Potrebno mi je jednostavno antensko fm pojacalo za autoradio.
Imam tranzistora BFR 91A i mislim da se mogu iskoristiti.
Molim semu i ,eventualno, opis izrade i iskustvo sa koristenjem.
antensko Fm pojacalo za autoradio
Gore visoko dole tvrdo
Re: antensko Fm pojacalo za autoradio
Imas seme po netu samo ukucaj BFR91A Antensko pojacalo
Ja sam pravio ovo samo ti treba BFG 65 Tranzistor http://static.elitesecurity.org/uploads ... age-20.JPG
Sa ES foruma ne mozes koristiti samo slike, posalji link do cijele teme iako si ti radio pojacalo
koje je namijenjeno TV signalu, @zarec-u treba za FM autoradio.-
greska nije moja ja znam da BFR91A sluzi za tv pojacalo. A ne za FM podrucije 88-108 mhz
BFR91
Vishay Telefunken
www.vishay.com
2 (8) Rev. 3, 20-Jan-99
Document Number 85030
Electrical DC Characteristics
Tamb = 25C, unless otherwise specified
Parameter Test Conditions Symbol Min Typ Max Unit
Collector cut-off current VCE = 20 V, VBE = 0 ICES 100 A
Collector-base cut-off current VCB = 20 V, IE = 0 ICBO 100 nA
Emitter-base cut-off current VEB = 2 V, IC = 0 IEBO 10 A
Collector-emitter breakdown voltage IC = 1 mA, IB = 0 V(BR)CEO 12 V
DC forward current transfer ratio VCE = 5 V, IC = 30 mA hFE 25 50 150
Electrical AC Characteristics
Transition frequency VCE = 5 V, IC = 30 mA, f = 500 MHz fT 5 GHz
Collector-base capacitance VCB = 10 V, f = 1 MHz Ccb 0.5 pF
Collector-emitter capacitance VCE = 10 V, f = 1 MHz Cce 0.3 pF
Emitter-base capacitance VEB = 0.5 V, f = 1 MHz Ceb 1.4 pF
Noise figure VCE = 5 V, IC = 2 mA, f = 500 MHz,
ZS = 50
F 1.9 dB
Power gain VCE = 5 V, IC = 30 mA, ZL = ZLopt,
f = 500 MHz
Gpe 18 dB
f = 800 MHz
Gpe 13 dB
Linear output voltage – two
tone intermodulation test
VCE = 5 V, IC = 30 mA, dIM = 60 dB,
f1 = 806 MHz, f2 = 810 MHz,
ZS = ZL = 50
V1 = V2 240 mV
Third order intercept point VCE = 5 V, IC = 30 mA, f = 800 MHz IP3 30 dBm
BFR91
Vishay Telefunken
www.vishay.com
ZS = 50
F 1.9 dB
f = 500 MHz
Gpe 18 dB
f = 800 MHz
Gpe 13 dB
ZS = ZL = 50
V1 = V2 240 mV
Ja napisah zbog prenosne karakteristike pojacala koje si linkovao.
Mom kolegi (penzioner) treba za autoradio.-
- prenosna karakteristika.png (43.21 KiB) Viewed 10106 times
Pa ljudi moji ...pojačalo sa BFR91A može biti i za TV i za FM radio i za puno drugih područja...greska nije moja ja znam da BFR91A sluzi za tv pojacalo. A ne za FM podrucije 88-108 mhz
a ne samo za TV pa TV kanali 2,3,4 su ispod FM banda...
dakle šta je potrebno da bi od pojačala za TV dobili samo pojačalo za FM 88-108 MHz
jedna zavojnica i dva kondenzatora.
Zavojnica L - Culack 0.5 ,5 zavoja promjera 7mm.
- FMFilter.gif (2.1 KiB) Viewed 10034 times
Poštovani elektroničari! Da ne otvaram novu temu, a ovdje se spominje BFR91A. Jel zna neko, gdje danas kupiti/naručiti ovaj tranzistor. Probao sam više njih sa AliExpressa, ali to nije to. Ima na eBay Telefunken, ali su po 2 eura po komadu, preskupo. Jel zna neko? Hvala
@JosipD, napisi u profilu lokaciju-odakle si.?
RiješenoLAF wrote:@JosipD, napisi u profilu lokaciju-odakle si.?
