SEP16
Word Clock - published
I have been seeing these "Word Clocks" all over the internet for the past few years, but they never really impressed me much. Mostly because there is nothing special about them (from the electronics point of view) but after seeing QlockTwo made by Biegert&Funk I simply couldn't resist making one that looks that nice.
But of course, in my local language. Aside from different language, I wanted it to be able to display full time - every minute of an hour - so I ended up using 248 white LEDs. To keep that stealthy look I used two capacitive touch sensors under the glass (near left and right LED dots) as buttons for the user-input.
Project page
[ Source: Trax ]
Sat sa riječima - objavljen
Link
comment [17]
- From 22.dimitri on 01-11-2019 at 10:30:02
Poštovani,
da li je moguće naručiti izradu ovog sata i slanje istoga poštom?
molim javite mi se na 22.dimitri@gmail.com
IP: 161.53.155.100
comment [16]
- From trax on 05-11-2017 at 13:34:26
bdbdhdh, u downloadu imas nacrt te plocice sa dimenzijom u formatu LAY. Skini sebi
sPrint-Layout i otvori taj fajl, mozes iz njega printati za plocicu a mozes i vidjeti koja mu
je dimenzija. Ja se ne sjecam dimenzije, a nemam na ovom novom racunaru sPrint-Layout.
- From bdbdhdh on 05-11-2017 at 12:26:46
Jel mi mozes da kazes koja je tocna duljina jedne one plocice za ledice?Posto si u downloadu
ostavio samo sliku
IP: 93.139.213.195
comment [14]
- From patrick on 21-11-2013 at 16:31:42
Thank you!
IP: 24.89.14.150
- From trax on 21-11-2013 at 16:19:48
Yes, there is a PCB design in Gerber format, I think I didn't publish it yet. If you need it, I
can send them to your email.
I will register english version of bot question... sometimes, thanks for pointing that out!
- From patrick on 21-11-2013 at 16:12:14
When I said kit, I meant are the circuit boards being made for it?
One other thing, you need to have your forum registration bot question in English as well :)
IP: 24.89.14.150
- From trax on 21-11-2013 at 08:12:57
Hello there. Sorry, there is not KIT available :-(
- From patrick on 21-11-2013 at 02:12:18
Hello,
I found you site after seeing the word clock on you tube. I tried to register on your forum to
find out more information about building one but I couldn't figure out the bot question as I
could translate it.
I was wondering if you now have the parts available as a kit?
IP: 24.89.14.150
- From adopilot on 17-09-2013 at 12:27:21
Da li se može naručiti izrada ovakvog sata i po kojoj cijeni
lijep pozdrav moj e mail je adopilot kod google maila
- From kustas on 31-05-2013 at 12:52:26
a ovaj max7219cwg i ds3232-n s njima ne treba nista njih samo zalemim za plocicu? i ima li gdje
program koji prebacujem na ATMEL AVR ATmega328P za skinit?
