comment [151]
- From Pielo on 06-02-2013 at 08:37:01
the source code link is under the videos (word clock.zip in folder firmware)
IP: 90.186.0.88
Firmware features
1. time display, obviously
2. date display
3. temperature display
4. seconds display
Structure
The Middle (wood)
The beginning
Electronics
Main PCB drilling
Capacitive touch sensor PCBs
Touch sensor PCB in place
All done!
The Back (hardboard)
Testing the LEDs
LED matrix test
Images of completed clock
Videos of clock working
Download counter: 4,154
Rating: (2.96, votes 5149)
Date: 12-09-2012
@trax finished testing your pcb? ready for sale?
best regards
IP: 76.68.173.94
IP: 90.186.0.88
Firmware is available for download by clicking on RED DOWNLOAD BUTTON below the article.
Hi,I´m doing this clock for a school project, i´m from Mexico,but i can´t found the source
code, can you help me? please.
IP: 189.191.19.104
Yes, corner LEDs are connected to MAX7219 just like the other LEDs. Please go to forum
discussion about building the clock. Soon I will post a full schematics of the LED matrix and
corner dots. Until then, go to forum, there is a link in the top of this article.
Hello Trax,
I'd really like to make on word clock like yours but I have some questions.
1.) How do you connect your corner LEDs? Are they connected with the MAX7219 just like the
other LEDs?
I'm asking because I want to know if it's possible to turn them on and off depending on the
time showing the extra minutes.
For example:
If the time is twenty six minutes past eight, I'd like to show the words
twenty+six+minutes+past+eight on the clock and turn on the top left corner. One minute later
I'd li
IP: 78.87.254.244
sorry...'/9diffuse the light more)' should read '(diffuse the light more)'
IP: 94.192.64.107
...which in turn reduced the letters brightness more than I would of liked, even using a 9K
intensity setting resistor for the MAXs
IP: 94.192.64.107
Hi Trax. The LEDS I used were 5mm flat top white LEDs off EBAY. These ones:
http://www.ebay.co.uk/itm/1000-pcs-5mm-2pin-Flat-top-White-LED-Wide-Angle-Light-Lamp-/121013614
472?pt=US_Car_Lighting&hash=item1c2cf93788 . I wouldn't use them again because, despite
their brightness their intensity as a function of angle is not uniform (dark rings are
present). To eliminate these rings /9diffuse the light more) I had to use a few tracing paper
layers...
IP: 94.192.64.107
