comment [181]
- From MICHALUS on 15-10-2014 at 16:27:11
One question. How to connect max7219 together??What does it mean MAX7219_AUX on the wc_cpu.sch
file
IP: 78.8.12.41
Firmware features
1. time display, obviously
2. date display
3. temperature display
4. seconds display
Structure
The Middle (wood)
The beginning
Electronics
Main PCB drilling
Capacitive touch sensor PCBs
Touch sensor PCB in place
All done!
The Back (hardboard)
Testing the LEDs
LED matrix test
Images of completed clock
Videos of clock working
Download counter: 4,154
Rating: (2.96, votes 5149)
Date: 12-09-2012
For connecting MAX'es together, please see this forum discussion:
http://www.elektronika.ba/forum/viewtopic.php?f=13&t=13916
file
IP: 78.8.12.41
Yes, I first stick vinyl graphics to the glass and then I glue graphics to the MDF. Graphics
hold the glass in this case! It hangs on my wall for two years now and no problems whatsoever!
How did you combine glass and MDF. I know it was silicone but at first you stick vinyl
graphics to the glass and then you put silicone on this graphics??
IP: 91.223.33.10
PCBs for v2 are available for download now. Check the third UPDATE note in the beginning of the
page.
oh man, I forgot. I will publish PCBs when I get home in couple of hours.
Hello
I reiterate the question of the pcb for new version
How can you send it to roman_os@wp.pl
So, you want schematics/pcb for new version? OK, I will send you that later...
So I was on the forum but have not found a tile designs smd in Eagle
Main PCB, touch sensors smd in Eagle?
