radovi forumasa sa ubrzanog kursa pbp
Re: radovi forumasa sa ubrzanog kursa pbp
mislis nesto kao propeller clock?
tako nesto samo sa ovakvim displejem
mislim da bi bilo originalno, tako nesto ja bar jos nisam video
- dejanmaksa
- Napredujem
Nabasao sam na netu na jedan programcic koji simulira pic mozda bude nekome interesantan.
Evo linka na rapidshare.
http://rapidshare(dot)com/files/179174345/p ... p.rar.html" onclick="window.open(this.href);return false;
evo bilo mi je dosadno pa sam napisao program za ledice, 5 ledica daju svakakve efekte (nisam znao kak da objasnim) evo ovdje se sve vidi: http://www.youtube.com/watch?v=XPgZY31I_bo" onclick="window.open(this.href);return false;
sad cu vidit kad opet nebudem mogo spavat, da napravim da kad se stisne tipkalo, svaki put ledice svjetle drugacijim poretkom
shema: http://www.imagesforme.com/show.php/313636_shema.JPG" onclick="window.open(this.href);return false;
SIMBOLI
SYMBOL LED1 = PORTB.1
SYMBOL LED2 = PORTB.2
SYMBOL LED3 = PORTB.3
SYMBOL LED4 = PORTB.4
SYMBOL LED5 = PORTB.5
POCETAK
HIGH LED1
HIGH LED2
HIGH LED3
HIGH LED4
HIGH LED5
PAUSE 600
LOW LED3
PAUSE 400
LOW LED2
LOW LED4
PAUSE 400
LOW LED5
LOW LED1
PAUSE 100
HIGH LED3
PAUSE 400
HIGH LED2
HIGH LED4
PAUSE 400
HIGH LED5
HIGH LED1
PAUSE 400
LOW LED1
LOW LED2
LOW LED3
LOW LED4
LOW LED5
PAUSE 10
HIGH LED1
PAUSE 500
HIGH LED2
PAUSE 500
HIGH LED3
PAUSE 500
HIGH LED4
PAUSE 500
HIGH LED5
PAUSE 500
LOW LED5
PAUSE 500
LOW LED4
PAUSE 500
LOW LED3
PAUSE 500
LOW LED2
PAUSE 500
LOW LED1
PAUSE 500
HIGH LED1
HIGH LED2
PAUSE 100
HIGH LED4
HIGH LED5
PAUSE 100
LOW LED1
LOW LED2
PAUSE 100
LOW LED4
LOW LED5
PAUSE 100
HIGH LED1
HIGH LED2
PAUSE 100
HIGH LED4
HIGH LED5
PAUSE 100
LOW LED1
LOW LED2
PAUSE 100
LOW LED4
LOW LED5
PAUSE 100
HIGH LED1
HIGH LED2
PAUSE 100
HIGH LED4
HIGH LED5
PAUSE 100
LOW LED1
LOW LED2
PAUSE 100
LOW LED4
LOW LED5
PAUSE 100
HIGH LED1
HIGH LED2
PAUSE 100
HIGH LED4
HIGH LED5
PAUSE 100
LOW LED1
LOW LED2
PAUSE 100
LOW LED4
LOW LED5
PAUSE 100
HIGH LED1
HIGH LED2
PAUSE 100
HIGH LED4
HIGH LED5
PAUSE 100
LOW LED1
LOW LED2
PAUSE 100
LOW LED4
LOW LED5
PAUSE 100
HIGH LED3
PAUSE 100
LOW LED3
PAUSE 100
HIGH LED3
PAUSE 100
LOW LED3
PAUSE 100
HIGH LED3
PAUSE 100
LOW LED3
PAUSE 100
HIGH LED3
PAUSE 100
LOW LED3
PAUSE 100
HIGH LED3
PAUSE 100
LOW LED3
PAUSE 100
HIGH LED3
PAUSE 100
LOW LED3
PAUSE 100
HIGH LED1
PAUSE 100
HIGH LED2
PAUSE 100
HIGH LED3
PAUSE 100
HIGH LED4
PAUSE 100
HIGH LED5
PAUSE 100
LOW LED5
PAUSE 100
LOW LED4
PAUSE 100
LOW LED3
PAUSE 100
LOW LED2
PAUSE 100
LOW LED1
PAUSE 100
HIGH LED1
PAUSE 100
HIGH LED2
PAUSE 100
HIGH LED3
PAUSE 100
HIGH LED4
PAUSE 100
HIGH LED5
PAUSE 100
LOW LED5
PAUSE 100
LOW LED4
PAUSE 100
LOW LED3
PAUSE 100
LOW LED2
PAUSE 100
LOW LED1
PAUSE 100
HIGH LED5
PAUSE 100
HIGH LED4
PAUSE 100
HIGH LED3
PAUSE 100
HIGH LED2
PAUSE 100
HIGH LED1
PAUSE 100
LOW LED1
PAUSE 100
LOW LED2
PAUSE 100
LOW LED3
PAUSE 100
LOW LED4
PAUSE 100
LOW LED5
PAUSE 100
HIGH LED5
PAUSE 100
HIGH LED4
PAUSE 100
HIGH LED3
PAUSE 100
HIGH LED2
PAUSE 100
HIGH LED1
PAUSE 100
LOW LED1
PAUSE 100
LOW LED2
PAUSE 100
LOW LED3
PAUSE 100
LOW LED4
PAUSE 100
LOW LED5
PAUSE 100
HIGH LED5
PAUSE 100
HIGH LED4
PAUSE 100
HIGH LED3
PAUSE 100
HIGH LED2
PAUSE 100
HIGH LED1
PAUSE 100
LOW LED1
PAUSE 100
LOW LED2
PAUSE 100
LOW LED3
PAUSE 100
LOW LED4
PAUSE 100
LOW LED5
PAUSE 100
GOTO POCETAK
END
hehe vidimo da ti je bilo dosadno...
nemozes ni zamislit koliko...
I meni! Zato sam napravio sažetak...flash005 wrote:hehe vidimo da ti je bilo dosadno...
Real Radios Glow in the Dark!
super. svaka cast
Nije super! Meni je još uvijek dosadno. A smješko niš ne komentira!
Buš il' nebuš
Buš il' nebuš
Još jedan uradak:
Mala gusjenica
Mala gusjenica
I ovaj "ide na" PIC16F84. Star je skoro ko Pohorje.
odlicno, drago mi je sto ovako nesto vidim medju gotovim projektima, nadam se daw ce ih biti i od strane onih koji su ucili sa kursa
Mislim da su dobili podstrek za rad. Kada ja matori mogu, kako nebi vi mladi. Sada ćeš vidjeti poplavu sličnih projekata.
Pozdrav, Branko
Pozdrav, Branko
iskreno se nadam, mada cini mi se da se vecina ulenjila...
Možda kome pomogne naći znakove koje se može prikazivati na LCD.
Prikaz simbola "stupanj Celsiusa" na LCD displeju. ASCII koda 223 je znak za stupnjeve.
Mali programčić za prikaz koje simbole prikazuje određeni displej.
LcdOut $FE, $C0, DEC (Temperatura / 100), ".", DEC2 Temperatura, " ",223,"C "
'PIC16F628A
@ DEVICE XT_OSC,WDT_OFF,PWRT_ON,PROTECT_OFF
DEFINE OSC 4 'Oscillator speed in MHz
CMCON = 7 ' Set PORTA to digital
INCLUDE "bs2defs.bas"
DEFINE LCD_BITS 4 'izbira ali lcd dela v 4 bitnem ali 8 bitnem modu
DEFINE LCD_DREG PORTA 'izbira se port na kateri so priključeni data biti(d4-d7)
DEFINE LCD_DBIT 0 'začetni bit data porta. 0 ali 4. Če je postavljen na 0
'se d4 spaja na RA0, d5-RA1, d6-rb2, d7-rb3,a če je postavljen na 4
'd4 se spaja na rb4 itd..
DEFINE LCD_RSREG PORTA 'port na kateri je priključena linija RS
DEFINE LCD_RSBIT 4 'bit porta na katerem je priključena linija RS. V tem slučaju
'je priključena na RA4
DEFINE LCD_EREG PORTB 'port na kateri je priključena E linija displeja
DEFINE LCD_EBIT 0 'bit porta na katerem je priključena E linija.
DEFINE LCD_RWBIT 2 'RW bit
DEFINE LCD_LINES 2 'število linij displeja. 1,2,4
DEFINE LCD_DATAUS 50 'zakasnitev podatkov v ms.
INPUT PORTB.7
INPUT PORTB.6
INPUT PORTB.5
output PORTB.1
output PORTB.2
output PORTB.3
output PORTB.4
SYMBOL enter = PORTB.7 'tipka
SYMBOL plus = PORTB.6 'tipka
SYMBOL minus = PORTB.5 'tipka
broj var word
broj = 1
start:
pause 100 'inicijalizacija displeja
lcdout $FE,1 'obriši displaj
lcdout $fe,1,DEC broj," ",broj 'izpiše v prvo linijo
if plus = 0 then broj = broj + 1 'naslednji znak
if minus = 0 then broj = broj - 1 'prejšnji znak
if enter = 0 then broj = 1 'vrača na početak
pause 100
goto start
end
- dejanmaksa
- Napredujem
Evo ja sam malo preradio primer koji je postavio pedja089 u vezi kockice za covece ne ljuti se.
symbol TASTER=PORTA.3
INPUT TASTER
TRISB=0
pocetak:
if taster=0 then goto pocetak
PORTB=%00111111
PAUSE 40
IF taster=0 then
pause 10000
goto pocetak
endif
PORTB=%11011011
PAUSE 40
IF taster=0 then
pause 10000
goto pocetak
endif
PORTB=%10011011
PAUSE 40
IF taster=0 then
pause 10000
goto pocetak
endif
PORTB=%11010010
PAUSE 40
IF taster=0 then
pause 10000
goto pocetak
endif
PORTB=%10010010
PAUSE 40
IF taster=0 then
pause 10000
goto pocetak
endif
PORTB=%11000000
pause 40
IF taster=0 then
pause 10000
goto pocetak
endif
goto pocetak
End
- kockica-1.jpg (16.68 KiB) Viewed 14487 times
- dejanmaksa
- Napredujem
Evo i ja da se prikljucim sa svojim jednim projektom koji sam napravio zahvaljujuci ovom forumu.
Radi se o termostatu sa LCD 16x2. Koristio sam PROTEUS v7.1 SP2.
- termostat sve.rar
- (74.71 KiB) Downloaded 549 times
napisao sam kod z asemafor u microBasicu for PIC ali ga nemam na cemu isprobati pa ako neko ima razvojnu plocu molio bih da pokusa testirati. Hvala
program semafor
main:
trisb = 0
radi:
PORTB = %11011110 ' 1. semafor - crvena 2. semafor zelena
Delay_ms(10000) ' pauza 10s
PORTB = %11101100 ' 1. semafor - crvena i zuta 2. semafor zuta
Delay_ms(3000) ' pauza 3s
PORTB = %11110011 ' 1. semafor zelena 2. semafor crvena
PORTB = %11100101 ' 1. semafor - zuta 2. semafor crvena i zuta
goto radi
end .
a ovo je hex fajl:
:100000000428FF3FFF3FFF3F031383168601DE30C6
:10001000831286003330CC00FF30CB00FF30CA00A3
:10002000CC0B13281A28CB0B16281928CA0B162814
:1000300013281028FD30CB00FF30CA00CB0B21283D
:100040002428CA0B21281E28B530CA00CA0B26282E
:100050000000EC3086001030CC00FF30CB00FF30C9
:10006000CA00CC0B34283B28CB0B37283A28CA0BC4
:100070003728342831284C30CB00FF30CA00CB0B56
:1000800042284528CA0B42283F28CE30CA00CA0B56
:100090004728F33086003330CC00FF30CB00FF30F0
:1000A000CA00CC0B54285B28CB0B57285A28CA0B04
:1000B000572854285128FD30CB00FF30CA00CB0B05
:1000C00062286528CA0B62285F28B530CA00CA0BAF
:1000D00067280000E53086001030CC00FF30CB00F0
:1000E000FF30CA00CC0B75287C28CB0B78287B28E6
:1000F000CA0B7828752872284C30CB00FF30CA0014
:10010000CB0B83288628CA0B83288028CE30CA00D0
:10011000CA0B882807288B28FF3FFF3FFF3FFF3F80
:00000001FF
program semafor
main:
trisb = 0
radi:
goto radi
end .
a ovo je hex fajl:
:00000001FF
