Evo zelim da pravim ovo kolo http://circuitdiagram.net/fm-voice-transmitter.html" onclick="window.open(this.href);return false; i sada sledeci tekst je napisan za kalem:
L1 was produced by stripping 22 gauge hookup wire of it’s insulation, then wrapping it in the grooves of the screw threads of a 1/4 diameter bolt, and then back-screwing the bolt out of the resulting coil. 8 turns were produced around the bolt. By wrapping the turns within the threads, a uniform seperation was created between the coil windings.
i ja sam ovo preveo i otprilike sam shvatio o cemu se radi, ali ne razumem kakvu zicu treba da koristim. Moze pomoc? Hvala.
Pomoc oko kalema
Pomoc oko kalema
Kad pijemo, mi se i napijemo.
- Napredujem
Re: Pomoc oko kalema
0,75mm, točnije 0,76mm....
Ok, hvala!
