comment [161]
- From trax on 26-02-2014 at 08:37:28
You don't need Serilux, you can use any other high quality self-adhesive foils used for outdoor
stickers!
Firmware features
1. time display, obviously
2. date display
3. temperature display
4. seconds display
Structure
The Middle (wood)
The beginning
Electronics
Main PCB drilling
Capacitive touch sensor PCBs
Touch sensor PCB in place
All done!
The Back (hardboard)
Testing the LEDs
LED matrix test
Images of completed clock
Videos of clock working
Download counter: 4,154
Rating: (2.96, votes 5149)
Date: 12-09-2012
My problem is that I live in France. The vinyl I find are coated with glue (the problem is that
the glue must see through the glass), I imagine that the adhesive vinyl used as films that are
placed on car windows for tinting but they are transparent and are not suitable. So I would
like if possible the reference product used or a website where I can buy this product.
IP: 80.13.70.118
stickers!
Where can i buy the Serilux self-adhesive foil ?
IP: 80.13.70.118
Postio je li šansa da se naruči ovakav jedan sat
I po kojoj cijeni ?
I know, but these LEDs that I have light up at 90 percent brightness with only ~5mA. The rest
~15mA will give them full brightness. Anyway, now I have changed the resistor for 20mA from the
MAX7219 datasheet - there is a table for your reference.
hello,
would like to ask how u choose Rset resistor for Max7219? And how is that possible that LED
needs just 5mA? Mine i got (1210 PLCC2) needs 20mA.
So the worst case scenario is 640mA for LEDS..
IP: 158.129.68.157
Rafał widzę że zacząłeś robić ten zegar.
Mam parę pytań co do frontu i rozwiązań co do trybu 24h. GG 2884612
Trenutno se nema gdje kupiti, ali nadam se da ce uskoro biti dostupan u prodaji!
Ko pravi, koliko kosta i gdje kupiti? :)
IP: 109.165.172.173
Yes, they work excellent :) I will post the results here in a few days. All parts are SMD on
the board, including the ATmega328P in TQFP package...
