PIC Simulator IDE 6.65
PIC Simulator IDE is powerful application that supplies PIC developers with user-friendly graphical development environment for Windows with integrated simulator (emulator), Basic compiler, assembler, disassembler and debugger. PIC Simulator IDE currently supports the following microcontrollers from the Microchip PICmicro 12F and 16F product lines: 12F629, 12F675, 12F683, 16F627, 16F627A, 16F628, 16F628A, 16F630, 16F648A, 16F676, 16F684, 16F685, 16F687, 16F688, 16F689, 16F690, 16F72, 16F73, 16F74, 16F76, 16F77, 16F737, 16F747, 16F767, 16F777, 16F83, 16F84, 16F84A, 16F87, 16F88, 16F818, 16F819, 16F870, 16F871, 16F872, 16F873, 16F873A, 16F874, 16F874A, 16F876, 16F876A, 16F877, 16F877A.
Features:
- Main simulation interface showing internal microcontroller architecture,
- FLASH program memory editor, EEPROM data memory editor, hardware stack viewer,
- Microcontroller pinout interface for simulation of digital I/O and analog inputs,
- Variable simulation rate, simulation statistics,
- Breakpoints manager for code debugging with breakpoints support,
- PIC assembler, interactive assembler editor for beginners, PIC disassembler,
- Powerful PIC Basic compiler with smart Basic source editor,
- PIC Basic compiler features: three basic data types (1-bit, 1-byte, 2-byte), optional 4-byte (32-bit) data type with 32-bit arithmetics, arrays, all standard PIC Basic language elements, optional support for structured language (procedures and functions), high level language support for using internal EEPROM memory, using internal A/D converter module, using interrupts, serial communication using internal hardware UART, software UART implementation, I2C communication with external I2C devices, Serial Peripheral Interface (SPI) communication, interfacing character LCDs, interfacing graphical LCDs with 128x64 dot matrix, R/C servos, stepper motor control, 1-Wire devices, DS18S20, using internal PWM modules ...
- Configuration bits editor,
- PC's serial port terminal for communication with real devices connected to serial port,
- LCD module simulation interface for character LCD modules,
- Graphical LCD module simulation interface for 128x64 graphical LCD modules,
- Stepper motor phase simulation interface for stepper motor driving visualization,
- Simulation module for external I2C EEPROMs from 24C family,
- Hardware UART simulation interface,
- Software UART simulation interface for software implemented UART routines,
- Oscilloscope (with Zoom feature) and signal generator simulation tools,
- 7-segment LED displays simulation interface,
- Support for external simulation modules,
- Extensive program options, color themes, ...
http://www.oshonsoft.com/pic.html
http://rapidshare(dot)com/files/136338761/P ... ve.net.rar
jel ima neki dodatak za pic basic?
_mirko_
Post by _mirko_ »
Zahvaljujuci _mirkovoj_ arhivi, sad ce se naglo povecati broj simulanata. :lol:
