Trebam :
1 kom - AC125
1 kom - AC126
2 kom - AC128
Germanij tranzistori
Re: Germanij tranzistori
Pogledat ću preko vikenda u "arhivi", ako nešto bude šaljem u ponedjeljak.
Josip
Josip
ASZ1018
Pošto mi treba slična stvar postat ću ovdje, nadam se da se bob neće naljutiti
Potreban mi je tranzistor- ASZ1018. Ukoliko netko ima ili zna gdje ima za nabavit nek javi...
Karakteristike su mu sljedeće:
U obzir dolaze i zamjene, VRT disc kaže da su to AUY37 i 2N2527...
Material of transistor: Ge
Polarity: PNP
Maximum collector power dissipation (Pc), W: 22.5
Maximum collector-base voltage |Ucb|, V: 80
Maximum collector-emitter voltage |Uce|, V: 0
Maximum emitter-base voltage |Ueb|, V: 40
Maximum collector current |Ic max|, A: 6
Maximum junction temperature (Tj), °C: 100
Transition frequency (ft), MHz: 0.25
Collector capacitance (Cc), pF: 160
Forward current transfer ratio (hFE), min: 30
Noise Figure, dB: -
Package of ASZ1018 transistor: TO3
Imam prekonekoliko germanijskih tranzistora, pogledam sutra po policama i ladicama pa vam javim
Ako neko treba:
AD149 1
AD162 3
AD436 3
AD438 2
AD469 1
AD149 1
AD162 3
AD436 3
AD438 2
AD469 1
Re: ASZ1018
Može i ASZ18..elektor wrote:Pošto mi treba slična stvar postat ću ovdje, nadam se da se bob neće naljutiti![]()
Karakteristike su mu sljedeće:U obzir dolaze i zamjene, VRT disc kaže da su to AUY37 i 2N2527...Code: Select all
Material of transistor: Ge Polarity: PNP Maximum collector power dissipation (Pc), W: 22.5 Maximum collector-base voltage |Ucb|, V: 80 Maximum collector-emitter voltage |Uce|, V: 0 Maximum emitter-base voltage |Ueb|, V: 40 Maximum collector current |Ic max|, A: 6 Maximum junction temperature (Tj), °C: 100 Transition frequency (ft), MHz: 0.25 Collector capacitance (Cc), pF: 160 Forward current transfer ratio (hFE), min: 30 Noise Figure, dB: - Package of ASZ1018 transistor: TO3
Javite i ukoliko znate nekoga tko prodaje starije tranzistore, a da nije član foruma. Trebao bih ga nabaviti što prije..
