Firmware features
1. time display, obviously 2. date display 3. temperature display 4. seconds display 5. configurable times of showing for all of the above (for example, the clock can display time for 20 seconds, and move to next thing to display: date, temperature or both and go back to time. It can even be set to display only the temperature) 6. automatic LED brightness adjustment according to ambient light (with automatic sensor calibration) 7. corner LEDs (dots) blinking at 1/2 Hz rate (or even turned off) 8. sleep mode - shutdown until next button (sensor) press
Structure The build itself was a real motivational rollercoaster mainly because it involved gluing a "letter mask foil" with all the letters which was the most nerve consuming process, a lot of woodwork, lots of soldering and some programming.
The Front (glass + vinyl graphics) To make the front for the clock I decided to use 3mm glass with machine-polished edges in so called "flat polish" which leaves a nice small bevel. Glass is more scratch resistant, durable and cheaper then plexiglass so that's why I have chosen it. The foil with letters is a self-adhesive black glossy foil by SERILUX™ which was cut by vinyl graphics cutter machine. The idea was to glue it to the back of the glass (for that extra glossy finish), so it was very important not to "trap" any dust particles between the glass and the foil since it would ruin the entire look. The best way to do it is under the water, and if some dust falls on to our working surface it would stay on top of the water. Much easier way is to simply use a spray filled with water and just a drop of dishwashing liquid/soap. This solution is sprayed on the glass and on the sticky side of the vinyl during positioning on the glass. The water+soapy solution will lubricate the entire process and make it possible to re-position the vinyl even after the sticky side touches the glass. The water is then carefully squeezed out with a credit card.
The process/tutorial of attaching vinyl graphics to the glass can be found all over the internet so I will not be explaining it here in detail, I will just say it is a two-man job for graphics of this size (17.7 x 17.7 inches). Foil graphics/letters are created and arranged using Inkscape - an open-source vector graphics editor. Font used is identical to the one used in QlockTwo - "DIN".
The Middle (wood) Entire clock electronics are embedded in standard 18mm thick MDF wooden panel with edges banded with glossy white PVC band. I simply ordered 17.7x17.7 inches MDF board with glossy white PVC edges from the local kitchen cabinet manufacturer. After it arrived I had to make 248 cone-shaped holes and spray them with reflective paint, which took me few days do complete.
The beginning
Electronics The whole thing is a dot-matrix display with 244 LEDs and 4 corner LEDs. Microcontroller used in this project is ATmega328P but the code can fit into ATmega168P just as well. Time keeping is done by DS3231 (or DS3232) i2c RTC IC from Maxim. It is a very good and accurate IC that also has a temperature sensor inside so we can read the temperature from it too. There is no power supply regulator in the electronics because I wanted to avoid any unnecessary heating. There is just one 5.1V Zener diode for over-voltage protection. Everything is powered from a 220V/5V 1A "wall wart" SMPS AC adapter and I strongly rely on it's voltage output accuracy.
Main PCB drilling
Just a note for soldering the LED matrices to MAX7219 ICs - no matter how you solder/arrange them, you can re-map them in the source-code. For example, if you mix Dig0 with Dig5 it is not a problem - there is a part of source code where you can change these references. I had to make that part of code because I freestyle-soldered these also. For user input I didn't want to put simple push-buttons simply because there is nothing special about them, so I ended up using two Atmel AT42QT1011 capacitive touch sensors which work excellent through vinyl+glass.
Capacitive touch sensor PCBs
Touch sensor PCB in place
All done!
The Back (hardboard) The back cover is made from Hardboard, a 3mm thick wooden material 17.7x17.7 inches in size. I will probably leave the clock without it, maybe I will just put a white glossy vinyl instead, just to protect everything from dust coming in.
Testing the LEDs From all 248 LEDs I found that only one of them didn't actually work, three were badly soldered - oops!
LED matrix test
Images of completed clock
Videos of clock working
Videos made during development There are several videos I made during the development.
@redmumba: I used this one:
http://forums.mikeholt.com/attachment.php?attachmentid=7613&stc=1&d=1350777728 I
actually borrowed it from a friend :-) You might not need a cone-shaped hole after all! IP: n/a
Question: What kind of bit did you use for the conical shapes? I've found both step bits
(expensive) and countersinks (not quite their intended purpose, but might work). What did you
end up using?
Thank you, and just to mirror what I'm sure everybody already has said--amazin gjob! IP: 54.240.196.185
[PART TWO] (3) I was a little confused with the word "degrees" at the end. Does this
have some reference to displaying the temperature in a way not shown before? IP: 188.221.249.49
[PART ONE] Hi Trax, I like what you are doing. I think I have a few questions. (1) After row 8
there are no words between 13 and 19 so you can't, for example, display "It is three
o'clock and eighteen minutes", although, the better spoken English would be "It is
eighteen minutes past three" (2) I don't think your firmware as it stands can display
"It is quarter to three", "It is quarter past three", and "It is two
o'clock and twelve minutes" for example in any given one hour period. Am I right? IP: 188.221.249.49
[PART TWO] ...nt firmware) and green (not compatible with current firmware?) coloured words
would be the closest to everyday spoken English but I don't think (please correct me if i'm
wrong) your language header file in its current format allows for "quarter to three",
"quarter past three", and "seven minutes past two" for example in any given
one hour period (ie. a reference to both the current hour name and the following hour name when
displaying different times within the same hour period) IP: 188.221.249.49
[PART ONE] Hi Trax. I have uploaded an initial English front to:
www.mediafire.com/view/?rdl80x39bdw6wwf that shows every minute of the hour. This front
corresponds to the black coloured writing in the example uploaded file:
www.mediafire.com/view/?ffcay3rb7je7isn , and is compatible with your language header file
format. Note, that some of the clock times are not 'exactly' how you would speak them in every
day life but they're not too far out, and it reads ok. The replacement red (compatible with
curre IP: 188.221.249.49
Hello Hibs! Thanks for the kind words. Yes, the clock will endlessly loop without manual
intervention however you configure it. Yes, you can use momentary push buttons that with
(positive output), you will just need to put decoupling capacitors in parallel with its
contacts. No firmware change required! When you make an english "front" and language
header file, please send it so I can publish it here. IP: n/a
