(POWER UP TIMER ENABLE BIT)--------------| |
;(LOW VOLTAGE PROGRAMIRANJE UGASENO PORTB4)----------|
ORG 0X0
;VARIJABLE ZA RAD PAUZE,SLANJE PODATKA NA DISPLAY
cblock 0x20
char,cmd,lc1,lc2,vr1,Temp1,Temp2,PrimPodaci;
endc
org 0
goto start
org 4
goto inthlr
; Definiranje izlaza/ulaza
start bcf STATUS,RP0 ;Banka 0
clrf PORTA
clrf PORTB
bsf STATUS,RP0 ; Banka 1
movlw B'00000000'
movwf TRISA
movlw B'00000010'
movwf TRISB
;Podešavanje USART-A (RS232)
Usart nop
movlw b'00011001'
; movlw 0x19
movwf SPBRG ;Brzina podataka
movlw b'00100100' ;Slanje podataka
movwf TXSTA
movlw b'10010000' ;Primanje podataka
movwf RCSTA
; Inicijalizacija displaya 16x2 u 4 bitnom modu ... OK
Init. bcf STATUS,RP0
call delay
;Function set
call RsIns
movlw B'00100000'
movwf PORTB
call Enable
movlw B'00100000'
movwf PORTB
call Enable
movlw B'11000000'
movwf PORTB
call Enable
;Display on/off control
call delay
call RsIns
movlw B'00000000'
movwf PORTB
call Enable
movlw B'11110000'
movwf PORTB
call Enable
;Display clear
call delay
call RsIns
movlw B'00000000'
movwf PORTB
call Enable
movlw B'00010000'
movwf PORTB
call Enable
;Entry mode set
call delay
call RsIns
movlw B'00000000'
movwf PORTB
call Enable
movlw B'01100000'
movwf PORTB
call Enable
goto natpis
; Natpis na displayu
natpis
call delay
movlw 'T' ;Podatak za slanje
call putc
movlw 'e' ;Podatak za slanje
call putc
movlw 's' ;Podatak za slanje
call putc
movlw 't' ;Podatak za slanje
call putc
movlw ' ' ;Podatak za slanje
call putc
movlw '1' ;Podatak za slanje
call putc
movlw '2' ;Podatak za slanje
call putc
movlw '3' ;Podatak za slanje
call putc
call DrugiRed ;Pomak kursora u drugi red
goto Glavni ;Idi u glavni program
;GLAVNA PETLJA
Glavni nop
call PrimanjeP ;Zovi primanje podataka
call putc ;Salji na LCD
goto Glavni ;Vrati se na glavnu petlju
;Primanje podataka sa RS232
PrimanjeP bcf STATUS,RP0
PrimanjeP1 btfss PIR1,RCIF ;Interupt je 1 ?
goto PrimanjeP1 ;Pokusaj opet
movf RCREG,W
bcf PIR1,RCIF ;Interupt reset
RETURN
;Enable puls + --> - LCD
Enable NOP
BSF PORTA,1
call delay
BCF PORTA,1
RETURN
;RS-instrukcije Porta0=0 LCD
RsIns nop
bcf PORTA,0
RETURN
;RS- podaci Porta0=1 LCD
RsPod nop
bsf PORTA,0
RETURN
;Slanje na LCD
putc bcf STATUS,RP0
call Vrijednost
call RsPod
movf Temp1,W
movwf PORTB
call Enable
movf Temp2,W
movwf PORTB
call Enable
call delay
return
;Pomak udesno--> za 1 mjesto LCD
PomakD nop
call RsIns
movlw b'00010000'
movwf PORTB
call Enable
movlw b'01000000'
movwf PORTB
call Enable
return
;Prvi red LCD displaya
PrviRed nop
call RsIns
movlw b'10000000'
movwf PORTB
call Enable
movlw b'00000000'
movwf PORTB
call Enable
return
;Drugi red LCD displaya
DrugiRed nop
call RsIns
movlw b'11000000'
movwf PORTB
call Enable
movlw b'00000000'
movwf PORTB
call Enable
return
;Spremanje akumulatora (podatak) koji se salje na portb
Vrijednost nop
movwf Temp1 ;Normalni podatak u temp1
movwf Temp2
swapf Temp2 ;Okrenuti podatak ide u temp2
return
;Pauza
delay movwf lc2
_sw2 movlw 0x1E ; 1E = 30dec
movwf lc1
_sw3 nop
decfsz lc1,f ;Prva petlja
goto _sw3
decfsz lc2,f ;Druga petlja
goto _sw2
return
inthlr retfie ;Povratak iz interupta
END
;Kraj programa
shema
seminarski.rar
(18.57 KiB) Downloaded 279 times
Posts: 7876 Joined: 20-02-2007, 14:50
Post
by pedja089 » 27-09-2011, 14:30
A sta je greska?
ZlacX
Post
by ZlacX » 27-09-2011, 14:33
Da zaboravil sam to napisati ... greska je da nece na LCD-u prikazati znak kad ga uneses u rs232 terminal( Android Bluetooth) kad god stisnem nesto na tipkovnici samo napravi jedan razmak
Sumnjam u podešenost usart-a ...
Post
by pedja089 » 27-09-2011, 16:12
Koliko ja znam terminal ima RS232 izlaz, a na picu se koristi TTL, tako da pogledaj malo po netu o naponskim nivoima i slicno... Ili jos bolje pogledaj dali taj terminal u simulaciji ima TTL ili RS232 izlaz.
ZlacX
Post
by ZlacX » 27-09-2011, 18:06
Skuzil sam par stvari problem je u PrimanjeP1 petlji ...ajde ljudi trebam pomoć s tim
lab1722tec
Posts: 123 Joined: 26-12-2010, 12:12
Post
by lab1722tec » 27-09-2011, 19:25
u "Fuse" si stavio :_INTRC_OSC što je 4MHz a ne 20 znači hardver i "safter" nisu u suglasju
a i pedja089 ti je ukazao na razlike u nivoima .....jesi pogasio komparatore.....??
ZlacX
Post
by ZlacX » 27-09-2011, 19:38
lab1722tec wrote: u "Fuse" si stavio :_INTRC_OSC što je 4MHz a ne 20 znači hardver i "safter" nisu u suglasju
Znam to za intrc_osc to sam maknul ... maknul sam jedan delay itd... kod je ovaj ...
LIST P=16F628A
; ERRORLEVEL -224
__CONFIG _CP_OFF & _HS_OSC &_WDT_OFF & _PWRTE_ON & _LVP_OFF
ORG 0X0
cblock 0x20
endc
org 0
goto start
org 4
goto inthlr
clrf PORTA
clrf PORTB
movlw B'00000000'
movwf TRISA
movlw B'00000010'
movwf TRISB
Usart nop
movlw b'00011001' ;0x19
movwf TXSTA
movwf RCSTA
call delay
;Function set
call RsIns
movlw B'00100000'
movwf PORTB
call Enable
movlw B'00100000'
movwf PORTB
call Enable
movlw B'11000000'
movwf PORTB
call Enable
call delay
call RsIns
movlw B'00000000'
movwf PORTB
call Enable
movlw B'11110000'
movwf PORTB
call Enable
;Display clear
call delay
call RsIns
movlw B'00000000'
movwf PORTB
call Enable
movlw B'00010000'
movwf PORTB
call Enable
;Entry mode set
call delay
call RsIns
movlw B'00000000'
movwf PORTB
call Enable
movlw B'01100000'
movwf PORTB
call Enable
goto natpis
natpis
call delay
call putc
call putc
call putc
call putc
call putc
call putc
call putc
call putc
;GLAVNA PETLJA
Glavni nop
movf RCREG,W
RETURN
Enable NOP
BSF PORTA,1
BCF PORTA,1
RETURN
RsIns nop
bcf PORTA,0
RETURN
RsPod nop
bsf PORTA,0
RETURN
;Slanje na LCD
putc bcf STATUS,RP0
call Vrijednost
call RsPod
movf Temp1,W
movwf PORTB
call Enable
movf Temp2,W
movwf PORTB
call Enable
call delay
return
PomakD nop
call RsIns
movlw b'00010000'
movwf PORTB
call Enable
movlw b'01000000'
movwf PORTB
call Enable
return
PrviRed nop
call RsIns
movlw b'10000000'
movwf PORTB
call Enable
movlw b'00000000'
movwf PORTB
call Enable
return
DrugiRed nop
call RsIns
movlw b'11000000'
movwf PORTB
call Enable
movlw b'00000000'
movwf PORTB
call Enable
return
Vrijednost nop
movwf Temp2
return
;Pauza
delay movwf lc2
movwf lc1
_sw3 nop
goto _sw3
goto _sw2
return
END
;Kraj programa
ZlacX
Post
by ZlacX » 27-09-2011, 20:03
Komparatore sam vec probal prije ... nema nikakve razlike
ZlacX
Post
by ZlacX » 28-09-2011, 16:13
Problem je rijesen ..ako netko treba program u assembleru neka javi
Posts: 3509 Joined: 08-01-2005, 18:04
Post
by trax » 29-09-2011, 14:40
Nije da nam je potreban program kao program, ali bilo bi dobro da napises u cemu je bio problem da znaju oni koji budu imali slican
