Aha, nisam skužio.
A vjerojatno nije PID kontrola ali kako sam naveo u prijašnjim postovima kako diže temperaturu možda za stupanj/dva nekad zna odstupati i to samo u početnom dijelu do 100 stupnjeva jer je grijač dosta "trom" i još isijava toplinu iako je isključen.
original code
4-26-05
Copyright Spark Fun Electronics© 2005
Nathan Seidle
spark@sparkfun.com
this version of code:
Copyright Kit Ryan ©2008
Kit Ryan
jc.ryan@verizon.net
//This program has been essentially completely rewritten and greatly expanded from the original Spark Fun model software.
//#pragma CLOCK_FREQ 8000000 - this statement replaced with osccon statement at beginning of Main() Put back if using boot loader.
//#define Baud_9600
#include <boostc.h> // misc functions, such as MAKESHORT, etc. Included via <system.h>
#include <PIC16F88.h> // SourceBoost device hardware map
//####need following statement if boot loader is not used. Otherwise, boot loader sets config bits********
#pragma DATA _CONFIG1, _CP_OFF & _INTRC_IO & _CCP1_RB0 & _DEBUG_OFF & _WRT_PROTECT_OFF & _CPD_OFF & _WDT_OFF & _PWRTE_ON & _LVP_OFF & _BODEN_OFF
#pragma DATA _EEPROM, 0x00,0x3c,0x00,0x32,0x00,0x5a,0x00,0x96,0x00,0x5a,0x00,0xb4,0x00,0x28,0x00,0xd7,0x00,0x3c,0x00,0x96,
0x00,0x1e,0x00,0x32,0x00,0x0a,0x00,0x28,0x00,0x0a,0x00,0x1e,0x00,0x0a,0x00,0x1e,0x00,0x0a,0x00,0x1e,
0x14,0x01,0x01,0x04,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00;
// These locations are for Programmed time/temp values. 0-9 (10 total) steps x 2 integers each (2 bytes/int) for time
// and temp = 40 bytes per program x 2 = 80 bytes (locations 0 - 79). They are initialized as
// 60, 50, 90, 150, 90, 180, 40, 215, 60, 150, 30, 50, 10, 40, 10, 30, 10, 30,10, 30
// Following that, there are stored 'settings' variables which can be changed using Setup or Calibrate functions:
// 80 = (1 byte) tc (time constant of the oven heating cycle in seconds. Default = 20s)
// 81 = (1 byte) temp_units on display (F or C - default: C)
// 82 = (1 byte) relay_LED (on or off with relay activation. Default = ON)
// 83 = (1 byte) t_inc (adjusts the step rate for speed_button from 1 to 10 second/degree steps. Default = 5)
// 84 = (1 byte) clock_cal (adjust the master INTRC clock around 8MHz +/- 2% (the room temp accuracy range) Default = 5)
#define STATUS_LED portb.3
#define BUTTON_UP portb.0
#define BUTTON_DOWN portb.1
#define BUTTON_SELECT portb.7
#define RELAY portb.4
#define go adcon0.2 //set A/D conversion start bit.
#define OFF 0
#define ON 1
#define TRUE 1
#define FALSE 0
#define D7 porta.3 //Data pin 7 on LCD (write)/ also LCD busy indicator (read).
#define D6 porta.2 //Data pin 6 on LCD
#define D5 porta.1 //Data pin 5 on LCD
#define D4 porta.0 //Data pin 4 on LCD
#define LCD_E porta.7 //operation enable (read/write) signal (strobe)
#define LCD_R_W porta.6 //read / write select
#define LCD_RS portb.6 //register select
#define CLR_DISP 0b00000001 //Clear display
#define CUR_HOME 0b00000010 //Move cursor home and clear screen memory
#define DISP_ON 0b00001100 //Turn visible LCD on. Also will turn off cursor and blinking.
#define SET_CURSOR 0b10000000 //SET_CURSOR + X : Sets cursor position to X
#define CUR_BLNK_ON 0b00001111 //turn on cursor and blinking
#define BR_CONST 51
//Global Variables
//unsigned char a; //misc variables
unsigned char m_seconds, eeaddress, err_num=0; //
unsigned int total_seconds, display_seconds, step_seconds, a_temp1=0, a_temp2=0; //total = elapsed time; step = for each step.
signed int tot_err=0, proj_actual=0, proj_temp=0; //these could be over +/- 128.
signed int proj_err; //projected temp error at tc/2 seconds in the future (which is based on slope)
unsigned int step_time, step_temp, prev_step_temp, set_temp=0;
unsigned char W_TEMP; //need to keep these global so they don't get lost during interrupts
unsigned long actual_temp; //actual temperature in either C or F units
unsigned char STATUS_TEMP, step_number;
unsigned char PCLATH_TEMP, temp; //'temp' is a generic variable used locally but declared just once
unsigned char timer_on = FALSE, temp_on = FALSE, relay_on = FALSE; //Timer and temp updates are off to start
unsigned char eeaddoffset; //Address offset is set to either 0 (for program 1) or 40 (decimal) for program 2. This value
//is the offset for the stored program data in EEPROM and makes addressing faster.
unsigned char cur_pos; //cursor position across top row of display. Selected position to change
unsigned char digit_100, digit_10, digit_1; //first, second and third digits in either time or temp display
unsigned char choice, e_data, e_address, button_push, button_release, long_push;
unsigned int two_second_timer=0;
unsigned char update_flag=FALSE, menu_index=0, state, prev_state, step, mode, prev_mode, calmode, set_mode, timer_int = FALSE;
unsigned char temp_units, time_units, relay_LED, t_inc, clock_cal, tc; //these are Setup-related variables stored in EEPROM.
//tc is the time constant for the oven (in secs). How long it takes the coils to get hot.
//End Global Variables
//Interrupt Vectors
//Interrupt register save handler
//Function definitions
void delay_ms(unsigned int x);
void init_lcd(void);
void LCD_wait(void);
void boot_up(void);
void send_cmd(unsigned char d, unsigned char cmd); //sends a byte of either command or data to the LCD
void printf_lcd(const char *nate); //print a string to the display
unsigned char onboard_eeread(unsigned char e_address); //read byte from eeprom
void onboard_eewrite(unsigned char e_data, unsigned char e_address); //write byte to eeprom
unsigned char mod_digit (unsigned char value, unsigned char direction);
unsigned int get_temp (void); //read thermocouple
void put_edata (unsigned char e_address, unsigned int value); //write integer to eeprom
unsigned int get_edata (unsigned char e_address); //read integer from eeprom
void update_display (unsigned int value, unsigned char location); //converts and displays a 3-digit number for temp or time display on top row of LCD
unsigned int speed_button (unsigned int value, unsigned char direction, unsigned char disp_pos); //increments/decrements a 3-digit number quickly
unsigned int get_temp(void);
unsigned char bin2hex(char x);
//void send_char (unsigned char n); //sends two nybbles of data to the lcd.
void init_state (unsigned char timer, unsigned char temp); //initializes each state with common code
void serial_putchar(unsigned char s_out); //puts character to the serial port
void convert_int (unsigned int value); //convert integer into 3 one-digit values for display or transmission
void serial_putnumber (unsigned int value); //sends a 3 digit ASCII number to the serial port
unsigned int proj_value (signed int x2, signed int x3, signed int y1, signed int y2); //projects a straight line value
void send_tunits (void); //send the C or F character to the screen for temperature units
//______________________________________________
void int_save_registers(void)
asm //had to use assembly code here because could not get access to the W register in C
MOVWF _W_TEMP; //Copy W to TEMP register (note - '_' means declared in C code section)
MOVF _status,0; //Swap status to be saved into W
CLRF _status; //bank 0, regardless of current bank, clears IPR, RP1, RP0
MOVWF _STATUS_TEMP; //Save STATUS to bank zero STATUS_TEMP register
MOVF _pclath,0; //Copy PCLATH to W
MOVWF _PCLATH_TEMP; //Save PCLATH to PCLATH_TEMP
CLRF _pclath; //Page zero, regardless of current page
//Interrupt register restore handler
void int_restore_registers(void)
asm
MOVF _PCLATH_TEMP,0; //bring old PCLATH into W
MOVWF _pclath; //Restore PCLATH register
MOVF _STATUS_TEMP,0; //Bring old STATUS_TEMP into W (sets bank to original state)
MOVWF _status; //Restore STATUS register
MOVF _W_TEMP,0; //Bring old W_TEMP into W = restore W
void interrupt(void)
int_save_registers();
// char sv_FSR = fsr; // save FSR if required
if(pir1.0) //Timer1 Overflow Interrupt
//Setup Timer1 to fire every 100ms
//1 TMR1 click is 4us (with prescaler of 8). 100ms / .004ms = 25000 clicks
//but you lose something during the reset process, so reduce clicks by 0.4%(100 clicks)
//65535 - 25000 = 40535 = 0x9E57
//65535 - 24900 = 40635 = 0x9EBB
//####modify to take the clock_cal adjustment into account
t1con.0 = OFF; //stop timer1 for a moment
tmr1h = 0x9E; //set high byte
tmr1l = 0x57 + (clock_cal * 20); //set low byte. Clock_cal is limited to a range of 1-10 in Setup.
m_seconds++;
if(m_seconds == 10) //10 x 100ms = 1 second!
m_seconds = 0;
total_seconds++;
timer_int = TRUE; //set 1 second interrupt flag
if (total_seconds >= 999) //restart timer
total_seconds = 0;
pir1.0 = 0; //Clear INT Flag
t1con.0 = ON; //restart timer1 operation
// fsr = sv_FSR; // restore FSR if saved
int_restore_registers();
void main ()
//Mode options:
//***the following lines are for info only. There are too many characters to store these strings in data memory so they are implemented
//as literal string constants in program memory in the body of the code below****
/* //these are display screens for the lower lcd line
Illegal state //state (20) - used for resetting the prev_state value to force 1st time through restarts
"MM x x Nx/Sel", //state (0)
"MA R/R R-On /Ex", //state (1)
"MA S/R R-Off /Ex", //state (1)
"SA U/U D/D /Ex", //state (2)
"P1 R/R Jmp Ed/Ex", //state (3)
"P1 S/R Jmp Ed/Ex", //state (3)
"E1 U/U D/D Nx/Ex", //state (13)
"P2 R/R Jmp Ed/Ex", //state (4)
"P2 S/R Jmp Ed/Ex", //state (4)
"E2 U/U D/D Nx/Ex", //state (14)
"SU Up Dn Nx/Ex" }; //state (5)
//****Need the following osccon statement if boot loader is not used****
//set INTRC oscillator for 8 MHz
osccon = 0b01110000; //Setup internal oscillator for 8MHz
boot_up();
//Setup Timer1 to fire every 100ms for interrupts
//65535 - 25000 = 40535 = 0x9E57. First time only. Make shorter after that.
t1con.4 = 1; //set prescaler to divide by 8
t1con.5 = 1;
intcon.7=1; //enable global interrupts
intcon.6=1; //enable peripheral interrupts
pie1 = 0b00000001; //enable timer1 interrupt only
t1con.1 = 0; //use internal oscillator/4 clock
tmr1l = 0x57; //set low byte but save code space - will be tweaked during the interrupt routine with clock_cal.
send_cmd(CLR_DISP, TRUE);
trisb = 0b10000011; //set portb pins for inputting button pushes
t1con.0 = ON; //start timer1 operation. Uses interrupt handler after this.
state = 0;
prev_state = 20; //default starting condition is the main menu state. Set prev_state to a non-existent number to force initialization
// cur_pos = 0; //
prev_mode = 1; //initialize menu location to 1st selection - "Manual"
button_release = FALSE;
choice = 'n'; //select a non-existent button choice to start off.
while(1) //MAIN LOOP: loop while waiting for timer interrupts or button pushes
//Scan for button pushes. Short pushes are less than 2 seconds. Long pushes are over 2 seconds and can have a different effect.
button_push = FALSE; //clear this indicator or you may get extra, false button push actions
long_push = FALSE;
update_flag = FALSE; //start each loop with this setting
two_second_timer = total_seconds;
if (BUTTON_SELECT == 1 && BUTTON_UP == 1 && BUTTON_DOWN ==1)
{ //This test (all three buttons are released simultaneously) will reset all the button indicators.
button_release = TRUE; //don't record a new button push until the previous one has been released.
//do not automatically reset this variable each loop or you may miss button pushes due to the short loop time.
//that is a button could only be pushed between this statement and one of the following if tests!
choice = 'n'; //reset choice to none to avoid some weird problems
delay_ms(50); //delay slightly to avoid button bounce
if (BUTTON_UP == 0 && button_release == TRUE) //if Up button pushed and no other button is already pushed.
//This test avoids the problem of conflicts if multiple buttons are pushed at once. Only the first one
//pushed will be acted upon and the other pushes ignored until all the buttons have been released.
choice = 'u';
while (BUTTON_UP ==0 && (two_second_timer + 2 > total_seconds)); //wait for button release or 2s
button_push = TRUE; //in either case, set button push indicator
if(BUTTON_DOWN == 0 && button_release == TRUE) //if Down button pushed and no other button is already pushed.
choice = 'd';
while (BUTTON_DOWN ==0 && (two_second_timer + 2 > total_seconds)); //wait for button release or 2s
if(BUTTON_SELECT == 0 && button_release == TRUE) //if Select button pushed and no other button is already pushed.
choice = 's';
while (BUTTON_SELECT ==0 && (two_second_timer + 2 > total_seconds)); //wait for button release or 2s
//for any case where button was pushed, check 2s timer
if(two_second_timer + 2 <= total_seconds) //was it a long push?
long_push = TRUE; //set indicator for long button pushes
//execute the buttons and lcd updates associated with the particular state the program is in
//if no button push, then just do lcd updates per state and/or 1 second timer
//if button push, take action and/or change state immediately - don't wait for 1 second timer
if (timer_int == TRUE) //update lcd only once per second - makes for smoother temp readings.
timer_int = FALSE; //reset 1 second timer
//send time and temp to serial port every second
serial_putnumber(total_seconds); //
serial_putnumber(set_temp); //send desired temp
serial_putnumber(get_temp()); //send actual temp
// a_temp3 = a_temp2;
a_temp2 = a_temp1; //save last temp difference reading. Need for temp projection algorithm.
a_temp1 = get_temp(); //note that get_temp read at other places in the program may not be exactly 1 second later.
if (relay_on)
serial_putchar ('1'); //if relay is on, send a 1
else
serial_putchar ('0'); //else relay is off, send a 0
serial_putchar (13); //CR, LF after each time/temp pair
serial_putchar (10);
if (temp_on == TRUE)
update_display (get_temp(), 12); //Display current temp reading
if (timer_on == TRUE)
{ update_display (total_seconds,2); //Update timer display if on
step_seconds++; //also increment the time within each step in program mode
else if (timer_on == FALSE) //timer is OFF to get to here
total_seconds = display_seconds; //keep timer in hold mode
if (relay_on == TRUE) //turn on relay. Do this here so relay only changes 1/sec max.
portb.4 = 1;
if (relay_LED == TRUE)
portb.3 = 1; //turn on LED (if selected)
else //relay_on must be FALSE, so turn relay off.
portb.4 = 0;
portb.3 = 0;
switch (state)
//---------------Main Menu-----------------------
case 0:
if (prev_state != 0) //first time through, set up display
send_cmd(CLR_DISP, TRUE); //Clear screen and put cursor to 1st position on top line
printf_lcd ("Mode:"); //Display top LCD line of display
send_cmd(SET_CURSOR + 64, TRUE); //setup lower line of display
printf_lcd ("MM x x Nx/Sel"); //button functions (x means no function)
prev_state = 0;
mode = prev_mode-1; //this will put the correct top line screen on even coming back from other mode state.
button_push = TRUE; //keep track of previous mode number in Main Menu
choice = 's';
long_push = FALSE;
init_state (FALSE, FALSE);
if (button_push == TRUE && choice == 's')
//if Select button has been pushed.
//ignore 'u' or 'd' button pushes in this mode
if (long_push == TRUE) //for a long push, this is a selection of that mode as the new state
state = mode;
else //else, must be a short push, just go to the next menu selection possibility
++mode;
prev_mode = mode;
send_cmd(SET_CURSOR + 7, TRUE); //save variable space by sending only the unique parts of the string to the LCD
if (mode == 6)
mode = 1; //cycle back to the beginning if there are no more modes
switch (mode) //mode is used only in the main menu. State becomes the mode value after selection
case 1: //can't use a variable here - too big for the memory
printf_lcd (" Manual");
break;
case 2:
printf_lcd ("Semi-Auto");
break;
case 3:
printf_lcd ("Program 1");
break;
case 4:
printf_lcd ("Program 2");
break;
case 5:
printf_lcd (" Setup");
break;
//no action to be taken on Main Menu screen for update_flag = true.
break; //end Case 0
//------------------Manual Mode---------------------------------
case 1: //Manual Mode - initially in timer-stop/relay-off condition
//Manual, separate control of the timer and the relay.
if (prev_state != 1) //first time through, set up display
send_cmd(SET_CURSOR, TRUE);
printf_lcd (" 0s 000");
send_tunits();
printf_lcd ("MA R/R R-on /Ex");
prev_state = 1;
init_state (FALSE, TRUE); //initialize common code
set_temp = 0; //needed to clear the variable value if coming into Manual mode from another mode.
if (button_push == TRUE)
switch (choice)
case 'u': //if Up button short or long push
if (long_push == TRUE) //Up button, long push - reset timer to zero
prev_state = 20; //force restart of this state to reset timer. Turns off relay, too.
else //Up button, short push - start (or restart) or stop timer (toggle each time)
total_seconds = display_seconds; //start or restart timer at the current display value
send_cmd (SET_CURSOR + 67, TRUE); //change run to stop option
printf_lcd ("S");
timer_on = TRUE;
else //timer_on must = TRUE to get here
display_seconds = total_seconds; //save current timer value for future restart
send_cmd (SET_CURSOR + 67, TRUE); //change stop to run option
printf_lcd ("R");
timer_on = FALSE;
break;
case 'd': //if Down button short or long push - toggle relay
if (relay_on == FALSE) //if relay was OFF, turn it ON
relay_on = TRUE;
send_cmd (SET_CURSOR + 73, TRUE);
printf_lcd ("off"); //set 'd' button option to turn relay OFF if pushed
send_cmd (SET_CURSOR + 7, TRUE); //send warning to screen that relay is on
printf_lcd ("RELAY");
else //relay must have been ON to get to here
relay_on = FALSE; //turn relay and LED OFF here
printf_lcd ("on ");
send_cmd (SET_CURSOR + 7, TRUE); //turn off relay warning note
printf_lcd (" ");
break;
case 's': //if Select button has been pushed.
if (long_push == TRUE) //Select button, long push - Exit back to main menu
state = 0; //return to main menu
break;
}; //end Switch
}; //end If
break; //end Case 1
//-------------Semi-Automatic Mode---------------
case 2: //semi-auto mode - stop condition **add timer function if code length permits**
//works same as Manual mode except it will hold the set temperature.
if (prev_state != 2) //first time through, set up display
printf_lcd (" 000");
send_tunits();
send_tunits();
printf_lcd ("SA U/U D/D /Ex");
update_display (get_temp(), 12); //update actual temp only, not time, in the stop condition
prev_state = 2;
set_temp = 0; //initial temperature setting for semi-automatic mode. (in Celsius)
switch (choice) //delete everything except returning to main menu - too much code for memory!!!!
case 'u': case 'd': //if Up or Down button has been pushed, increment desired temp setting.
set_temp = speed_button (set_temp, choice,7);
break;
break;
} //end Switch
} //end If
//in any event, update the relay setting based on difference between set and actual temps.
update_display (set_temp, 7);
// actual_temp = get_temp();
if (get_temp() < set_temp)
relay_on = TRUE; //if oven temp is too low, turn on relay
else
relay_on = FALSE; //if oven temp is too high, turn off relay (and LED)
break; //end Case 2
//--------------Programmed Mode------------------
case 3: case 4: //Program 1 or 2 - stop condition
if (prev_state != 3 && prev_state != 4) //first time through, set up displays
printf_lcd ("0 000s 000"); //step --- elapsed time --- desired temp@end of this step --- actual temp
send_tunits();
send_tunits();
printf_lcd ("P1 R/R Jmp Ed/Ex"); //run/stop/reset --- Jump to step --- Edit mode/Exit back to Main Menu
if (state == 3)
prev_state = 3;
eeaddoffset = 0;
if (state == 4)
send_cmd(SET_CURSOR + 65, TRUE);
printf_lcd ("2"); //identify this as running Program2
prev_state = 4;
eeaddoffset = 40;
step_number = 0; //initialize the current data with step 0 data to prepare to run the program.
eeaddress = (0 + eeaddoffset); //Get step 0 data address. Program1 data starts @ 0, Program2 data starts @ 40.
step_time = get_edata (eeaddress); //get first step_time from memory
step_seconds = 0;
step_temp = get_edata (eeaddress+2); //first step_temp data is 2 bytes past time data
update_display (step_time, 2); //show step 0 values for time and temp on the display
update_display (step_temp, 7);
// //initialize time and temp values for calculation of temp ramp setting below.
prev_step_temp = 38; //starting point for warm up in Celsius
if (temp_units == FALSE)
prev_step_temp = 100; //in F
}; //end initialization if group
if (step_seconds > step_time) //if we hit the end of one of the current step periods
{ //load next step time and temp from memory
//if time step = 000, that is taken as the end of the program - reset and stop
step_number++ ; //increment step number
step_seconds = 0; //reset timer for the new step (each step is timed starting from 0)
eeaddress = (4*step_number)+ eeaddoffset;
step_time = get_edata (eeaddress); //get next step_time from memory
prev_step_temp = step_temp; //save for temp change calcs
step_temp = get_edata (eeaddress+2); //next step_temp data is 2 bytes past time data
send_cmd (SET_CURSOR, TRUE); //update step number on display
send_cmd (bin2hex (step_number), FALSE);
if (step_time == 0) //indicator that program has completed. Stop timer and relay, return to program start condition.
timer_on = FALSE;
relay_on = FALSE;
prev_state = 20; //pretend we just came in from the main menu again to reset the program.
//Algorithm is to put linear temp slope between the previous temp and the new desired temp. Compare
//desired temp with actual and turn relay on/off accordingly. Check once/second max. Will eventually
//add a ramp up/down function to reduce overshoot problems on the specific oven.
//calculate what the current set temperature should be. This is the displayed value.
//Algorithm puts a linear temp slope between the previous step temp and the current step temp.
set_temp = proj_value (step_time, step_seconds, prev_step_temp, step_temp);
//units are always C in program memory
//must update the program temp display, too.
if ((step_seconds + tc/2) <= step_time) //if tc/2 seconds ahead of current time in still in this step, use current slope
proj_temp = proj_value (step_time, step_seconds+tc/2, prev_step_temp, step_temp);
else //tc/2 seconds ahead of current time is in the next step so get that data.
proj_temp = proj_value (get_edata (eeaddress + 4), tc/2-(step_time - step_seconds), step_temp, get_edata (eeaddress + 6));
//now project actual temp ahead tc seconds and compare. Slope is done over 2 points.
//Since the slope is a derivative function, it is subject to a lot of noise. Need to include absolute difference, too.
proj_actual = get_temp() + ((tc/6)*(a_temp1-a_temp2)); //
proj_err = (get_temp()- set_temp) + (proj_actual - proj_temp); //P and I factors for PID control.If error is negative, relay should be turned on.
if (proj_err <= 0)
relay_on = TRUE; //if oven temp is too low, turn on relay (and LED if selected)
else
else
total_seconds = display_seconds; //otherwise, just keep resetting the timer to previous reading
switch (choice)
printf_lcd ("S");
timer_on = TRUE;
printf_lcd ("R");
timer_on = FALSE;
relay_on = FALSE; //always turn off oven if timer is stopped
break;
case 'd': // Down button, short push - jump to next step
//Always put the relay and timer into off condition when using jump.
//Also, reset the timer back to zero
//for long or short Jump button pushes, take the Jump action
display_seconds = 0; //
total_seconds = 0;
printf_lcd ("R");
relay_on = FALSE; //turn off relay and LED (even if LED wasn't on -avoid another if test).
timer_on = FALSE;
//if time step = 000, that is taken as the end of the program - cycle back to step 0.
if (step_time == 0) //indicator for end of program. Cycle through to step 0 and keep going.
prev_state = 20; //start this mode again. Least code method.
update_display (step_time, 2); //send step time to the display
update_display (step_temp, 7); //send step temp to the display
send_cmd (SET_CURSOR, TRUE); //update display for step, time and temp changes
send_cmd (bin2hex(step_number), FALSE);
break;
prev_state = state;
if (long_push == TRUE) //Select button, long push - Exit back to Main Menu
state = 0;
else //Select button, short push - go to program editing mode
state += 10; //shift current state to program mode. 13 for Program 1, 14 for Program 2.
break;
}; //end Switch
}; //end If
break; //end of Cases 3 and 4
//------------------Edit Program Mode -------------------------
case 13: case 14: //Program - edit mode. State 13 for Program1, state 14 for Program2.
//Remember that each program step time is for that step only, not the whole elapsed time. Had to do that to save program space.
if (prev_state != 13 && prev_state !=14) //first time through, set up displays
//always get here from Program mode with display so don't need to update the top line here again
printf_lcd ("E1 U/U D/D Nx/Ex");
if (state == 13)
// printf_lcd ("E1 U/U D/D Nx/Ex"); //increase value --- decrease value --- Next cursor position/Exit back to Program Mode
prev_state = 13;
eeaddoffset = 0; //use first 40 EEPROM memory locations for Program1 data
if (state == 14)
printf_lcd ("2 "); //identify this as program 2
prev_state = 14;
eeaddoffset = 40; //use locations 40-80 for Program2 data
init_state (FALSE, FALSE); //initialize common code
step_number = 0; //initialize the current data with step 0 data to prepare for editing.
eeaddress = (0 + eeaddoffset); //Get step 0 data address. It's 40 locations past the beginning for Program 2.
send_cmd(SET_CURSOR, TRUE); //reposition cursor to beginning of top line to print step number
send_cmd(bin2hex(step_number), FALSE);
update_display (step_time, 2); //top line numbers get updated here
update_display (step_temp, 7); //units are the same as for Program mode.
send_cmd (SET_CURSOR, TRUE); //start with cursor at the "step" position = 0 of 16 total positions in the top LCD row.
send_cmd (CUR_BLNK_ON, TRUE); //turn on cursor and blinking
cur_pos = 0;
switch (cur_pos) //it's more efficient to sort through cursor position first for this mode.
//Note: ignore cursor positions (cases) which are not either step, time or temp
case 0: //cursor is at 0 = "step number" position
step_number = mod_digit (step_number, choice); //choice is 'u' or 'd'. 's' button push is ignored by mod_digit()
eeaddress = (step_number*4 + eeaddoffset); //Get step data address. Program2 is 40 bytes past the step data for Prgm 1
step_time = get_edata (eeaddress); //get step_time from memory
if (step_time == 0)
step_number = 0; //step_num = 0 is the signal for end of program, so cycle back to beginning of the program.
step_temp = get_edata (eeaddress+2); //step_temp data is 2 bytes past time data
update_display (step_time, 2); //update the whole display to show the data for the current step number
send_cmd(SET_CURSOR, TRUE); //put cursor back to the step_number position (0)
send_cmd(bin2hex(step_number), FALSE); //note:cursor automatically shifts right one character after writing!!
send_cmd (SET_CURSOR, TRUE); //shift it back!
break; //end Case 0
case 5: // Cursor is in the time position
if (choice == 'u' || choice == 'd') //if Up or Down button has been pushed, increment desired time setting.
step_time = speed_button (step_time, choice,2);
eeaddress = (step_number*4 + eeaddoffset); //Calc step_time data address. Program 2 is 40 bytes past the same data for Prgm 1
put_edata (eeaddress, step_time); //Save new step_time value to programmed memory
break; //end Case 5
case 10: // Cursor is in the temp position
if (choice == 'u' || choice == 'd') //if Up or Down button has been pushed, increment desired temp setting.
step_temp = speed_button (step_temp, choice,7);
eeaddress = (step_number*4 + eeaddoffset + 2); //Calc step_temp data address. Temp is 2 bytes past time data location.
put_edata (eeaddress, step_temp); //Save new step_temp value to programmed memory
break; //end Case 10
}; //end Switch
if (choice == 's') //if Select button has been pushed. **don't forget to turn off cursor/blinking upon exit
if (long_push == TRUE) //Select button, long push - Exit back to Program Run Mode
prev_state = state;
state -= 10; //either 3 or 4 for Program1 or Program2.
send_cmd (DISP_ON, TRUE); //turns off cursor blinking
else //Select button, short push - mover cursor to time or temp position
if (cur_pos == 5)
cur_pos = 10; //move to "temp" position
else if (cur_pos == 0) //if cursor at "step" position,
cur_pos = 5; //move to "time" position
else
cur_pos = 0; //else reset to "step" position
send_cmd (SET_CURSOR + cur_pos, TRUE); //tell LCD where cursor is
}; //end if
break; //end of Cases 13 and 14
//--------------Setup Mode--------------------
case 5: //Setup Mode - for temp_units (C/F), time_units (SSSs/M:SS), relay_LED (O/O), data logging (O/O), start temp (0,30C)
//will save data to EEPROM starting at address 80. Data is stored as either 1 (TRUE) or 0 (FALSE) since all options have only
//2 choices.
unsigned char value;
if (prev_state != 5) //first time through, set up display
send_cmd(SET_CURSOR + 64, TRUE); //write lower line of lcd
printf_lcd ("SU Up Dn Nx/Ex");
prev_state = 5;
set_mode = 1;
button_push = TRUE; //force one time through the lcd top line screen display section below
choice = 'n'; //no real button was pushed for this first time through so take no specific action
switch (choice)
else //select button, short push - goto next variable
set_mode++;
if (set_mode == 6)
set_mode = 1; //cycle back to the beginning
break;
case 'd': case 'u': //modify variable.
eeaddress = (79 + set_mode); //calc EEPROM address of data. Use simple method to save space
value = onboard_eeread(eeaddress); //get current temp_unit value from EEPROM memory
if (set_mode == 1)
if (choice == 'u')
value += 1;
if (choice == 'd')
value -= 1;
update_display (value, 12);
if (set_mode == 2 || set_mode ==3)
if (value == TRUE)
value = FALSE;
else if (value == FALSE)
value = TRUE;
if (set_mode == 4 || set_mode == 5)
value = mod_digit (value, choice); //keep the speed_button increment range between 1 and 10
onboard_eewrite (value,eeaddress); //save current value in EEPROM
break;
}; //end switch
//update the Setup display for any changes from button pushes
value = onboard_eeread(eeaddress); //get current variable value from EEPROM memory
send_cmd(SET_CURSOR, TRUE); //go to beginning of top line of display
switch (set_mode) //update printout for the correct setup variable
case 1: //tc = time constant (warm up delay lag)
tc = value; //update current time units
printf_lcd ("Time Const = s"); //use string constants - not enough memory for variable storage
break;
case 2:
temp_units = value; //update current temp units
printf_lcd ("Temp Units = ");
send_cmd (SET_CURSOR + 15, TRUE);
send_tunits();
break;
case 3:
relay_LED = value;
printf_lcd ("Relay LED =");
send_cmd (SET_CURSOR + 12, TRUE);
if (value == TRUE)
printf_lcd (" ON ");
else printf_lcd (" OFF");
break;
case 4:
t_inc = value; //stored values range from 0 - 9. Displayed and used values are 1 - 10.
printf_lcd ("Tm/tmp Incr = ");
send_cmd (SET_CURSOR + 14, TRUE);
if (value == 9)
send_cmd ('1', FALSE);
send_cmd ('0', FALSE); //display a hex 10 value since we're only using 1 space
else
send_cmd (bin2hex (value+1), FALSE); //t_inc range from 1 to 10
break;
case 5:
clock_cal = value;
printf_lcd ("Clock cal = ");
if (value == 9)
else
break;
}; //end Switch
}; //end if
break; //end of case 5
default: //if we get an erroneous state, do nothing.
break;
//##if there's been a state change from a button push - do we need to cycle through again???
// }; end if - may not need
} //end main
//Project Value takes in point and slope information and projects or interpolates an intermediate value
//assumes that x2 is always greater than x1 and both are positive. y2 may or may not be greater than y1 but is always a positive number.
//It also assumes that x1 is always zero since each step_time restarts the clock. Also, x3 is between zero and x2 along the x axis.
signed int value;
value = y1 + (x3*(y2 - y1))/x2;
return value;
//______________________________________________________________________________
//converts an integer into 3 ASCII digits and sends them out the serial port followed by a tab.
//The tab seems to be the preferred separation character for reading a file into Excel.
convert_int (value); //put ASCII values into the digit_ series of variables
serial_putchar(bin2hex(digit_100)); //send 3 digits to the serial port
serial_putchar(bin2hex (digit_10));
serial_putchar(bin2hex (digit_1));
serial_putchar (59); //separate values with semicolon (ascii 59, or comma 44)
//Sends the temperature units character to the screen. Done to reduce code size. temp_units is TRUE for Celsius.
if (temp_units == TRUE)
send_cmd ('C',FALSE);
else
send_cmd ('F', FALSE);
//Sends a byte to the LCD in two nybbles
void send_cmd(unsigned char c, unsigned char cmd) //if cmd is TRUE, this is a command, else it is an ASCII data char to be displayed
LCD_wait();
LCD_R_W = 0; //set LCD to write
LCD_E = 0; //start with strobe at low setting
if (cmd == TRUE) //for a command, set RS=0, for data, set RS=1.
LCD_RS = 0; //set LCD to command input mode
else LCD_RS = 1; //else set to data mode
// send_char (c); //high nybble first
D7 = c.7;
D6 = c.6;
D5 = c.5;
D4 = c.4;
LCD_E = 1; delay_ms(1); LCD_E = 0; //Toggle the Enable Pin
D7 = c.3; //now low nybble
D6 = c.2;
D5 = c.1;
D4 = c.0;
LCD_E = 1;
delay_ms(1);
LCD_E = 0;
// (unsigned char value, unsigned char direction) - Increments or decrements a single digit by 1, up or down as selected
//direction is either 'u' or 'd' for up or down. Will wrap around 9 to 0 and vice-versa.
if (direction == 'u')
value++;
if (value >= 10)
value = 0;
if (direction == 'd')
if (value <= 0)
value = 9;
else
value--;
return value;
//Speed_button - increments or decrements a value either singly or repeatedly. Returns the final value.
if (direction == 'u') //if Up button has been pushed, increment desired time/temp setting.
//for short push, just go 1 increment. For long push, keep incrementing until button release.
value += (t_inc+1); //increment time or temp by 1 to 10 seconds/degrees at a time
if (value > 999) //put a 3-digit limit on temp setting to fit display width
value = t_inc+1; //wrap around zero to save time in setting high values
update_display (value, disp_pos);
while (BUTTON_UP == 0)
value += (t_inc+1); //increment repeatedly as long as button stays pushed
if (value > 999) //put a 3-digit limit on time/temp setting to fit display width
value = t_inc+1; //
delay_ms(100); //10 numbers per second increment
// if (BUTTON_UP == 1)
// long_push = FALSE; //need to detect when the button is stopped being pushed inside this loop!
if (direction == 'd') //if Down button has been pushed, decrement desired time/temp setting.
//for short push, just decrement once. For long push, keep decrementing until button release.
if (value <= 0)
value = 999; //do wrap around zero to save time in getting to high values
else value -= (t_inc+1); //decrement 1 to 10 seconds/degrees at a time
while (BUTTON_DOWN == 0)
if (value <= 0)
value = 999; //wrap around zero
else value -= (t_inc+1); //decrement repeatedly while button stays pushed
return value;
//Convert a binary integer value into 3 one-digit characters for either serial port transmit or LCD display
//Answers are returned via the global variables digit_100, etc
digit_100 = value / 100;
value %= 100; //Mod operator to cut off the 100s
digit_10 = value / 10;
value %= 10;
digit_1 = value;
//Update display - updates 3-digit time or temp given an integer value for the number and an LCD position in the top row to place the first number.
//the units measure must be added by the calling routine afterward.
//assumes 3 digit value is in the range 0 - 999, otherwise you get strange characters on the screen
convert_int (value); //convert integer into 3 separate digits
send_cmd(SET_CURSOR + location, TRUE); //note: cursor is automatically shifted to the right after each char write
if (digit_100 == 0) send_cmd (' ', FALSE); //suppress leading zeros
else send_cmd (bin2hex(digit_100), FALSE);
if (digit_100 == 0 && digit_10 == 0) send_cmd (' ', FALSE);
else send_cmd (bin2hex(digit_10), FALSE);
send_cmd (bin2hex(digit_1), FALSE);
//Returns the current temperature in Celsius or Farenheit as selected in Setup
#define AVG_AMT 16 //sets # readings to average
unsigned char x;
unsigned long temperature = 0;
unsigned int total = 0;
//Read Channel 4
adcon1 = 0b11000000; //extra divide by 2 for clock (bit 6). Right justified (bit 7)
adcon0 = 0b01100001; //Select Fosc/16 for 8mhz, and channel RA4/AN4, A/D on
for(x = 0 ; x < AVG_AMT ; x++)
delay_ms(1);
go = 1; //Convert RA4 to digital
while(go == 1); //wait for A/D conversion to complete. Resets "go" to 0 when done.
MAKESHORT(temperature, adresl, adresh); //joins the two bytes into one integer result
total += temperature; //Add on to the total
temperature = total / AVG_AMT; //these convert the reading from millivolts into degrees Celsius
temperature = temperature * 5000; //example:if ADC output is 75, then * 5000 (supply mV) = 375000
temperature /= 1024; //10 bits = 1024 steps. 375000 / 1024 = 366mV
if (temp_units == FALSE) //FALSE is for Farenheit units
temperature *=9; //this preserves the accuracy for 1 degree F changes
temperature /= 50; //convert to Farenheit
temperature +=32;
else temperature /= 10; //TRUE is for Celsius.
return temperature;
//Init vars and ports
void boot_up(void)
ansel = 0b00010000; //Turn RA4/AN4 to Analog
porta = 0b00000000; //clear PORT A latch
trisa = 0b00010000; //set PORT A pin direction: 0 = Output, 1 = Input (Temp on RA4)
//initialize globabl variables
m_seconds = 0;
total_seconds =0;
step_seconds =0;
trisb = 0b10000011; //RB3(LED)is output. RB6(RS)is output. RB4 (relay) is output. Pins 0, 1, & 7 are input from buttons.
option_reg.7 = 0; //RBPU = 0 - Enable PORTB Internal weak Pull-ups (to drive LED)- needed for sensing button pushes!!!!
portb = 0b00000000; // output 0 Volts on RB3 for start of flashing the LED
init_lcd(); //set up LCD for nibble interface, 2 x 16 lines display.
send_cmd(SET_CURSOR, TRUE); //set to beginning of 1st line on LCD
printf_lcd("SparkFun & Ryan ");
send_cmd(SET_CURSOR + 64, TRUE); //64 = 40H is the beginning of the 2nd line on LCD
printf_lcd(" OvenFlow v1.0 ");
portb = 0b00001000; //turn on LED on pin RB3
delay_ms(2000); //wait to show initial display
portb = 0b00000000; //turn off LED on pin RB3
//### serial port init code here
//Initialize Serial Port
txsta = 0x24; //Enable Tx, BRGH=1
rcsta = 0x90; //Enable SPort, Enable Rx
spbrg = BR_CONST; //9600 Baud with 8MHz INTRC clock and BR_CONST = 51
//load memory resident constants
tc = onboard_eeread(80);
temp_units = onboard_eeread(81);
relay_LED = onboard_eeread(82);
t_inc = onboard_eeread(83);
clock_cal = onboard_eeread(84);
//Intializes a few things first time through each change in state. Saves a few instructions overall.
timer_on = timer; //Back to Main Menu, make sure relay and stop watch timer are off
temp_on = temp; //keep temp reading up to date
display_seconds = 0; //save or reset initial time value of 000s for stop watch function.
relay_on = FALSE; //make sure relay and LED are off from any previous mode operation
total_seconds = 0; //reset timer to 0.
step_seconds = 0;
//Initializes the 4-bit parallel interface to the HD44780
void init_lcd(void)
//Wait for LCD busy bit to clear
//LCD_wait();
LCD_RS = 0; //(0 = instruction input; 1 = data input)
LCD_R_W = 0; //(0 = Write to LCD; 1 = read from LCD)
//Tell the LCD we are using 4bit data communication
// wait at least 0.1 secs after power up to insure LCD is ready for input
//the following sequence of 4 instructions will put the LCD into 4 bit mode.
//note that only the lower 4 bits in the port are connected to the LCD.
//The first 3 instructions with delays are actually a manual reset of the entire LCD which
//duplicates the normal power-up reset function - just in case. The 4th instruction
//0x02 actually puts the LCD into 4 bit mode.
delay_ms(100); //wait at least 40 ms per data sheet
porta = 0b00000011; //0x3 at bits D4 and D5 on LCD panel
LCD_E = 1; LCD_E = 0;
delay_ms(10); //wait at least 4 ms per data sheet
delay_ms(1); //wait at least 100 us per data sheet
send_cmd (0b00110010, TRUE); //send 0x3 a third time (like a reset function) then 0x2 to put lcd in 4 bit mode
send_cmd(0b00101000, TRUE); //2-line display, 5x7 matrix
send_cmd(DISP_ON, TRUE); //turn on display but not cursor or blinking
send_cmd(CLR_DISP, TRUE); //start with a blank display in case of boot up anomalies on screen
//Checks the busy flag and waits until LCD is ready for next command
void LCD_wait(void)
bit i = 1;
trisa = 0b00011111;
LCD_R_W = 1; //Tell LCD to output status
LCD_RS = 0;
while(i == 1)
i = D7; //Read data bit 7 - Busy Flag
LCD_E = 0;
LCD_E = 1; delay_ms(1); LCD_E = 0; //Toggle E to get the second four bits of the status byte - but we don't care
trisa = 0b00010000; //reset pins to output except RA4; 0 = Output, 1 = Input (TEMP on RA4)
//Returns an integer(2-byte time or temp) from the onboard eeprom starting at e_address (hi - lo byte order)
unsigned char x,y;
unsigned int value;
x = onboard_eeread(e_address+1); //get lo byte first
y = onboard_eeread(e_address); //get hi byte
MAKESHORT (value,x,y); //converts lo/hi bytes into a 2-byte integer
return value;
//Writes an integer(2-byte time or temp) to the onboard eeprom starting at e_address (hi - lo byte order)
unsigned char e_data=0;
LOBYTE (e_data, value);
onboard_eewrite(e_data, e_address+1);
HIBYTE (e_data, value);
onboard_eewrite(e_data, e_address);
//Reads one byte from the onboard eeprom at e_address up to 256
eecon1.7 = 0; //Point to EEPROM Memory
//Do a read
eeadr = e_address; //Set the address to read
eecon1.0 = 1; //Read it
return eedata; //Read that EEPROM value
//Write e_data byte to the onboard eeprom at e_address up to 256
//Can write EEPROM in single bytes. No pre-erasure required.
bit temp_intcon = intcon.7;
eecon1.7 = 0; //Point to EEPROM data block
eecon1.4 = 0; //Preform write only
pir2.4 = 0; //Clear the write completion intr flag
eedata = e_data; //Give it the data
eecon1.2 = 1; //Enable EE Writes
intcon.7 = 0; //Disable Intrs
//Specific EEPROM write steps
eecon2 = 0x55;
eecon2 = 0xAA;
eecon1.1 = 1;
while(pir2.4 == 0); //Wait for write to complete
eecon1.2 = 0; //Disable EEPROM Writes
intcon.7 = temp_intcon; //Set GIE to its original state
//Returns ASCII Conversion of Decimal/Hex Single Char values (0 - F)
//return ASCII character equal to x in binary/decimal for printing)
if (0 <= x <= 9) return (x + '0');
if (10 <= x <= 15) return (x-10 + 'A');
return '?';
//Prints an ASCII string to the LCD including variables
void printf_lcd(const char *nate) //*nate is input string (already in ASCII) to be printed
unsigned char i, k;
for(i = 0 ; ; i++)
// k = nate[i];
if (nate[i] == '\0') //all strings end with a hidden '\0' character
return;
send_cmd(nate[i], FALSE);
//General short delay *********may be able to delete the library delay function (which has a lot of nops in it).
//Clocks out at 1006us per 1ms
unsigned char y, z;
for ( ; x > 0 ; x--)
for ( y = 0 ; y < 4 ; y++)
for ( z = 0 ; z < 69 ; z++);
//Writes Character to Serial Port.
wait: //pir1.4 is the TXIF flag to indicate that the TXREG transmit buffer register is empty.
if ( pir1.4 == 0 ) //While transmit buffer register (TXREG) in not empty wait to load next char.
goto wait;
//##must break this up into hi and low bytes for sending ##//
txreg = s_out; //transmit buffer register is now empty and can be loaded with char "s_out" for transmission.
//note that transmission occurs immediately from loading the TXREG register.
