Auto radio u kući - Pitanje
Zez
Re: Auto radio u kući - Pitanje
Post by Zez »
Datasheet TDA2050, proizvođač ST:
Music power concept
Music power is (according to the IEC clauses n.268-3 of Jan. 83) the maximum power which
the amplifier is capable of producing across the rated load resistance (regardless of non-
linearity) 1 sec after the application of a sinusoidal input signal of frequency 1 kHz.
According to this definition our method of measurement comprises the following steps:
● Set the voltage supply at the maximum operating value
● Apply a input signal in the form of a 1 kHz tone burst of 1 sec duration: the repetition
period of the signal pulses is 60 sec
● The output voltage is measured 1 sec from the start of the pulse
● Increase the input voltage until the output signal shows a THD=10%
● The music power is then Vout na kvadrat /RL, where Vout is the output voltage measured in the
condition of point 4 and RL is the rated load impedance.
The target of this method is to avoid excessive dissipation in the amplifier.
Lijenost je iz raja izašla.
LAF
Post by LAF »
@Zez, sretno novo ljeto
To je samo vrsna snaga pri THD10%, odokativno je 2 puta veca on nominalne snage, a ovo sto
"prodaju" pod muzicka snaga je dva puta vece od ovoga, znaci 4 puta vise od nominalne snage.-
LAF
Post by LAF »
Posto je, kako kazu jutro pametnije od veceri; da samo napomenem da ni jedan proizvodjac u
autoradio ili ostale kombinacije ne ugradjuje DC/DC pretvarac za podizanje napona osim u
ona cuda sto se zovu snagasi za auta. Vezani smo za napon napajanja koji u fazi rada masine
i kada se puni akumulator iznosi 14,4 v. Na izlazima pojacala ma kako izvedeno bilo se javlja
neophodan pad napona na aktivnim komponentama, tako i u mostnoj vezi izlaza, na opterecenju-
zvucniku ne moze se generisati napon visi od 10Vpp. Uzimajuci u obzir standaedne impedanse
zvucnika lako je izracunati kolika se snaga moze dobiti.-
Zez
Post by Zez »
Hvala LIma Alfa, i tebi. Ha, čuj, mogu oni prodavati što god im drago jer najveći dio korisnika ne zna ništa o tome i nasjeda (pogotovo na onakve bisere iz posta kojeg je napisao Feko - 2000W P.M.P.O), a dobro sročena reklama prodat će i fiću pod ferarija, no ovo je (bar zasada) službena definicija. Inače, deklariranje muzičke snage bilo je svojstveno njemačkim proizvođačima audio-pojačala tijekom sedamdesetih i početkom osamdesetih.
Sargox 18
Post by Sargox 18 »
Ovaj ATX bi trebao biti dobar ili je 350W malo?
Zez
Post by Zez »
Bit će dobar, ali ne za maksimalnu snagu izlaza. Odokativno,najviše 15 do 18 W po kanalu (ako rade sva četiri izlaza) ili dvostruko za dva upotrebljena izlaza, tj. pojačala.
Sargox 18
Post by Sargox 18 »
Tako malo??
Onda koliku snagu bi trebao imati ATX da ima barem 50W po kanalu?Jedan kilovat?
Sve se to da srediti ali me zanima da li ce se memorirane stanice i ostale postavke izbrisati cim iskljucim ATX?
Sargox 18
Post by Sargox 18 »
Problem rijesen..
Kupio sam radio pojacalo Kenwood KR-A4020 2x50W,koristen,nedostaje mu samo plasticni taster za On/Off zato je i cijena mala (36€)
Sargox 18
Post by Sargox 18 »
Ako kome treba gore prikazani ATX napajanje,rado cu mu ga pokloniti i poslati jer meni vise ne treba.
Zahvaljujem na trudu oko ove problematike...za mene problem za vas macji kasalj :D ...Stvarno nisam imao zivaca vise,uvijek neki vrag iskrsne..
Emigrant
Post by Emigrant »
nemoj ga poklanjati .... može ti još zatrebati .... nikad se nezna .... jer daje ti tri napona + 12V , + 5V , +3.3V ..... možda za ledice ....
Zez
Post by Zez »
A dade se to i fino preraditi. Ima toga na Netu.
