Toki - Voki 2W
Zasto sebi ne napravite nesto savremenije. Ovaj uredjaj podrzava FULL-DUPLEX komunikaciju, znaci osobe mogu pricati i slusati u isto vrijeme. Recimo da je ovo INTERCOM.
Za jos dosta odlicnih shema posjetite: http://www.ajpotts.fsnet.co.uk/Circuits.htmlThis NBFM VHF transceiver was orginally designed for a work collegue Mr. Paul Creed, who wished to have a radio link between himself and his son whilst riding his motorcycle and son in the side car. As it is difficult to use a PTT on a motorbike a continuous transmission / reception duplex system was required. The easiset way is to use one Xtal Oscillator to feed the TX and RX but use a 450KHz I/F for RX. I used a 470KHz IFT and tuned it down to 450KHz by adjusting the slug. The chosen frequencies were 49.860MHz for one unit and 49.410MHz for the other. These units will output approximately 10mW of RF power and ranges of 300ft have been achieved using a 1/6wave rubber duck (144MHz R/D works well) for transmit and a 10cm wire antenna for recieve.
- zogldi
- Penjem se :)
Re: Toki - Voki 2W
E prijatelju!Ovih TX/RX sam napravio par komada davno(negdje krajem 80).Tačan naziv u to doba je VT-1.Ovaj uredjaj radi na 27MHz tzv. CB band,nemože sa ovakim riješenjem izbaciti više od 150 mW u output jel ti faktički modulišeš amplitudno jedan oscilator sa jednim tranzistorom ili u prevodu ni u priči nemožeš dogurati dva wata.Sa ovim što imaš na ovoj šemi to ti je oko 1km u savršenim uslovima(nema prepreka itd.).Ako ipak budeš gradio uređaj evo ti mala pomoć:kad budeš podešavao izlaz uzmi malu sijalicu 3V namotaj zavojnicu promjera 5mm žicom 0.8mm 6-7 navoja Cul,jedan kraj zavojnice spoji na masu sijalice a drugi na centralni dio.Prinesi to sve predajnoj zavojnici upali predaju i vrti jezgru kad dobiješ najjači sjaj uštimovao si predaju(pravi paralelno dva komada lakše se uštimava prijem).Pozdrav
pozdrav
nemoj bezveze gubiti vrijeme na taj toki voki.
nema od toga nista.
da me ne shvatite pogresno,nemislim da nemozes napraviti vec kad napravis vidjeces da to ustvari cak nije ni igracka.imas kod kineza takvih toki vokija koji kostaju otprilike max 10 km.
ako vec hoces da pravis tako nesto imas boljih sema samo nemoj da ocekujes tako velike domete.
za dobar domet potrebno je malo vise od par tranzistora i otpornika,dobar uredjaj,dobar antenski sistem i mnogo strpljenja da se sve to uklopi.sa razlogom se kaze :"koliko para toliko muzike".
a ovo sto su svi rekli za domet slazem se,da stavis neku antencugu i da odes negdje na cistinu cuo bi se max na 2km pod uslovom da prijemnik napravis dobro to jest da ga podesis tacno kako treba.
a inace i ja sam pao na tu foru reklame ( 30km!!!) doduse tad sam bio klinac koji je bio zaljubljen u radioamaterizam i nesjecam se tacno ali su tada ( prije nekih 10-15 godina) dvije plocice i uputstvo kostale kao otprilike sada 30-40 km i jos se dobijala poklon sema za toki voki preko mreze 220v.
pozdrav svima
ps:nevjerujte svemu sto procitate,ljudi su kurve
(naravno,cast izuzecima)
a sto se tice trafoa kao sto ljudi rekose ima ga u starijim prijemnicima i uglavnom se nalazi blizu mjesta spajanja zvucnika i koliko se sjecam obicno je crvene boje.
sretno sa radom
nema od toga nista.
pozdrav svima
sretno sa radom
@tox master da li ta sema istina radi ili je to samo zezanje.Ja sam postavio na sajtu semu ovog toki vokija uzeo sam je od drugara i plocice sam dobio ali cim sam cuo komentare u ovom foruimu odustao sam od pravljenja.Imam i tu semu preko 220v ali da li to uopste funkcionise kazu da je veoma tesko sklopiti one feritne lonce i koliki je domet toga uopste.i jos se dobijala poklon sema za toki voki preko mreze 220v.
@Fixxxer ako hoces mogu da ti dam plocice(2kom.) ali ti sigurno nece nista koristiti ipak bolje da se slusaju iskustva a ako si uporan da pravis daj mi adresu poslacu ti ja sam 100%odustao od toga pa mi i netrebaju (plocice su original)
@tox master upravu si u ovoj oblasti te podrzavam a problem je u tome sto su sve vise i vise takoreci nezna covek vise od koga da se pazips:nevjerujte svemu sto procitate,ljudi su kurve
EKIPA SA SAJTA NEMOJ NISTA POGRESNO DA SHVATI OVO SE NEODNOSI NA NIKOG SA SAJTA DA JA IMAM NESTO PROTIV NEKOG TO BI 100% SAZNAO PRVI OD MENE JER JA TAKVE NETRPIM DUZE OD 2 MINUTA.
Hvala ti stari, ali nemoj se zamarat slat pločice. Bit je u tome da mi je to maturalna radnja. Moran je pridat 09.06. inače ne izlazin na maturu, odnosno ne upisujen se na faks, odnosno mogu se smatrat mrtvin.
Pločice san napravija sa flomasteron na brzinu, nije mi ih se dalo ukrašavat, tek kad se uvjerin da radi onda cu napravit normalne pločice.
Sada šta se tiče dometa, toki-voki se ionako nece koristit u osobne svrhe, samo ce stat u školi tako da me briga da se baca i 10m, samo neka se nešto čuje iz njega
Nadalje, ne mogu sada zapocimat radit neki drugi toki-voki, neman vrimena ni živaca. Na ovoga san zalemija sve, samo mi fali taj trafo kojega neman odakle izvadit, a kada bi ga iša kupit ne znam šta bi pita, te zavojnice jer oni pacjenti iz chipoteke nemaju niti Cu lak žicu, niti ferit. To bi mozda uspija iščupat iz babine televizije ako nista drugo
Stvarno ne znam sta cu sa tin trafon. Imate vi koji pametniji prijedlog?
pozdrav
evo sad sam bas skino semu i uputstvo za ovaj toki voki i mogu vam reci da budi uspomene na prije nekih 10-15 godina.
plocice koje sam ja tad narucio izgledale su identicno kao ove i svi ostali papiri kao i ono "ibp telekom" na plocici.
sad nesto razmisljam koji su to lopovi bili.
ko zna koliko se ljudi navuklo na tu foru i narucilo plocice i mislio kako ce pricati sa nekim na 30 km a od toga nista.
kao sto rekoh u proslom postu "ljudi su...".
ali dobro,nema veze,svaka im cast na domisljatosti u svakom slucaju.
@stojke369 ,i ja sam cuo da je zenuto napraviti te lonce mada dok me je to zanimalo da pravim nisam bio ni u kakvoj mogucnosti da to pravim (ni dijelova ni para) a sad me vec proslo.
a sto se tice dometa neznam ali kako mi se cini oni tamo kazu da je oko 100km ako se dobro sjecam seme.
e sad ako su za onaj toki voki rekli 30km ,znaci da ovo mozda ima domet par kilometara mada u ovom slucaju ne igraju ulogu faktori kao kod toki vokija (prepreke ,antena...) nego koliko se sjecam broj trafo stanica kroz koje prolazi signal a koje prigusuju signal.
u svakom slucaju znam da sam vidjeo takve uredjaje fabricke u konradovom katalogu i tu imaja namjena bila za komunikaciju u nekim vecim kucama ,znaci da pricas sa nekim na 2. spratu ako si ti u prizemlju.
po meni to govori dosta o dometu,ali mozda nisam u pravu.
ali po logici da je to tako dobar vid komunikacije koristilo bi se to cesce u upotrebi iako ja nikad nisam vidjeo da to neko ima i da koristi.
eto to je moje misljenje o tome mada mozda nisam u pravu...ali sumnjam.
neznam da li si to dobio u tom kompletu onu semu predajnika za ukt podrucje 88-108mhz (isto domet od 50-100km zar je neko sumnjo da ce biti manje).
e taj sam pravio i radio je vrlo lose ,mislim nestabilno i bacao je na mnogo frekvencija istovremeno.
@ Fixxxer,nisam te bas najbolje shvatio.
sta ti sve fali jos za to?
zavojnice,trafo,preklopnik...?
imas li kvarc kristal?
ako te zeza samo preklopnik i trafo naprimer mozes spojit tu plocicu da radi ali kao samo prijemnik ili kao predajnika a da nadjes neki drugi uredjaj sa kojim ces ga probati.doduse to vise nece biti toki voki nego samo predajnik/prijemnik ali nemogu da se sjetim nicega pametnijeg sada.
u tom slucaju kontakte mozes da spojis jumperima a mikorofon bi mogao da stavis kondezatorski sa malim preinakama u semi i ne bi ti trebao trafo.e sad neznam da li bi to proslo nan faksu ali bi te sigurno pohvalili za inovaciju .
e u tom slucaju bi ti trebao neki djeciji tokac sa kojim bi to sve probao.
eto ispisa se ja pravo ovde sad ali ko zna mozda nekome bude od koristi.
kako ono kaze lane gutovic ..."neznam zasto sam vam ovo pricao...ako ne skodi moze samo da koristi"
pozdrav
pozdrav
@Fixxxer umesto prekidaca mozes uzeti neki mali relej za vise kontakta pa uklopis to kad mu dovedes napon na spulnu on uljici predaju a kad mu prekines napon uljuci prijem (neznam koliko sad kontakta ima prekidac ali moze da se resi citaj ranije postove mislim da je pisano o tome).Ali moj drugarski savet ti je da odes kod kineza i kupis deciji toki voki i preuredi ga da izgleda kao rucni rad.Kosta 350-400dinara a tebe ce skuplje da kosta da napravis ovaj.Pricam ti zato sto ces se muciti da nabavis kristale pa kad ih nabavis platices ih skuplje nego gotove kineske tokce a imas isti domet.Trafo potrazi kod tv mehanicara ima ih po trelevizorima ako se nevaram to je prilagodni trafo na izlazu (mislim da ih imas u niskim televizorima).A naplatice ti i trafo ako nadjes Sve u svemu najbolje ti je da kupis
@tox master mislim da si upravu da su dobri bili bi u upotrebi A imam i tu semu predajnika 2w 100km domet ali sam cuo da je ocajna a i ti si mi potvrdio tako da sam sad 100% siguran da je nepravim (ipak je iskustvo iskustvo.
