Semafor za utrke
Re: Semafor za utrke
Ja bih na tvom mestu stavio releje prema sijalicama. Možda si i ti mislio tako i gore napisao, ali ja nisam pročitao čitav topic
Evo kako sam na kraju sve osmislio:
Shema ispod:koristim releje,a probat cu namontirat i sirenu na 12V preko PortaA.1
Moram jos vidjet kako ce to sve izgledat er mi kasni sirena preko releja.
Evo kod
I Shema:
http://imageshack.us/photo/my-images/6/shema3f.jpg/
Evo kod
'* Name : PROBA3060.BAS *
'* Author : MARKO *
'* Notice : Copyright (c) 2012 *
'* : All Rights Reserved *
'* Date : 12.5.2012. *
'* Version : 1.0 *
'* Notes : *
SYMBOL PREKIDAC30=PORTB.6
SYMBOL PREKIDAC60=PORTB.7
SYMBOL CRVENA1=PORTB.5
SYMBOL CRVENA2=PORTB.4
SYMBOL CRVENA3=PORTB.3
SYMBOL CRVENA4=PORTB.2
symbol CRVENA5=PORTB.1
SYMBOL ZELENA=PORTB.0
symbol SIRENA=PORTA.1
INPUT PREKIDAC30
INPUT PREKIDAC60
OUTPUT CRVENA1
OUTPUT CRVENA2
OUTPUT CRVENA3
OUTPUT CRVENA4
OUTPUT CRVENA5
OUTPUT ZELENA
OUTPUT SIRENA
CRVENA1=0
CRVENA2=0
CRVENA3=0
CRVENA4=0
CRVENA5=0
ZELENA=0
SIRENA=0
ADCON1=15
OPTION_REG.7 = 0
pocetak:
SEC30:
if PREKIDAC30=0 THEN
PAUSE 2000
LOW SIRENA
pause 13000
LOW ZELENA
PAUSE 10000
HIGH CRVENA1
HIGH SIRENA
PAUSE 500
LOW SIRENA
PAUSE 500
HIGH CRVENA2
HIGH SIRENA
PAUSE 500
LOW SIRENA
PAUSE 500
LOW SIRENA
HIGH CRVENA3
HIGH SIRENA
PAUSE 500
LOW SIRENA
PAUSE 500
LOW SIRENA
HIGH CRVENA4
HIGH SIRENA
PAUSE 500
LOW SIRENA
PAUSE 500
LOW SIRENA
HIGH CRVENA5
HIGH SIRENA
PAUSE 500
LOW SIRENA
PAUSE 500
low CRVENA1
LOW CRVENA2
LOW CRVENA3
LOW CRVENA4
LOW CRVENA5
HIGH ZELENA
HIGH SIRENA
GOTO sec30
ELSE
LOW CRVENA1
LOW CRVENA2
LOW CRVENA3
LOW CRVENA4
LOW CRVENA5
LOW ZELENA
ENDIF
SEC60:
if PREKIDAC60=0 THEN
PAUSE 15000
LOW ZELENA
PAUSE 40000
HIGH CRVENA1
PAUSE 1000
HIGH CRVENA2
PAUSE 1000
HIGH CRVENA3
PAUSE 1000
HIGH CRVENA4
PAUSE 1000
HIGH CRVENA5
PAUSE 1000
low CRVENA1
LOW CRVENA2
LOW CRVENA3
LOW CRVENA4
LOW CRVENA5
HIGH ZELENA
GOTO SEC60
ELSE
LOW CRVENA1
LOW CRVENA2
LOW CRVENA3
LOW CRVENA4
LOW CRVENA5
LOW ZELENA
ENDIF
GOTO POCETAK
END
Pin 9 uln-a mora biti spojen za induktivna opterecenja
Mozes li mi pojasniti sta i kako to spojiti?
Sve ima u datasheetu.
E Pedja, molio bih te da mi pojasnis. Pretrazio sam datasheetove,ali nigdje tog pina9. Ima negdje da je samo spojena neka test lampa, a drugdje je spojeno napajanje.
Molio bih te pomoc. Nakon onolikog kursa molio bih nekoliko recenica od tebe i bio bih zahvalan. I ako mi ti mozes komentirati kod i shemu. Sta promijeniti a da lijepo funkcionira u praksi,bez nekih bugova.
Pin 9 (COM) od ULN2003, spajaš na +12V (napajanje špula releja), jer su u ULN-u tu spojene katode zaštitnih dioda.
http://www.datasheetcatalog.org/datashe ... 337_DS.pdf
6 stranica, donja shema....
8 na GND
9 na VCC
8 na GND
9 na VCC
super si sve sastavio, jako dobar čip uln2003 sa cijenom od 6kn i u smd tehnici i struji colectora od 500mA
jako dobar pa ga možeš iskoristiti da ti pali neki bilo koji tranzistor za kakvo pojačalo "sirenu" ili već imaš gotovo recimo od komp zvučnika i slično...ili relej..pa opet nešto..
a pic na izlazu daje oko 20mA ako se ne varam?
lijep pozdrav
lijep pozdrav
