JUN24
Current projects and news
Since I didn't post anything for almost a year, it would be good idea to introduce you with some of my previous and current projects that I am working on.
Project 1: Vehicle Inductive Loop Detector. This device is used to detect presence of vehicles above the wire-loop buried in road. It took me few months to perfect this project and current version of this device is v2.1 (third).
Project 2: Word Clock v2. Front panel is now looking much better because I used a car tinting foil to darken not-illuminated letters. You can see the effect of this foil in the photos later. Electronics are also replaced, new PCBs were designed and factory made.
Project 3: Vehicle-activated sign - a road sign that displays current vehicle's speed by using Doppler radar technology and 7-segment display. This project is currently on hold until Project 4 is done.
Project 4: This project doesn't have an official name yet, but it is used to control home appliances over the Internet.
More details about these projects
Project 1 - Vehicle Inductive Loop Detector - ILD (single channel)
This sensor is usually used in automatic road barriers, controlling traffic lights, car parks, etc. It works by detecting a change in inductance of the loop, and it does that by detecting a change in frequency of oscillator that powers that loop. It can also be used to measure passing vehicle's speed if two devices are used or one dual-channel. I am still not sure whether I am going to publish source file for this project or even HEX file. I used PIC16F877A microcontroller and firmware is written in HI-TECH C.
The first version (v1) of this device was done with PIC16F628A but it wasn't designed very well particularly because of the way supply voltage was regulated. I used linear voltage stabilizer LM317 and it produced excessive heat which caused problems with the on-board oscillator which was very close to it on PCB.
loopv1
Inductive Loop Detector v1
After that came second version v2 where I used PIC16F877A and step-down regulator TPS5405. This version works pretty well with one drawback - maximum supply voltage was 28V DC. This made it impossible to power the device from 24V AC (when rectivied this results in 34V DC). This had to be fixed.
loopv2c
Inductive Loop Detector v2
loopv2
Inductive Loop Detector v2 - bottom PCB side
In third version (v2.1) I replaced TPS5405 IC with the one that can withstand supply voltages of up to 40V DC. This made it possible to connect the device to 24V AC.
loopv2.1a
Inductive Loop Detector v2.1 - assembly
loopv2.1.c
Inductive Loop Detector v2.1 - done
Testing - on desk
Testing - with vehicle
Project 2: We are back on Word Clock project. As mentioned, front panel is now looking much better as you can see in the photos bellow. PCBs for electronics are redesigned and factory made.
wcv2a
Word Clock v2
wcv2c
Word Clock v2
wcmainpcb
Main PCB top and bottom side
wctouchpcb
Touch sensor PCBs top and bottom side
Project 4: A project that still doesn't have an official name but it will be used for controlling home appliances over the Internet. It is in active development and it should be done very soon. The idea is to connect a "Base Station" to ADSL modem (or a router with Internet access) that will be used to control remote "RF Modules" spread all over the house. Communication between Base Station and RF Modules is done by nRF24L01+ wireless 2.4GHz modems. Microcontroller used in Base Station is ATmega328P and connection to Internet is accomplished by ENC28J60 with TCP/IP Stack from Tuxgraphics.
ctrlbasestation
Base Station
ctrlmodule0x01b
Module Type 1 - top side
ctrlmodule0x01c
Module Type 1 - bottom side
ctrlmodule0x01d
Module Type 1 - TESTING in water heater
Projekti u zadnjih godinu dana Bookmark and Share Comments (7)
Hello I wonder if I can post the code in your exalted project c inductive loop detector v2.1, am a student of electronics and can guide me a lot in my graduation project. Many thanks in advance if you can.
IP: 186.80.248.85
Pozdrav Trax,upravo pocinjem sa pravljenjem tvog sata,vidim da su plocice gotove,kako se porucuju?Takodje,da li ima nekih ispravki i poboljsanja u medjuvremenu sto se celog projekta tice?Pozz
IP: 212.62.41.202
Thank you for sharing. Your post worth of reading. Waiting for new posts. buyincoins
IP: 184.22.230.198
Nije ITD-TIM, nego batchpcb.com
Jel to plocice radio ITD-TIM?
IP: 93.139.100.153
Haha, ovo je testna implementacija :-)
Ja se sa ovim bojlerom ne bi kupao :))
Comment page:
