AVR transistor tester
Instrumenti
Evo nove igracke :ohno:
shema je ovdje:http://www.mikrocontroller.net/articles ... stortester
video je ovdje: http://www.youtube.com/watch?v=dtoSCx3pwpY" onclick="window.open(this.href);return false;
a moja verzija je na ovim slikama:
http://img810.imageshack.us/img810/6264/89268728.jpg" onclick="window.open(this.href);return false;
http://img801.imageshack.us/img801/5177/47016529.jpg" onclick="window.open(this.href);return false;
http://img204.imageshack.us/img204/4224/27299922.jpg" onclick="window.open(this.href);return false;
http://img19.imageshack.us/img19/4905/12429360.jpg" onclick="window.open(this.href);return false;
http://img638.imageshack.us/img638/474/79837578.jpg" onclick="window.open(this.href);return false;
http://img837.imageshack.us/img837/3404/24562792.jpg" onclick="window.open(this.href);return false;
http://img269.imageshack.us/img269/8697/49459881.jpg" onclick="window.open(this.href);return false;
http://img40.imageshack.us/img40/6532/44294561.jpg" onclick="window.open(this.href);return false;
http://img402.imageshack.us/img402/9374/63065300.jpg" onclick="window.open(this.href);return false;
http://img13.imageshack.us/img13/8687/65336553.jpg" onclick="window.open(this.href);return false;
http://img838.imageshack.us/img838/9918/48704452.jpg" onclick="window.open(this.href);return false;
http://img811.imageshack.us/img811/4531/88731828.jpg" onclick="window.open(this.href);return false;
http://img148.imageshack.us/img148/6003/31751419.jpg" onclick="window.open(this.href);return false;
moram reci da program ima gresku :roll: ne uspije svaki puta inicijalizirati LCD pa baca na ekran gluposti, iako vidim da i onda program radi (testiranje led diode 2-3 puta blicne ko i kad je sve uredu).
Probao sam par verzija softvera ali isto....evo kako izgleda kad se upali pod greškom:
http://img215.imageshack.us/img215/2232/greska.jpg" onclick="window.open(this.href);return false;
Re: AVR transistor tester
Vidim cekic je tu, pa ako ne radi :azdaja:
gurko
Post by gurko »
Pravo dobra spravica! Svaka cast!
Jesi li slucajno skontao na koji nacin prepozna koji je element? Npr, kako razlikuje duplu diodu od tranzistora?
kizbaja
Post by kizbaja »
svaka cast :D
jesi probo stavit tranzistor kojemu je jedna polovica u kratkom spoju, dal ga prepozna ko diodu ili...?
@gurko, kako stvar radi autor je opisao na svojoj stranici...prvi link u mom prvom postu.
@kizbaja, jbg. kad uvijek bacam sve što nevalja :roll: odsada u jednu kutiju pa da ima za testiranje...javim kad probam, ili budem namjerno jednog tranzistora probio :roll: :ohno:
mega162
Post by mega162 »
Svaka čast Feko :)
Sta reci nego BRAVO!!
kako si ubacio hex u ovaj avr, nisam nikada radio nista s njima :?
Koliko te je izasao kompletan projekat?
Kupio sam USB programator sa ebaya za 7 dolara :ohno:
http://cgi.ebay.com/USB-ASP-ISP-51-AVR- ... 45fbc4676d" onclick="window.open(this.href);return false;
iii napravio adapter. Nih ću praviti kako mi koji zatreba :wink:
http://img8.imageshack.us/img8/2010/91844229.jpg" onclick="window.open(this.href);return false;
http://img688.imageshack.us/img688/3037/66609345.jpg" onclick="window.open(this.href);return false;
ATmega8 adapter PCB.zip
(9.09 KiB) Downloaded 706 times
edit:
Ledica i otpornik ne trebaju...pinout po kojemu sam radio ima na 3 pinu oznaku LED pa sam mislio da na nju ide signalizacija programiranja :roll:
Koliko me koštalo?
Atmega8 = 24 kune, Display = oko 40 kuna i ostala sitnarija cca 10 kuna....oko 75 kuna.
Problem inicializacije LCD-a je riješio Kizo kojem se još jednom zahvaljujem. Ispravljeni firmware je u prilogu.
TransistorTestLCDinitFixByKizo.zip
(8.6 KiB) Downloaded 834 times
78L05
Post by 78L05 »
Sviđa mi se kako je napravljeno, bravo Feko. :wink:
alsatpv
Post by alsatpv »
Shema je potpuno ista ko i što si ti radio. Ja sam pločicu radio sam jer sam htio da mi bude veličine 2 dimenzije displaya kada se sve ugradi u kutiju. Onaj display mi je za isprobavanje...display se direktno bode na konektor.
http://img204.imageshack.us/img204/156/21236923.jpg" onclick="window.open(this.href);return false;
Imao sam i takvu kutiju prije mjesec dana u rukama i sad ne mogu da ju nađem :ohno:...previše krša u radioni :azdaja:
..još jedna ovakva pintest pločica i može u kutiju :wink:
Proba ZaSlike.com
[URL=http://zaslike.com/viewer.php?file=1ru19mp8iao4zxl3sal7.jpg][IMG]http://zaslike.com/files/1ru19mp8iao4zxl3sal7_thumb.jpg[/IMG][/URL]
jbg. kad ovo gore stavim u "Img"
isto se dobije poruka:It was not possible to determine the dimensions of the image.
...kako dobiti da na forumu bude mala slika, pa kad se klikne onda ju pokaže veliku?
Našla se kutija, pa se radilo popodne....
Uređaj radi na bateriju od 9V, lijevo od displaya su 2 mikroprekidača-prvi je za backlight a drugi je On/Off ako se dugo ne koristi, mada jako malo troši bateriju je se automatski gasi za 10 sekundi. Ponovni pritisak na taster ga aktivira, izbaci rezultat i nakon 10 sekundi se ugasi.
Testirao sam 3 kučišta SMD tranzistora i nitijenog nisam morao pritisnuti prilikom testiranja....evo slikica :wink:
http://img16.imageshack.us/img16/1921/51068047.jpg" onclick="window.open(this.href);return false;
http://img850.imageshack.us/img850/3711/83708251.jpg" onclick="window.open(this.href);return false;
http://img18.imageshack.us/img18/9683/36811536.jpg" onclick="window.open(this.href);return false;
http://img84.imageshack.us/img84/3382/45196256.jpg" onclick="window.open(this.href);return false;
http://img683.imageshack.us/img683/8669/81039741.jpg" onclick="window.open(this.href);return false;
http://img836.imageshack.us/img836/7313/59994670.jpg" onclick="window.open(this.href);return false;
http://img29.imageshack.us/img29/9774/62715673.jpg" onclick="window.open(this.href);return false;
Ja sam pravio Tranzistor tester - SC analyser - Determinator 4001 ima ga ovde na forumu u gotovim projektima ali nisam zadovoljan. Hoce da slaze a takav nepouzdan instrument nisam hteo da koristim i stavio ga sa strane u kutiju. Kad dobro istestirate vase uredjaje kazite da li ste nasli jos neku gresku ili nepravilnost u radu. Svidja mi se kako radi pa bi napravio ali ako ima "manu" kao njegov predhodnik kojeg sam pravio da gresi onda da ga ne pravim dzaba :wink:
Pa ovaj ti je turbo jeftin. Atmegu8 uvijek možeš za nešto drugo iskoristiti, display također...a sve ostalo su 3 tranzistora, 7805 i 10tak otpornika i par kondenzatora koje sigurno imaš na lageru. Nisam se previše igrao sa njime, ali sve što sam testirao-rezultat je bio OK. Za otpornike i kondenzatore nema veliku točnost, no to mu ni nije namjena. Ja sam ga u biti napravio zbog SMD tranzistora koje vadim sa šasija novijih uređaja a oni obicno nemaju oznake tako da ce mi dobro doci :wink:
Imam sve delove diplej, atmega, otpore.... nije problem.Za kondezatore vec imam napravljen onaj LCF metar a otpore merim unimerom tako da mi i to nije bitno. Primer ovaj sto sam pravio predhodni hoce da laze. Ubodem tranzistor on pokaze BCE okrenem tranzistor i ubodem on pokaze ponovo BCE. Od 10 dovoljno je da me zezne na 3 i nista nisam uradio... na eci peci pec bi od 10 manje promasio :)
Srecko
Post by Srecko »
Ja sam izradio taj tester pre cca godinu i po dana, pa nisam bio previše zadovoljan sa njim. Tada sam imao poteškoča kada sam htjeo dati "Engleski" program u njega tada nije pokazivao prave napise, radilo je samo sa original Nemačkim programom. Mislim i, da nije uvek pokazao prav šta si pokušao izmeriti njime. pravo, da kažem tada sam ga dao na strau i nisam se više sjetio na njega. Možda su šta izboljšali program pa da sada radi bolje. :D
@Feko možeš staviti taj tvoj crtež adaptera u neki pdf ili neki program nap egle ili koji drugi koji ga otvara.
Taj tvoj adapter je zanimiv i za koji drugi instrument. :lol:
LP Srečko
Samouk
