Zanima me kakav je ARM DSO NANO osciloskop,sviđa mi se njegov izgled i veličina,a o cijeni da ne pričam..
Dali netko ima iskustva sa njim,pošto se ja ne razumijem u osciloskope i ovo bi mi bio prvi,dali ga se isplati kupiti za početak,da se na njemu učim,a poslije da si uzmem nešto ozbiljnije,sad,dali on zadovoljava početničke potrebe? evo specifikacije pa ako mi netko može malo pojasniti,bio bih mu jako zahvalan...
Display
2.8″ Color TFT LCD
Display Resolution
320×240
Display Color
65K
Analog bandwidth
0 - 1MHz
Max sample rate
1Msps 12Bits
Sample memory depth
4096 Point
Horizontal sensitivity
1uS/Div~10S/Div (1-2-5 Step)
Horizontal position
adjustable with indicator
Vertical sensitivity
10mV/Div~10V/Div (with ×1 probe)
0.5V/Div~10V/Div (with ×10 probe)
Vertical position
Adjustable with indicator
Input impedance
>500KΩ
Max input voltage
80Vpp (by ×1 probe)
Coupling
DC
Trig modes
Auto, Norma, Single, None and Scan
Functionalities
Automatic measurement: frequency, cycle, duty, Vpp, Vram, Vavg and DC voltage
Precise vertical measurement with markers
Precise horizontal measurement with markers
Rising/falling edge trigger
Trig level adjustable with indicator
Trig sensitivity adjustable with indicator
Hold/run feature
Test signal
Built-in 10Hz~1MHz (1-2-5 Step)
Waveform storage
SD card
PC connection via USB
As SD card reader
Upgrade
By bootloader via USB
Power supply
3.7V Chargeable Lithium battery / USB
Dimension (w/o probe)
105mm X 53mm X 8mm
PC connection
Mini USB B-Type
[Pomoc] Kupnja osciloskopa
Re: [Pomoc] Kupnja osciloskopa
http://www.elektronika.ba/forum/viewtop ... 64#p111867
Ako se ne varam to je isto ko i ovo, samo ima 3 kanala manje...
Ako ti se ne zuri sacekaj da meni stigne, pa cemo videti kakvo je to cudo...
ma nije mi problem čekat,nego koliko vidim po specifikacijama taj je dosta bolji..
