- From trax on 19-09-2012 at 09:42:16
Diode su neke no-name sa ebay. PLCC-2 WHITE SMD LED
Firmware features
1. time display, obviously
2. date display
3. temperature display
4. seconds display
Structure
The Middle (wood)
The beginning
Electronics
Main PCB drilling
Capacitive touch sensor PCBs
Touch sensor PCB in place
All done!
The Back (hardboard)
Testing the LEDs
LED matrix test
Images of completed clock
Videos of clock working
Download counter: 4,149
Rating: (2.96, votes 5112)
Date: 12-09-2012
Nice project and build quality ! How did you make the 'grooves' ? Standard drill or something
more sophisticated ?
IP: 195.68.2.34
Da cijena sitotiska za 1 komad je i ovdje (Osijek) dosta visoka.
Koje diode (LED) si koristio?
IP: 95.178.176.134
DorinMD: Ok, I will post the picture at www.elektronika.ba/wc.jpg when I finish it.
vlatko: folija je crna crna, nema sivoga uopste :-)
sito tisak je PRESKUP za jedan primjerak sata, barem ovdje kod mene u stamparijama.
Jako, jako dobro. Svaka čast. Baš razmišljam da si i ja napravim jedan. Jedino što bih
probao drugačije je da izbjegnem foliju. Probao bih sitotisak direktno na staklo (sa donje
strane). Iz iskustva znam da ljepilo od folije daje lagani sivkasti ton.
U svakom slučaju super projekt! Odlično!
IP: 95.178.182.181
I want to translate the clock in the Russian and Romanian.
If not difficult shows a connection diagram LEDs to words.
Also, circle the word, like this:
http://habrastorage.org/storage2/e41/681/f0a/e41681f0a23189aac087b2b0a3cd6388.jpg
Waiting for your early reply!
Thanks in advance!
IP: 178.168.32.117
Svaka cast. Zasluzeno zavrsio na Hack A Day. Sve pohvale.
IP: 109.165.211.18
