TwoWay Thing - Dvosmjerni GSM Kontroler
Ivan_Kalafatić
Post by Ivan_Kalafatić »
Ma to mi je prezime (Kalafatić), al kad sam se registrirao, umjesto c stavio ć i sad je strgano :). Nisam stigao danas redizajnirati pločicu po svom.. ali bit će :)) trebam se raspitati za nokiu 6210.. valjda ću naći negdje :). Pozz ;)
Kab00m
Ivan_Kalafatić
Reply samom sebi.. Uploadao sam .brd i .sch iz eagle 5.0 s mojom verzijom pločice.. Dodani konektori (u obliku jumpera) za sve senzore i sve releje, dodan konektor za napajanje za ledicu i releje, dodana ledica kod 16f84, u paralelu s konektorima za releje, dodane zaštitne diode, ubacio nešto teksta :).. Ako sam nešt zaboravio ovdje napisati, sorry :).. ako ima kakvih nejasnoća, javite..
http://www.elektronika.ba/forum/uploadz ... afatic.rar
EDIT:
zaboravio sam napisati.. meni je ovog eagla već pun kufer pa ak ima koja dobra duša da to još jednom provjeri.. meni je prevruće :))
Kab00m
kasamiko
Post by kasamiko »
is this a new version or just another pcb layout?
sorry but i can't understand the whole thread.. :cry:
rhonnz
Ivan_Kalafatić
Greets kasamiko,
This is new pcb layout made by me. I have added connectors (like jumpers on motherboard and so on) for all sensors and relays, for connection to cellphone, for power for relays and LED; on Trax's schematic there is no LED connected to pin 18 of 16f84 but on pcb is; i have added that LED. I have also added some text and protecting diodes for relays. If you are willing to check if i have accidentaly made some mistakes, please let me know.
This is made in eagle 5.0
Kab00m
Have you made "the thing" already? Does it work, or it is just on the paper ???
Ivan_Kalafatić
@Smješko
Ne znam za koga je.. pretpostavljam meni.. Nisam još napravio s svojom pločicom, 2x sam provjerio novu i čini mi se ok, čekam da uhvatim vremena i napravim svoju verziju, ali znam da provjereno projekt radi s original traxovom pločicom..
Kab00m
kasamiko
Post by kasamiko »
@Ivan_Kalafati
I'll try to check it during my fr*e time..anyway you can make it a little more compact?
Regards..
rhonnz
Ivan_Kalafatić
@kasamiko
Sure thing.. but i don't now how :) :).. If i have measured okay, dimensions of board are 9.5x8 cm.. I could compact it removing text and rotating diodes and connectors.. i will give a try later..
greets
EDIT:
here is smaller pcb.. 8x8cm..
http://www.elektronika.ba/forum/uploadz ... er-pcb.rar
Kab00m
kasamiko
Post by kasamiko »
You can mount some components radially (standing) rather than axially (lying) like resistors and diodes... :D
I wonder why i can't delete some of the parts on your layout?
rhonnz
kasamiko
Re: TwoWay Thing - Dvosmjerni GSM Kontroler
Post by kasamiko »
Hello...any development?
regards...
rhonnz
kasamiko
Post by kasamiko »
It's been a while about this SMS controller. I'm using this flawlessly but now that Nokia 6210 is hard to find, I'm planning to use a SIM900D GSM Module.
Any idea if this will work?
Regards,
rhonnz
You can try, maybe it will work without any firmware modifications!
ddamir
Post by ddamir »
Molim Vas za komentar, za uredjaj na http://www.dolha.hr
Koji je slican opisanom na ovoj temi TwoWay i koliko je zapravo sve to potrebno za neke aplikacije. Ima brdo toga i izgleda profi.
Hvala
jevti
Post by jevti »
:ohno:
Hi Trax!
I was bored and I had an idea! why only 4 relay switch?... if you can turn even 15!
I've added a 4to16 Decoder and voila 15 outputs!!!! :D
The only tricky Thing is, that you can not turn all Relais permanently on, it must be a "P.xxxx !" command for using all 15 Outputs.
Maybe its possible to modify code so that Strobe on HCT4514 can be switched?! maybe disable one of the sensor Inputs and turn into control Output?!
greets jevti
Hello,
Yes, it could be done :-)
I didn't think anyone was using this project anymore :-)
jevti
Post by jevti »
Such a pity, that this cool Thing isn`t used anymore!
Pretty nice Projekt, and so usefull!!!
Ok, could be done? Great, how could it be done? By me :?:
I dont have the source of Pic to Change anything :(
Would you do it for me?? :roll:
greets
Yes, I could use one of AUX pins to latch the HCT4514.
Which HEX/phone are you using (6210 or 6310i)?
