FM odasiljac
FM odasiljac
jel ima tko kakvu kvalitetnu shemu za FM odasiljac koji ce raditi u opsegu od 1km a da se signal moze hvatat klasičnim radio prijamnikom?
Re: FM odasiljac
Ovaj je domea 700m iman jaci od 4wfengeaos wrote:jel ima tko kakvu kvalitetnu shemu za FM odasiljac koji ce raditi u opsegu od 1km a da se signal moze hvatat klasičnim radio prijamnikom?
http://www.elektronika.ba/forum/uploadz ... 86_buu.txt ... (Fajl je dobio ekstenziju .txt. Reimenujte fajl tako da izbrisete .txt i ostane originalna ekstenzija.)
Re: FM odasiljac
Kad skinete fajl, treba mu dodati esktenziju .pdf ako se sama ne dodajopagti wrote:Ovaj je domea 700m iman jaci od 4w
Re: FM odasiljac
evo jedan od 4w
http://www.elektronika.ba/forum/uploadz ... 614_4w.txt ... (Fajl je dobio ekstenziju .txt. Reimenujte fajl tako da izbrisete .txt i ostane originalna ekstenzija.)
ja bih zelio napraviti bez mikrofona s line in-om. nasao sam ovo:
FM VHF Stereo Transmitter
A work collegue back in 1993, Warwick Jones brought a BA1404 back from his Austrialian trip for me to experiment with, and this is where it led me.
This FM VHF Stereo Transmitter operates from a 12Volt supply and outputs a true stereo signal any where between 88 and 108MHz. The output is approximately 250mW and when using a tuned 1/4 wave dipole antenna ranges of over 5miles was acheived. Crystal X1 is 38KHz. L1 and L2 are 2turns of 22SWG enambled coper wire wound over an adjustable 10mm ferrite core. L1/C2 make up the tuned circuit and adusting L1 determines the O/P frequency. All resistor values are 1/4 watt and capacitors are rated at 16Volts. VR1 and VR2 are 4.7K Presets. All Bi-polar capacitors are ceramic. C16 is a Trimmer Cap and should be trimmed for maximun output into a 50ohm load antenna. The 2nd and 3rd harmonic contents are minimal. If an amplifier is to be used then incorporate a Low Pass filter network in its' output to reduce spurious emmissions.
The circuit diagram takes a while to load...PLEASE WAIT!!!!Due to demand I have draughted up a Veroboard layout of the circuit which you will find beneath the circuit diagram. Use the circuit diagram to identify the components. It is Ideal to tune up this circuit using a wave detector meter placed a few inches away from the transmitter. I have a circuit on this site.
http://www.elektronika.ba/forum/uploadz ... ereotx.gif
http://www.ajpotts.fsnet.co.uk/stereotxvero.gif
sta vi mislite o tome? ak mislite da to mozda ne bi radilo jel bi se dale ove vase sheme prepravit da nemaju mic nego line in
Re: FM odasiljac
jel bi mogo umjesto ovog alternativnog kondenzatora (od dvije zice) staviti neki promjenjivi kako bih mogao donekle birati frekvenciju? ako da, kojeg raspona??????jopagti wrote:Ovaj je domea 700m iman jaci od 4wfengeaos wrote:jel ima tko kakvu kvalitetnu shemu za FM odasiljac koji ce raditi u opsegu od 1km a da se signal moze hvatat klasičnim radio prijamnikom?
u pravu si, mosfet modul BGY33 (133), stvarno perfektna stvar za FM predajnike, daje 20W iz ulaza 100mW,zadnja cijena sto sam je vidio na netu je bila oko 90 Eura.Firkragg wrote:Za velike snage je ljudima uglavnom problem izlazni driver, obicno su RF mosfeti >10W dosta skupi (za te frekvencije)
A i meni bi trebalo za HFSSTC par...
Re: FM odasiljac
jel zna tko? jel se moze zamijenit promijenjivim kondenzatorom, a ak da kojeg rasponafengeaos wrote:jel bi mogo umjesto ovog alternativnog kondenzatora (od dvije zice) staviti neki promjenjivi kako bih mogao donekle birati frekvenciju? ako da, kojeg raspona??????jopagti wrote:Ovaj je domea 700m iman jaci od 4wfengeaos wrote:jel ima tko kakvu kvalitetnu shemu za FM odasiljac koji ce raditi u opsegu od 1km a da se signal moze hvatat klasičnim radio prijamnikom?
Najjace mi je ko ovo gore vidit BC547 u izlaznom stupnju FM odasiljaca, onda ljudi to prave i nadaju se kilometarskim dometimau pravu si, mosfet modul BGY33 (133), stvarno perfektna stvar za FM predajnike, daje 20W iz ulaza 100mW,zadnja cijena sto sam je vidio na netu je bila oko 90 Eura.
Mislim da je 'najmocnije' (freq. i snaga) sot imam ovdje mitsubishijev M68710L, iskopan iz (valjda) ancient voki tokija. 2W i 400-430Mhz, malo cudno (ocekivalo bi se 433), ili je to bila neka tajna frekvencija..
Mozda je i najbolja sansa za snagu ako se neko dokopa neke RF cijevi ili sl, (par W je odlicno), spojena u classE bi mogla posluziti kao zgodno pojacalo za 'veroniku'.
PS. palo mi je napamet da pricam o zloostavljanjima 'obicnih' SMPS mosfeta na 4hv ali necu
Potrazi neki sto manjeg minimalnog kapaciteta, 1-2 pf nadalje (mislim da ti vise od 30ak nece trebati , eksperimentriaj i igraj se.jel zna tko? jel se moze zamijenit promijenjivim kondenzatorom, a ak da kojeg raspona
Ufrkane zice katkad mogu biti zgodan lash-up za promjenjivi kond..
evo ja kontam ici uzimati 75 omski kabal jedno 20m
da stavim antenu na dimnjak i sprovedem kabal u sobu.
trenutno je antena na balkonu jer nisam imao dovoljnu duzinu kabla do dimnjaka,posto se uz antenu mota onaj balun od kabla.
uz to koristio sam klasicni 75 omski kabal koji se prodaje za tv antene i satelitske.
predpostavljam los kvalitet.
znaci pokusacu naci kakav kvalitetni kabal 75 oma sa dobrim plastom okolo.
jer u ovome mom sistemu nesto nije uredu.
sa 1W nece preko 200m.
mozda je kabal los,mozda antena nije uredu,mozda mjesto gdje se nalazi antena.
znaci antenu sam pravio sa one slike koja dodje uz semu veronike
otvoreni dipol duzine po 81cm svaki dipol
e koliko dipoli moraju biti udaljeni od okolnih predmeta i nosaca.
tamo pise mislim oko pola metra minimalno.
Neznam jel svima to jasno, (ko je radio ista sa SSTC) ali odasiljac se moze npr. s dummy loadom namjestiti savrseno i onda krepavati s antenom i svim tim kabelom.
Kabel i antena i sve sto spojimo na odasiljac ima kapacitet i induktivitet (antena se uzima i za 1/4 valne duzeine po polu, impedancija 75, 50ohma i sl, to nije bitno sad) i detunira izlazni filter i pojacalo odasiljaca (kolko se sjecam u veroniki je class E i namjesta se).
Tek kad je sve na mjestu onda se odasiljac namjesta za max snagu, sto katkad zna biti komplicirano.
Kad kutija nije oklopljena imati neki tune je prakticki nemoguce s oscilatorom koji stalno mjenja frekvenciju ( i njemu smeta sve zivo sto se oko njega pomice.
Za bilo sto ozbiljnije metalna kutija je obavezna.
Antena naravno gubi puno na snazi ako je blizu zidova, metalnih objekata, u kuci i sl, ne moram o tome ponavljati.
Kad je sve ovo gore rijeseno i dalje nisi zadovoljan ostaje ti pvisenje napona, i bildanje snage sve do smrti izlaznog stupnja.
Od okolnih predmeta, pogotovo metalnih i zidova (bilo cega vodljivog) dipoli moraju biti sto udaljeniji jer jednostavno gube energiju na 'indukcijsko grijanje' u tom slucaju.e koliko dipoli moraju biti udaljeni od okolnih predmeta i nosaca.
e da ovo sam sam se sjetio ga gornji dipol nece biti blizu nicega kad stavim na dimnjak.
znaci nosac pricvrstim na vrh dimnjaka.
dojnji dipol ce biti paralelan sa dimnjakom udaljen oko pola metra od njega.
a naravno gornji dipol ce biti slobodan,jer je iznad nosaca a samim tim ni dimnjak nije blizu.
e samo da pitam:
da li se odasiljac moze stimati tako da spojim antenu ,pa onda stimam.
napravim onaj mjerac polja sa led diodama i pratim zracenje antene.
trimere na veronici stimam dok mjerac polja nebude pokazivao najveci otklon,odnosno dok nebude svijetlilo najvise dioda,to jest dok antena nebude zracila najvise energije.
ovako kad stavim otpornik 75 oma mjesto antene i nastimam,pa onda spojim antenu ,nema snage i dioda na odasiljacu nesvijetli.
znaci drugacije stimam za dummy load 75 oma ,a drugacije za antenu 75 oma.
e samo da pitam:
Objasnio sam ti gore zasto i kako ces stimati.ovako kad stavim otpornik 75 oma mjesto antene i nastimam,pa onda spojim antenu ,nema snage i dioda na odasiljacu nesvijetli.
Nemozes otpornikom nista napraviti nego probu, antenu moras namjestati kad sje spojena i postavljena na mjesto (i odasiljac mora biti an fiksnom mjestu u metalnoj kutiji, micanjem i vrtenjem ploce okolo je noramlno da se detunira.
Antena nesmije biti pokrivena, i to sam vec vise puta ponovio.e da ovo sam sam se sjetio ga gornji dipol nece biti blizu nicega kad stavim na dimnjak.
e samo da pitam:
Digni je barem metar iznad dimnjaka ili postavi negdje na otvoren krov.
imam i ja jedan takav, taj je iz analognog mobitela(HR stara mreza 099), oni su radili na podrucju 410-420Mhz(predaja), a prijem na 930MHzFirkragg wrote: imam ovdje mitsubishijev M68710L, iskopan iz (valjda) ancient voki tokija. 2W i 400-430Mhz, malo cudno (ocekivalo bi se 433), ili je to bila neka tajna frekvencija..
ok!Firkragg wrote:Objasnio sam ti gore zasto i kako ces stimati.ovako kad stavim otpornik 75 oma mjesto antene i nastimam,pa onda spojim antenu ,nema snage i dioda na odasiljacu nesvijetli.
e samo da pitam:
