Koj programator da kupim ?
izidor
Post by izidor »
Odlučio sam kupiti programator i suzio sam izbor na ova dva:
http://cgi.ebay.com/Mini-USB-PIC-Progra ... 3a5393acf3
i
http://cgi.ebay.com/USB-PIC-programmer- ... 1c0fa9212f
Prvi je puno skuplji od drugog, ali mi se čini da su i jedan i drugi dobri.
Što vi mislite?
race king
Re: Koj programator...
Post by race king »
pa pogledaj koje piceve moze programirat jedan a koje drugi. koji moze vise taj kupi :D
Drago_Zg
Post by Drago_Zg »
Što ono piše, zašto je onaj drugi jeftiniji?
izidor
Post by izidor »
Na kraju sam se odlučio za jeftiniji :)
MHN
Post by MHN »
Ako vec uzimas s ebay-a pogledaj i ovo:
http://cgi.ebay.at/Clone-PICKIT2-PICKIT ... 3a5495b900
izidor
Post by izidor »
Dvije stvari vezane za link:
1.Taj programator podržava jako malo mikrokontrolera
2.Nije mi baš jasno kako ti programatori rade, nigdje ne vidim gdje bih trebao staviti PIC, nema nigdje rupica (nazovimo ih tako)u koje bi trebao staviti PIC.
tesla2
Post by tesla2 »
@ MHN --> šta bezveze zezaš njega, reko je da će uzet jeftiniji... a ti ga zezneš i stavip mu tu nešto što skoro uopće nije programator.
GLE:
PICkit™ 2 Debug Express
Features of PICkit 2 Debug Express:
PICkit 2 Development Programmer/Debugger
44-pin demo board with PIC16F887 Midrange PIC microcontroller
The PIC16F887 may be debugged directly without any additional hardware.
A series of 12 Lessons on assembly programming that cover I/O, A/D converters, timers, interrupts, and data tables (All source code files are provided)
A Debugging Tutorial on using the PICkit 2 as a debugger with the MPLAB IDE (Ch. 4 of the PICkit 2 User’s Guide)
Getting Started in C tutorial on developing and debugging in C with a fr*e CCS PCM™ Midrange C Compiler Demo* for PIC16F887(contained on the PICkit 2 CD) *2kWord Program Limit.
Getting Started in C tutorial on developing and debugging in C with a fr*e HI-TECH PICC™ LITE C Compiler with MPLAB IDE
fr*e! Microchip’s MPLAB IDE software for a complete code development environment
DV164121 (purchase on Microchip Direct)
PICkit™ 2 Starter Kit
Features of PICkit 2 Starter Kit
Low pin count demo board supporting 8/14/20-pin mid range PIC microcontrollers
20-pin PIC16F690 Midrange microcontroller
Note: Requires the AC162061 ICD Header and AC164110 adapter to debug.
Getting Started in PICBASIC PRO tutorial on developing and debugging in BASIC with a fr*e microEngineering Labs PICBASIC PRO™ Demo Compiler (contained on the PICkit 2 CD)
HI-TECH PICC™ LITE C Compiler with MPLAB IDE.
ILI KOMPLETNO OVDJE: http://www.microchip.com/stellent/idcpl ... e=en023805
sry ak nisam upravu... ali mislim da jesam :roll:
Elektronicar
Post by Elektronicar »
Moze se reci da si delimicno u pravu.
Svaki pic koji ima In-Circuit Serial Programming moze se programirati sa pickit2(3).
Sve zavisi od njegove potrebe.
tesla2
Post by tesla2 »
ali @Izidore .. ja ti ne preporućujem to.... Svakako uzmi jedan od ova dva gornja... Uzmi jeftiniji, ak hoces nešto uštediti. A ako želiš uštediti punnooo, a k tome i naućiti onda razmisli o homemade programatoru.
( ja sam sebi doma napravio programator i programira savršeno, svi mikrokontroleri (PIC) koje sam probao isprogramirati su uspješno isprogramirani. ) ... Sve je na tebi.. biraj.. odlući... moja ti je preporuka ovaj gore jeftiniji... ili da si doma sam napraviš pa budeš ponosan svaki put kad programiraš da programiraš sa programatorom koji je tvojih ruku djelo ;)
MHN
Post by MHN »
Naravno da bi mu ako je pocetnik bilo bolje da napravi sam programator, puno bi vise naucio. A naravno da s Pickit-om mozes da programiras piceve, i ne samo da programiras, on ima svoj interni eprom tako da mozes piceve programirati bez racunara. Za svako i malo ozbiljnije radove s pic, nakraju skontas da je ovo veoma korisna alatka u radu s njima. Na microcipovoj stranici zvanicna cjena je oko 35 dolara a na ebay je oko 20-tak koliko sam vidio.
izidor
Post by izidor »
Hvala na komentraima svima, ipak ću ostati pri svojoj odluci o kupnji (jeftinijeg).
izidor
Re: Koj programator da kupim ?
Post by izidor »
Danas mi je došao programator (jeftiniji) :)
dino_kc
Post by dino_kc »
i na koj naćin to radi?
"cuksi" -> "dino_kc"
TheMaster
Post by TheMaster »
Dali biste preporucili PICKIT 2 za pocetnika s mikrokontrolerima ?
