Izvor 0-30V 0.002-3A
Ljudi odučio sam se na izradu jednog napajanja. Na elektronika.rs.ba sam već naručio komponente. Ali nakon što sam pročitao i zadnjih 5-6 rečenica teksta sa stranice na kojoj se nalazi shema i upute shvatio sam da u shemi ima malo problema. O čemu se radi??? Tamo piše da se tranzistor 2N3055 pregrijava i da treba spojiti 2 u paralelu sa emiterskim otpornikom 0.1ohm/5W, da je napon na U1, U2, U3 na nogicama 7 prevelik jer maksimalni je 36V a po shemi je 45V to znači da će ga istodobno spržiti. Tamo piše da se svi pinovi 7, emiter od Q3 i gornja nožica od R19 spoje na izlaz od 7809 sa 18V zenericom između "common" pina i "-" pina kondenzatora C1 a ulaz 7809 na "+" od istog kondenzatora, i da ću tako imati ukupnu voltažu od 32.6V. Ovo sam donekle shvatio i nije tako teško izvesi, ali mene zanima da li je nešto slično moguće uraditi i sa LM317 jer nisam u mogućnosti trenutno naručivati nove komponente.
Evo link na shemu: http://img860.imageshack.us/i/schem.gif/" onclick="window.open(this.href);return false;
A evo i originalni tekst:
Ok. I bulid your project about a day ago. Mounted all the parts on the pcb and then concluded that there is some serious problems in this schematics. First, 2N3055 will overheat, so you have to connect two of them in parallel with emitter resistors 0.1ohm/5w. Second, maximal voltage between '+' and '-' of TL081 is 36VDC.If you connect them as it is shown in this circuit diagram that voltage will be about 45VDC, so they will burn down immediately. To fix this problem you have to reconnect all pins number 7 of U1, U2 and U3, emitter of Q3 and 'upper' end of R19 to out of an 7809 with 18V zener diode between 'common' pin and '-' of 3300uF cap, and input of 7809 connect to '+' of the same cap. Now, on pin number 7 and mentioned parts you'll have 27VDC, and total voltage will be 32.6VDC. Third, instead of using 3300uF, use 4700 or 6800uF/63VDC to reduce the ripple on higher currents (2-3A). The rest of the circuit is perfect. I like it cause it is so inexpensive and easy to make with those simple reconstructions i mentioned.
Što reći?
Re: Izvor 0-30V 0.002-3A
Čovječe... ti si to dosta dobro preveo...
Nije nikakvo čudo što se 2N3055 pregrijava, a način kako je povezan dodatni tranzistor u paralelu je čista klasika... Tek mala napomena, na oba emitera treba vezati 0R1 otpor!
Vjerovatno bi se dalo kemijati sa 317, i vjerovatno bi radilo, ali sigurno bi radilo sa 7812 i zener od 15V, ili 7815 i zener od 12V... pa i 7818 i zener od 9V... Bitno je napajanje 081 držati unutar 36V (a ovako je na 27V, malo rezerve!), i to je to!
A kond? Preporuka da se koristi 6800 je na donjoj granici za 3A! Može i veći, a ako si već nabavio od 3300, nabavi još jedan, pa i dva!
Ja mogu!
ivan09 wrote:...nisam u mogućnosti trenutno naručivati nove komponente.
Ja mogu!
Ma to sam na brzinu samo preveo. Da piše i to za kond ali to mi nije frka tog imam i previše.
Ma mogu i ja naručiti komponente aliii... Financije su problem... Jer ipak sam ja tek dijete od 16 godina. Za ovaj izvor sam već dao 50€ (kućište, komponente...) Kad malo bolje razmislim nije mi toliki bed ubaciti još 5€ i skupiti i te komponente pa kompletirati to kako treba.
Naručiti večeras i 7809 i tu zener diodu od 18V još jedan tranzistor i dva otpornika za njega pa šta bude...
Što reći?
Daj adresu na pm, pa možda ja nešto iskemijam iz garaže... odavno nisam nikome ništa poslao...
Da, bas sam htio reci...@Ivane, nemoj odmah kupovati dijelove, pitaj na forumu...ima ljudi koji imaju dijelova na kile.
Mogli bi napravit neki podforum za mlade elektroničare,kojima možemo poslat rabljene djelove,npr. kao što je @Feko meni..To me pokrenulo u ove vode
"cuksi" -> "dino_kc"
Pa mogli biste Mi se sasvim sigurno ne bi bunili Neegoo ja sam na brzinu napravio shemu po onome kako sam ja to shvatio, pa ako bi netko mogao pogledati da vidim jel sve u redu ako jest da počnem spajati...
(shema je prepravljena za minutu u paintu pa se nemojte smijati)
http://img809.imageshack.us/i/schemh.jpg/" onclick="window.open(this.href);return false;
Što reći?
Ja sam izradio taj stabilizirani ispravljač i otvorio vlastitu temu, u njoj možeš pronaći sve probleme na koje sam ja nailazio pa ih popraviti, ništa strašno, radi se o par komponenti:
http://www.elektronika.ba/forum/viewtop ... f=9&t=9312
Ali, ja ipak mogu ostaviti ovaj 2n3055 ne moram kupovati novi za 3A ako spojim 2 u paralelu????
Što reći?
Može, grijanje ti ovisi o disipaciji na tranzistoru.
I da, odgovori na PM...
Slabo si shvatio...ivan09 wrote:...ja sam na brzinu napravio shemu po onome kako sam ja to shvatio, pa ako bi netko mogao pogledati da vidim jel sve u redu ako jest da počnem spajati...
Kako misliš 3A provući kroz 7809?? Zener naopačke? Emiter Q3?
Dakle + od C1 vuci na kolektore izlaznih tranzistora, i ulaz 7809!
Sve ovo ostalo što je na izlazu 7809 (osim kolektora izlaznih tranzistora), ostaje, i emiter Q3!
Zener uvijek u zapornom smjeru!
Haj' sad probaj!
Evo sad sam uradio kako si mi i predložio... Valja li ovo?
http://img576.imageshack.us/i/schem.jpg/" onclick="window.open(this.href);return false;
Što reći?
Zamalo...
Ja bi to ovako...
http://img225.imageshack.us/img225/1716/zaivan09.jpg" onclick="window.open(this.href);return false;
Ja bi to ovako...
A bio sam blizu, sekunda mi je falila osim što sam diodu pogrešno označio ali, žurilo mi se u školuu pa u svoj toj zbrci bez razmišljanja se desila i ta pogriješka...
Što reći?
Ta skunda je razlika između "funkcionalnog uređaja" i "uređaja za dimne signale"...
Kad se "baviš elektronikom", brzina nije vrlina! Najviše grešaka dešava se baš kad nešto "na brzinu" želiš uraditi, izmjeriti... vidjeti jel' radi prije zadnje provjere...
Ono nisam znao to priznajem, ali dioda me je zeznula.
Čuo sam da ne treba svo ovo kompliciranje ako je napon transformatora 24V da neće biti nikakvih problema...
Što reći?
Još mi samo TL081 fali. Imam 084 al koliko sam ja vidio oni nemaju ništa zajedničko pa ne mogu njega nikako iskoristit. Ako ima netko nek javi da mijenjamo.
Što reći?
4 x 081 = 084
Gornja jednađba definitivno matematički nije tačna, ali 084 je četverostruko OP, koje sadrži 4 081!
http://pdf1.alldatasheet.com/datasheet-" onclick="window.open(this.href);return false; ... TL081.html
Mora toga biti... a ako baš ne nađeš - javi!
Mislio sam na njegov raspored nogica i uopšte na nogice. Jer pločica je već izrađena. A da napravim jednu pločicu sa koje bih napravio mostove do ove originalne i tako iskoristio jedno TL084 umijesto 3 081. Da li bi tih 10-ak cm žice stvaralo probleme???
Što reći?
Naj se za*ebavat!
Mislim... to bi radilo, al' na šta bi ličilo?
Ima toga u mojoj "garaži"...
