Moderators: pedja089 , stojke369 , [eDo] , trax
mstevica
Posts: 330 Joined: 04-06-2006, 22:56
Post
by mstevica » 15-01-2007, 11:47
Interesuje me gde se moze kupiti okaj smd cip?Koristi se u lemilici.
MHN
Posts: 350 Joined: 11-03-2005, 22:02
Post
by MHN » 16-01-2007, 11:01
To je Maxim kolo, idi na
http://www.maxim-ic.com/ i naruci SAMPLE tog kola, dobices ga besplatno.
mstevica
Post
by mstevica » 16-01-2007, 15:19
Nerazumem bas najbolje sta si hteo da mi kazes.
MladaNada
Posts: 2529 Joined: 20-05-2006, 14:57
Post
by MladaNada » 16-01-2007, 19:54
Kompanija maxim pravi taj chip , odes na njihovu stranicu , registrujes se sa pravom adresom i ostalim i narucis uzorak (sample)
sabossa
Posts: 3 Joined: 14-01-2007, 01:58
Post
by sabossa » 18-01-2007, 01:23
U Sarajevu je jedna - hajmo rec- chipoteka - RS ELEKTRONIK broj telefona - 033 463 032
probaj kod njih
ciko se zove Rasim - vrlo ljubazna ekipa je - ko god da se javi
mstevica
Post
by mstevica » 18-01-2007, 14:40
Sve sam se ok uclanio i ubacio max6675 u Sample Cart ali mi izpisuje neznam zbog cega
Validation Error
You must correct the following error(s) before proceeding:
* Estimated Annual Usage is required
Dali je neko imao ovakih problema?
Ulogovaos am se ok, cak mi pise i ime u gornjem desnom uglu
Posts: 3509 Joined: 08-01-2005, 18:04
Post
by trax » 18-01-2007, 15:38
Pa nisi unio to polje cojece... unesi i probaj opet.
