Digitalni merac broja obrtaja (obratometar)
Re: Digitalni merac broja obrtaja (obratometar)
zna li neko đe se nalazi hex za ovaj obrtomjer
Mislim na onaj sa displejom 2x16
- morski_pas
evo ti za početak ,a ti malo zagri stolicu
LCD should be connected as follows:
' LCD PIC
' DB4 PortA.0
' DB5 PortA.1
' DB6 PortA.2
' DB7 PortA.3
' RS PortA.4 (add 4.7K pullup resistor to 5 volts)
' E PortB.3
' RW Ground
' Vdd 5 volts
' Vss Ground
' Vo 20K potentiometer (or ground)
' DB0-3 No connect
r var word
f var word
loop: f = 0
r = 0
count portb.0 , 1000 , f
if f > 1000 then khz
Lcdout $fe, 1 ' Clear LCD screen
Lcdout #f ' Display Freq.
lcdout $FE, $14
lcdout "Hz"
goto loop
khz: r = f // 1000
f = f / 1000
lcdout "."
lcdout #r
lcdout $FE, $14
lcdout "KHz"
goto loop
' LCD PIC
' DB4 PortA.0
' DB5 PortA.1
' DB6 PortA.2
' DB7 PortA.3
' E PortB.3
' RW Ground
' Vdd 5 volts
' Vss Ground
' DB0-3 No connect
r var word
f var word
loop: f = 0
r = 0
lcdout $FE, $14
lcdout "Hz"
goto loop
khz: r = f // 1000
f = f / 1000
lcdout "."
lcdout #r
lcdout $FE, $14
lcdout "KHz"
goto loop
r var word
f var word
loop: f = 0
r = 0
lcdout $FE, $14
lcdout "Hz"
goto loop
khz: r = f // 1000
f = f / 1000
lcdout "."
lcdout #r
lcdout $FE, $14
lcdout "KHz"
goto loop
Hvala. Jeli ovo program
f var word
loop: f = 0
r = 0
lcdout $FE, $14
lcdout "Hz"
goto loop
khz: r = f // 1000
f = f / 1000
lcdout "."
lcdout #r
lcdout $FE, $14
lcdout "KHz"
goto loop
mislim da su ovđe 2 programa jedan za mjerenje obrtaja u sekund a drugi za mjerenje obrataja u minut jel tako
Ne shvatam ovaj program
@morski_pas
e odlicno, jel si to ti crtao shemu?
ako moze malo krupnija slika, da vidim onaj senzor sto se spaja na rb0, jel je to nki filter, ili moze da se spaja na kabl od svecice ?
I jos nesto, ako moze neko da mi pomogne oko hall senzora, posto sam batalio ovo sam svecicom, uzeo sam dva hall prekidaca,
tle 4945l (bipolar)
i
tle 4976l (unipolar)
gledao sam malo po datasheetovima, i po meni je laksi ovaj bipolarni jer tu imam lepo ulaz, izlaz i masu, a ovaj unipolarni mi nije jasan, jer ima samo dva kontakta.
medjutim, kada sam spojio bipolarni prekidac po shemi iz datasheeta, shvatio sam da je to ustvari prekidac, jedan pola magneta ga pali, a drugi pol gasi prekidac.
jel mogu upotrebiti ovaj unipolarni prekidac da napravim senzor ili moram bas nabaviti pravi hall senzor?
hvala..
tle 4945l (bipolar)
i
hvala..
jeli sve ovo kod
' LCD PIC
' DB4 PortA.0
' DB5 PortA.1
' DB6 PortA.2
' DB7 PortA.3
' E PortB.3
' RW Ground
' Vdd 5 volts
' Vss Ground
' DB0-3 No connect
r var word
f var word
loop: f = 0
r = 0
lcdout $FE, $14
lcdout "Hz"
goto loop
khz: r = f // 1000
f = f / 1000
lcdout "."
lcdout #r
lcdout $FE, $14
lcdout "KHz"
goto loop
' LCD PIC
' DB4 PortA.0
' DB5 PortA.1
' DB6 PortA.2
' DB7 PortA.3
' E PortB.3
' RW Ground
' Vdd 5 volts
' Vss Ground
' DB0-3 No connect
r var word
f var word
loop: f = 0
r = 0
lcdout $FE, $14
lcdout "Hz"
goto loop
khz: r = f // 1000
f = f / 1000
lcdout "."
lcdout #r
lcdout $FE, $14
lcdout "KHz"
goto loop
- morski_pas
evo veće slike :
http://forum.patoghu.com/images/poti/2009/03/11.jpg
da to je sve kod osim linija označenih sa ' one su opis naredbi ili pojašnjavane nekih radnji
znači :
ako piše
' E PortB.3 to objašnjava da je nožica E od LCD-a spojena na nožicu port B3 mikrokontrolera itd.
znači :
ako piše
Zahvaljujem
kolika je kod vas cijena od 16f84a
kolko košta kod vas pic 16f84a
- morski_pas
ako misliš u hrvatskoj je oko 5 do 6 eura
vrijedi li tih para
- morski_pas
kako za koga ako mu treba onda nije,ovo gore možeš napravit i sa drugim picevima pic16f676,pic16f628 itd
jesu li oni jeftiniji
Jesi li ga dosadan. Sa takvim stavom nećeš ništa naučiti. Eto već si tu napisao preko 10 postova, a nisi se maknuo sa mrtve točke .
Napravio sam sklop samo čekam da mi stigne mikrokontroler i da ga isprogramiram
Onda kupi taj 16f84 i sredi to. Pa onda pokaži slikice. Nemoj se previše zamarat za tih 10-ak kn, mala je to cijena za stečeno znanje.
Btw. na dealextremu su dobili IR senzor (jeftin) koji bi se mogao lijepo uklopiti kao senzor za brojač okretaja. Samo neznam koliko brzo može switchati, trebalo bi isprobati. Inače čini mi se da je netko sa foruma već koristio sličan senzor u brojaču okretaja.
Evo i linka http://www.dealextreme.com/p/ir-infrare ... nge-121348
