/Projects/Word Clock
word clock qlocktwo circuit schematics
Firmware features
1. time display, obviously
2. date display
3. temperature display
4. seconds display
Structure
wordclocksandwitch
bazen1
bazen2
You can see me my reflection in the glass :-)
The Middle (wood)
drvo2
The beginning
drvo6
drvo8
woodgroovesdone
woodreflectivepainting
woodedgespaintedblack
Electronics
wccpu
mainpcbdrilling
Main PCB drilling
mainpcbdone2
mainpcbdone
ledmatrixschematics
ledstrip
ledmatrix
ledmatrixinwood
wcMAX7219breakout
max7219pcb
max7219inplace
max7219soldered
addingcornerleds
wctouchsensor
P8080130
Capacitive touch sensor PCBs
at42qt1011
P8080141
P8080140
touchsensorinplace
Touch sensor PCB in place
mainpcbinwood
alldone2
All done!
The Back (hardboard)
Testing the LEDs
matrixbadleds
LED matrix test
Images of completed clock
Videos of clock working
Download counter: 4,153
Rating: (2.96, votes 5135)
Date: 12-09-2012
841_word_clock.zip
Bookmark and Share Comments (222)
comment [142]
Hibs, what LEDs did you use for your clock?
comment [141]
Paus papir sam zalijepio sa selotejpom na drvo :-) To je obicni paus papir iz knjizare. Mozes koristiti i tu imitaciju pjeskarenog stakla - mozda je to i bolje. HIBS: I will check it out! We can continue discussion at forum, there is a forum topic link at the beginning of this project page...
comment [140]
U tekstu si napisao da si koristio obični paus papir. Je li to baš obični papir ili je to ona samoljepljiva folija imitacija pjeskarenog stakla. Ako je obični paus papir, kako si ga zalijepio? Je li on onda zalijepljen na ovu crnu foliju ili na medijapan?
comment [139]
Nice work Hibs!
comment [138]
Hi Trax (and anyone else whose interested). Here is link to video/images/english front/english header file of my clock so far. http://www.mediafire.com/?6lkbs64pl3s42dt The wood is cut to fit in an Ikea Ribba frame. The word front is printed on 2 pieces of transparency sheets aligned together. So far the clock only says 'IT IS x MINUTES PAST x" although the word front allows for 'IT IS x MINUTES/QUARTER/HALF PAST/TO x" for future firmware updates.
IP: 94.192.64.107
comment [137]
sorry, i again. i have the hardware finish and have made the first test. Your programm ist on the ATMega328. Must i setting fusebits? All LED's are shine sometimes white, somtimes red (reversed polarity). What can to be the Problem. The touchsensor is not reaction.
IP: 62.159.22.218
comment [136]
...for this, soon!
comment [135]
Pielo, no, you don't connect the corner LED to MAX and GND, you connect it ONLY to MAX outputs. It is a bit difficult because I didn't draw the schematics for this part, but I will try to explain. The two upper MAX chips control only 6 rows of LEDs, so you have two spare rows to connect 16 LEDs. You will connect only two LEDs for top-left MAX, and two for top-right MAX to any spare "SEG" pin (ANODE) (see datasheet of MAX). And, cathodes will be connected to "DIG" pins. I will try to draw schematics for th
comment [134]
Thanks for the information. Again for safety, I must the cathode from the corner led's fixed at GND and anode to the free pins of the MAX7219. Sorry my english is not got, I hope you understand me. (i'm german)
IP: 62.159.22.218
comment [133]
@PIELO Hello if you look closely you will not use any output on the MAX7219 so you can use them for LED corners or if you use a matrix of 16x16 instead of 14x16 as an example you can use the extra output on the ATmega168p. Best regards
IP: 76.68.172.98
