Prodajem PLC kontrolere CYBRO PLC
Ulazi: 8 digitalnih/ 3 analogna
Izlazi: 6 izlaznih / 3 analogna
2 COM porta
Ethernet port
Program Memory: 128 K flash EEPROM Data Memory: 128 K static RAM system clock: 24 MHz
Processing time: 250 ns basic commands
Reach a time base: 10 ms, 100 ms and 1 s
Data types: bit, word, int, long, real
Time after which the data is lost: 15 days
This Community clocks (RTC): 30 seconds / month
Digital inputs: 24 V, 7 mA sink / source
Delay the digital inputs: 5 ms
Digital Outputs: 1 A, 250 V relay contacts and 0.5 A, 30 V transistor outputs
Analog inputs: Pt100/Pt1000, Ni100/Ni1000, 0 (4) mA .. 20 mA and 0 V, 10 V analog outputs: 0 (4) mA .. 20 mA and 0 V, 10 V
Precision: 0.1%
IEX capacity: 16 units (512 I / O points) IEX bus length: 5 m max.
IEX transmission speed (baud rate): 100 kbps
A-bus capacity: 32 devices
A-bus distance: 1 000 m max.
A-bus transmission speed (baud rate): 19,200 bps
A-bus response time: 25 ms x number of devices
High Speed Counter: 10 kHz max. HSC levels: 24 VDC
Supply voltage:
85 V - 264 V, 50/60 Hz (PLC)
24 VDC (PLC, Bio-16, PG)
5V (IEX) output current:
600 mA max. (PLC)
1000 mA max. (Bio-16)
1200 mA max. (PS)
24 V output power: 120 mA max. (PLC only)
Hard-working temperature: 0 ° C. .50 ° C, 85% RH (relative humidity) Storage Temperature: -10 ° C. .75 ° C, 85% RH
Housing: IP20, gun-DIN bar
