/Projects/Word Clock
word clock qlocktwo circuit schematics
Firmware features
1. time display, obviously
2. date display
3. temperature display
4. seconds display
Structure
wordclocksandwitch
bazen1
bazen2
You can see me my reflection in the glass :-)
The Middle (wood)
drvo2
The beginning
drvo6
drvo8
woodgroovesdone
woodreflectivepainting
woodedgespaintedblack
Electronics
wccpu
mainpcbdrilling
Main PCB drilling
mainpcbdone2
mainpcbdone
ledmatrixschematics
ledstrip
ledmatrix
ledmatrixinwood
wcMAX7219breakout
max7219pcb
max7219inplace
max7219soldered
addingcornerleds
wctouchsensor
P8080130
Capacitive touch sensor PCBs
at42qt1011
P8080141
P8080140
touchsensorinplace
Touch sensor PCB in place
mainpcbinwood
alldone2
All done!
The Back (hardboard)
Testing the LEDs
matrixbadleds
LED matrix test
Images of completed clock
Videos of clock working
Download counter: 4,149
Rating: (2.96, votes 5112)
Date: 12-09-2012
841_word_clock.zip
Bookmark and Share Comments (222)
Svaka cast i od mene... Koliki su ti bili troskovi elektronike? Da si najavio sta ces da pravis, mogao sam ti obezbijediti free CNC glodanje u Bijeljini ili bar folijski materijal. Sledeci put kad budes lijepio foliju, trazi transfer foliju kojom se sluzi svako ko radi firmopisacke poslove...
IP: 80.239.242.207
Svaka cast Trax!! :) Ako se moze naruciti jedan ovakav sat, onda me racunaj, predobar je... ;)
IP: 109.163.140.93
Comment page: <...17181920212223
