google powermeter
ShOkRe
Re: google powermeter
Post by ShOkRe »
ma da nije bas svaki edi za ovaj harakiri ali opet ponavljam http://www.pulawireless.hr/forum/viewtopic.php?t=268" onclick="window.open(this.href);return false; naš forum od pulawirelesa, di samo frend mauricio (koji je puno bolji sa linux embedanim spikama) i moja malenkost, razvaljivali jedan ap koji radi super za ovakve stvari, a ima ga kod nas za stotinjak kuna....
(uf kolko sam grešaka pri pisanju u gornjem postu napravio, sorry)
ShOkRe
Post by ShOkRe »
pazi pak ovu kombinaciju
Set the soundcard source before using by clicking on the soundcard setup menu item at the top of the app and then doubleclicking the listbox selections for the soundcard of choice. Hook the left channel of the soundcard to the voltage sensing transformer on the AC Line under measurement - It should have 1V maximum output at the highest line voltage to be measured. You might use a 6.3VAC winding with a 6:1 divider on it such as a 10K and a 2K resistor network. The current transformer should be hooked to the right channel of the soundcard and have a 30mV/A ratio. The soundcard is setup for 300VAC and 30A when a full digital signal is measured
acw
http://www.electronicsoft.net/en-us/dept_8.html" onclick="window.open(this.href);return false;
ShOkRe
Post by ShOkRe »
ma da to je link di sam ga i ja iskopao, al nikamo ne vodi....
al ionako to je više kao da se vidi kako to sve ljudi rade, niko ne kase da je to
neka dobra metoda....
i dalje je na tapeti ono sa nekakvim prigodnim mjernim transformatorom/ima
ispravljanje i aweraging sa operacionim i mjerenje sa ad-om nekog mcu-a
hajd, doći če i to na red kad se hrpa posla na stolu smanji...
pozz
Evo ga ljudi:
http://www.elektronika.ba/727/napravi-s ... et-a-watt/" onclick="window.open(this.href);return false;
ShOkRe
Post by ShOkRe »
jes kleme..!
ma evo malo sam našo slobodnog i napravio 2 pločice sa lm324 (4xop-amp) to je 8 ulaza, svaki je opamp korigirani punovalni ispravljač, probao sam za senzor uzeti nemodificirani relej (veći) gdje može proči 2 zavoja PF2.5mm^2 bez čerupanja, i na izlaze op-amp-a sam stavio kondiće koji drže average očitanje parsto milisekundi da nebi moro picem prečesto semplat... pa baš to sastavljam, tako da kad složim, javim valja li...
ShOkRe
Post by ShOkRe »
totalno sfulano, ne radi dobro, nema linearno očitanj.... ne radi do kilovata i od kilovata do 1k5 se popne na 99% očitanja i puška, moram probat neke druge šeme, ova ne radi......
ShOkRe
Post by ShOkRe »
još jedan embedani mjerač u nizu.....
http://www.flukso.net/" onclick="window.open(this.href);return false;
a nitko nije uspjeo napraviti jednostavna strujna klješta.....
kakvi smo mi elektroničari..... nemozemo izmjerit struju od lustera i klime
i poslat na rs232.... sram me bilo.... baš mi je bed....
grunf
Post by grunf »
pokusaj broj 1 :D, inace postignuta usteda na mjesecnom nivou je 24% :D, sto na godisnjem nivou izvnosi oko 100KM
protitp uređaja s ociglednim dizajnerskim greskama :D
klijent side izgled u web pregledniku
Moze li nesto vise od 2 slike?
Meni je ova ethernet pocica pokidala zivce... U cemu si pisao program?
grunf
Post by grunf »
dok se slozi dokumentacija :D i kod mene se ova eternet ploca ponasala u najmanju ruku cudno :D, na momente na razvojnom sistemu je odbijala da radi a o njenoj potrosnji ne treba ni pisati, ali na konkretnom uredjaju perfektno.
Meni nikako nije radila na ploci...
grunf
Post by grunf »
...inace sam imao problema sa bootloaderom jenostavno nije htio da ostvari konekciju?
Sta radi telefon u ovom mjeracu? Jel ovo uopste mjerac potrosnje? :)
grunf
Post by grunf »
pa naravno da nije :D, CurrentCost mjeri i sluzi za prikupljanje podataka za dijagrame, negdje smo pisali prije o njemu, a ovaj sklop samo demonstriria moguce oblike kontrole, telefon je tu samo sminka :D 8) , ma opciono pomocu prekidace se moze izabrati www ili gsm suport, jer ciljanja grupa pretplatnika su ADSL pretplatnici BH Telecoma :D za www suport, a kao ostali bi mogli korisititi pachube servisi i GSM suport :D. ono ovo je samo ideja googlepowermetra, koju sam pokusao relaizirati pomocu sasvim drugogo uređaja jer TED energy inspector ili Alert me su preskupi, a ovaj CurrentCost je ono kao jeftin, a ovo svenekekao radi :lol:...samo da mi je sad skontat kako nabavit neki low power web plug in konfjter da s ena njemu vrti web server...
grunf
Post by grunf »
low power web plug in konfjter :D joj sta napisa, low power konfjuter, nesto sam citao na u temu. napisao sam ja i u radu u literaturi http://www.elektronika.ba" onclick="window.open(this.href);return false; :D ti mene trax odma po ledjima :D
Hehe...
ShOkReEee...
Ne znam zasto ovo nebi radilo: http://www.seeedstudio.com/depot/electr ... p-471.html" onclick="window.open(this.href);return false;
ShOkRe
Post by ShOkRe »
jesu škrti s informacijama s tim kolutićem.... vjerovatno je samo zavojnica, al opet treba iskemijati neko operaciono pojačalo-ful/half ispravljač/buffer da bi ga s picevim a/d om mogo lijepo čitat.....
sad me muči kako napraviti taj dio s operacionima, al napravilo bi se i to, nego na poslu imam previše posla, pravim lewd displeje ko neki kinez, pa se ne stignem ovim bavit, kao ni s puno drugih stvari s kojima bih volio.... al ajde biće kad bude.....
škvardra, odlični ste ! vidim da još ima aktivista :-)
pozdrav!
yt1nvs
Post by yt1nvs »
@trax ovakav slican trafo kao ovaj gore radi na agregatima merenja struje i to direktno na AD MCU pin i to bez OP-a.Odnos je ovakav npr. 8.8A je 0.88VDC 25A je 2.5V itd.Zaliven je pa nisam mogao da ga pregledam.
grunf
Post by grunf »
opet ja...malo sam se zaigrao s ovim curentcost cudom :D...i ovo je nemoguce zavrsiti :D...stalno budalasti padaju napamet :D...evo sta sam dobio!
http://img689.imageshack.us/img689/1552 ... rmente.png
