Sve antene na 2.4 GHz
MORGAN
Post by MORGAN »
1. Omni antena
http://www.allendale-stores.co.uk/wifi/ ... ntenna.jpg" onclick="window.open(this.href);return false;
2. Kantena
http://vratisinec-wireless.hr/oprema/kantena.jpg" onclick="window.open(this.href);return false;
3. sat-Kantena
http://www.wifihr.net/files/slike/sat.jpg" onclick="window.open(this.href);return false;
4. Biloop
http://pe2er.nl/wififsm/BiloopFieldStre ... -groot.JPG" onclick="window.open(this.href);return false;
5. Biquad
http://www.nec2.org/ntype-front-thumb.jpg" onclick="window.open(this.href);return false;
6. Double biquad
http://martybugs.net/wireless/biquad/im ... nearly.jpg" onclick="window.open(this.href);return false;
7. Double dual biquad
http://i46.tinypic.com/34skoja.jpg" onclick="window.open(this.href);return false;
8. sat-Biquad
http://hazardous.com/sx/DTVBiQuaddishback.jpg" onclick="window.open(this.href);return false;
9. Helix
http://ve2zaz.net/13cmHelx/ph_tot.jpg" onclick="window.open(this.href);return false;
10. Quad helix
http://www.setileague.org/photos/miscpix/helix01.jpg" onclick="window.open(this.href);return false;
11. Panel
http://pliki.interprojekt.pl/wiki/attac ... budowa.jpg" onclick="window.open(this.href);return false;
12. Vagi
http://www.optimum-online.hr/BinaryLibr ... 00_600.jpg" onclick="window.open(this.href);return false;
13. Yagi
http://product-image.tradeindia.com/002 ... ntenna.jpg" onclick="window.open(this.href);return false;
14. Backfire
http://www.radiolabs.com/products/anten ... ckfire.gif" onclick="window.open(this.href);return false;
15. Grid
https://www.inter-shop.gr/commerce/cata ... D24DBI.jpg" onclick="window.open(this.href);return false;
16. Obelisk
http://yu1aw.ba-karlsruhe.de/Obelisk%20 ... -%2011.jpg" onclick="window.open(this.href);return false;
17. Amos
http://www.qsl.net/yu1aw/Amos%20at%20work.jpg" onclick="window.open(this.href);return false;
18. 3D Korner
http://www.qsl.net/yu1aw/3DCFspider4.jpg" onclick="window.open(this.href);return false;
19. Waveguide
http://personal.ee.surrey.ac.uk/Persona ... 040304.jpg" onclick="window.open(this.href);return false;
20. Patch
http://www.qsl.net/k3tz/images/k3tz_patch14.jpg" onclick="window.open(this.href);return false;
21. Horn (od kartona)
http://farm1.static.flickr.com/3/5178759_b15426d59d.jpg" onclick="window.open(this.href);return false;
22. Quados
http://www.qsl.net/yu1aw/Quados%20static%20protect.jpg" onclick="window.open(this.href);return false;
23. Fid
http://i47.tinypic.com/2cp47sx.jpg" onclick="window.open(this.href);return false;
ako znate još neku samo nastavite.... :D
zlatkoMM
Re: Sve antene na 2.4 GHz
Post by zlatkoMM »
Zanima me ova zadnja fid antena da li ima negdje opis i koje su dimenzije???????????
japek
Post by japek »
Na Draganovoj stranici: http://yu1aw.ba-karlsruhe.de/fid_antene.htm .
Nadam se, da češ nači što tražiš.
Pozdrav, Janko
Ova je zgodna za ose. Mogu graditi svoja saćasta gnjezda u ovim rupicama. :lol:
http://trevormarshall.com/waveguides.htm
japek
Post by japek »
Smješko, pa da znaš, da takve svari i ne moraju biti baš smješne.
Sječam se, prije skoro 20 godina, kada sam još radio na kablovski TV imali smo na jednoj zgradi prijemno stanico za zemeljske i satelitske programe. Kad počnu oni reklamirati da u 9 sati naveče nestane slika sa satelita, a ujutro ponovo proradi. Na objekat smo odlazili više puta, proveravali spojeve, menjavali svari, ali uvek isto. Na kraju smo ipak našli krivca, bio je to neki veliki crni paok, koji je svake noči spavao u onoj rupi od prijemnog konvertera za satelitsko. Tada na početku tamo još nismo stavljali čep, odnosno zatvarali te rupe i baš mu se svidjelo tamo unutra. Ali izgleda bio je dovoljno krupan, da slike više nije bilo.
Zbog njega bilo je nakoliko slabe volje pa i troškova.
LP, Janko
@Janko znam ja da takve stvari nisu smješne. Ratujem sa osama i stršljenima i nalazim ih po svakakvim rupama (ispod crijepa na krovu, u cijevima nosača antena, u kojekakvim rupama na ogradi terase, itd.) pa sam zato i napisao ovo vezano uz slot antenu. Mislim da bi bilo dobro tu antenu presvući termo-bužirom kako bi se zatvorile rupe (slotovi) i onemogućio ulaz i gnježđenje spomenute gamadi.
toncy_makaroncy
Post by toncy_makaroncy »
momci i dobri ljudi molio bih vas za pomoc da mi pojasnite slikom ili tekstom kako se pravi biquad ili dualbiquad wireles antena hvala vam unaprijed
japek
Post by japek »
Za biquad imaš http://pe2er.nl/index.htm i http://yu1aw.ba-karlsruhe.de/optim_biquad_ant.htm.
Meni se više sviđaju okrugle stvari, pa može i http://lea.hamradio.si/~s55wt/Biloop/Biloop.html.
A što se tiče dual izvedbe, nije to to, zašto se najde i na mojoj stranici. Bolje je onda stack od više antena ili drugi tip. I yagi nije baš komplikovana antena, nešto se najde o tome tu: http://lea.hamradio.si/~s55wt/WIFI%20an ... jenja.html.
Pozdrav, Janko
zlatkoMM
Post by zlatkoMM »
zlatkoMM
Post by zlatkoMM »
Evo na slici je završena 'curtain quad' antena za 2.4 wifi.
Još treba napraviti mali balun transformator i staviti je u plastično kućište za vanjsku montažu.
zlatkoMM
Post by zlatkoMM »
Evo još jedne koja je modificirana fraktal antena.
Tj. ako malo bolje pogledate u suštini fraktalna verzija curtain quada.
Dizajn je moj,jer nisam nigdje vidio ništa slično(za sad...).
Duljina jednog segmenta je 8mm,rađeno sa bakrenom žicom 0.75.
Resistor_01
Post by Resistor_01 »
Vec kada se ovde govori o antenama . Imam jedno pitanje ? Koja je razlika izmedju onih dipola sto kupe signal na wireless anteni gdje je jedan lim spojen na masu(pletena zica bakrena) kloakscijalnog kabla a drugi na onu drugu zicu klokasijalnog kabla. I dipola gdje je su obadva lima spojena na masu a samo jedn lim na jezgo (bakrena zica u sredini) kloaksijalnog kabla. Mislim da znate o cemu govorim. Koji je bolji ? Koje su mane , prednosti ?
zlatkoMM
Post by zlatkoMM »
E sad mi nije ništa jasno...ozbiljno..
Kakav lim?
Na koju antenu misliš konkretno?
Resistor_01
Kada otvoris onu plastiku iz koje ide kabal na grid wireless anteni . Imaju bakreni limovi . Kod mene je ovakva sema : http://postavi.org/?di=SE9A. Pletena zica kloaksijalnog kabla skopcana na jedan bakreni lim a jezgro na drugi. Dok u ovoj dole sto sam postavio jezgro skopcano na jedan a pletena zica (masa) na oba lima. U neikm antenama je ovako kao na drugoj slici. Sada pitanje je koji je sistem bolji koje su prednosti, mane ?. Da li bi ja dobio bolji signal kada bi uradio ovaj drugi dipol? Naravno duzine limova su iste ..
Drugi sistem
Drugi sistem
Resistor_01
Zna li ko :?:
zlatkoMM
Post by zlatkoMM »
Ovo na slici je pravilan način jer se spojeno sa balun transformatorom tj.
asimetričnim članom.
Resistor_01
Tako cu i najvjerovatnije uraditi. :D
